Very Disapointing.. RUST!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomzz09, Dec 15, 2009.
  1. Dec 15, 2009 at 5:52 PM
    Tacomzz09
    Tacomzz09 [OP] Well-Known Member
    Calgary
    09 DBL CAB TRD Sport Towing
    Hi guys, i just recently bought my Tacoma a year ago, hasnt seen winter until this winter, and so I looked under my truck today.. to find RUST. WTH do i do now? i only got 8000K clicks on it,
  2. Dec 15, 2009 at 5:55 PM
    dimitrik
    dimitrik Well-Known Member
    Dimitri
    Quebec
    09 Access Cab TRD-Offroad
    AllPro Skidplate
    Rust or just oxidation? There is no need to alarm yourself of oxidation. If it is rusting, you should check if there is a body guarantee.
  3. Dec 15, 2009 at 5:57 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Pics ?
  4. Dec 15, 2009 at 5:59 PM
    dimitrik
    Dimitri
    Quebec
    AllPro Skidplate
    I am pretty sure he just mistook rust with oxidation. Oxidation is what happens to a a bitten of apple when you leave it in the air. it does the same thing to metal, it's nothing to be alarmed about.
  5. Dec 15, 2009 at 6:02 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    And the statue of liberty. It used to be a copper color:D
    Learned that in 5th grade;)
  6. Dec 15, 2009 at 6:04 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Most of the heavy metal stuff will tend to show surface rust during this time frame/mileage, especially if your truck is not garaged kept. Probably nothing to worry about, but I hate rust so I keep up on the spot painting under my truck. However, keep a close eye on the frame and underbody areas for rust, which is cause for alarm with a newer truck. :cool:
  7. Dec 15, 2009 at 6:06 PM
    Tacomzz09
    Calgary
    lol, it is garaged, ever since day 1
  8. Dec 15, 2009 at 6:07 PM
    dimitrik
    Dimitri
    Quebec
    AllPro Skidplate
    Here is a tip that people don't hear a lot. Don't park your car on anything but paved roads. If it is not paved humidity will sip trough the dirt and produce rust under your body. Trust me i have first hand experience. It's fine leaving it from time to time, but if you consider your lawn as a parking spot, you should change that.
  9. Dec 15, 2009 at 6:13 PM
    Tacomzz09
    Calgary
    is it possible to restore the frame in the future when the rust actually occurs through the whole body chassis? for example, sand off all the rust and repaint it?
  10. Dec 15, 2009 at 6:15 PM
    dimitrik
    Dimitri
    Quebec
    AllPro Skidplate
    It is always best to deal with REAL rust immediately. Not hope to restore it later. Rust can propagate very fast.
  11. Dec 15, 2009 at 6:16 PM
    Tacomzz09
    Calgary
    yeahh, dam the snow hey? i hate it when they start putting salt on the roads lol
  12. Dec 15, 2009 at 6:18 PM
    dimitrik
    Dimitri
    Quebec
    AllPro Skidplate
    Yeah.... god damn salt! I like the snow, snow is fine, it is the salt that rusts cars. Want a tip? Pressure wash the salt off.
  13. Dec 15, 2009 at 6:32 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Putting your truck in a warm garage every night will accelerate rusting - heat accelerates the reaction between the steel, oxygen and water to form iron oxides (rust).
    From what I hear it's been too cold in Central Alberta all week for anything to rust, unfortunately probably too cold outside for a vehicle to start as well.
  14. Dec 15, 2009 at 6:49 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    There's your problem :D
  15. Dec 15, 2009 at 6:51 PM
    sabian
    sabian Active Member
    northern michigan
    SR5 tacoma
    Fortech is right. The worst thing you can do in a cold snowy climate is put the truck in wet every night into a heated garage. "rust never sleeps"
