Very quick question re rear shocks
Discussion in '1st Gen. Tacomas (1995-2004)' started by slobmonster, Jun 9, 2015.
  1. Jun 9, 2015 at 4:00 PM
    slobmonster
    slobmonster [OP] Active Member
    California
    00 Tacoma XCab 4WD
    Hi all. This should be a quickie. With 100k on the odo I am looking to replace my shocks (and find someone to do the struts).
    Bilstein specifies rear left, or rear right, for its shocks. Does this matter? (I recall swapping out shocks on a different model Toyota and they were identical.) In other words can I purchase 2 of this item:
    http://www.amazon.com/gp/product/B004JPV3PI/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
    And be good to go, for both sides?
    Thanks.
  2. Jun 9, 2015 at 4:06 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    In their catalog do the shocks have the same part #??
  3. Jun 9, 2015 at 4:54 PM
    travelfeet
    travelfeet Well-Known Member
    Andrew
    Troy, NY
    02 xtra 4x4 v6
    One is a bit longer than the other. You might be OK getting the longer size for both sides, but then you run some risk of bottoming one before the other. Both shorter and you could over extend one. I want to say its about an inch difference, they are close, but not the same.
    Snowman likes this.
  4. Jun 9, 2015 at 5:33 PM
    trx125
    trx125 Well-Known Member
    They are side specific. The longer one goes on the driver side to compensate for the extra weight of the driver, gas tank, etc. So you won't have the infamous Tacoma lean.
  5. Jun 9, 2015 at 9:16 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    How does shock length have any effect on ride height?
    OP they are side specific because one mounts toward the front of the axle and the other toward the rear, so they are different lengths.
  6. Jun 9, 2015 at 9:44 PM
    slobmonster
    California
    00 Tacoma XCab 4WD
    Thanks everyone! Needless to say I hadn't crawled under my truck today.
  7. Jun 20, 2015 at 9:15 AM
    slobmonster
    California
    00 Tacoma XCab 4WD
    Checked the part #s before installation, and the longer shock actually goes on the passenger side. Has to do with being mounted top towards the front on that side.
