vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Jun 29, 2020 at 10:38 AM
    #2221
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    vFTuner = "The Software"
    The Cable = "Tractrix"
    Tunepacks = "The License to run OVTunes"
    CygnusX191 likes this.
  2. Jun 29, 2020 at 11:00 AM
    #2222
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    You can access and install the p5f "tune" files because you bought the tune pack. The tune pack itself (when it's available) will also provide you with editable versions of the tune files.
    https://www.tacomaworld.com/threads/vf-tuner-for-the-3-5l-tacoma.662948/page-4#post-23227091
    https://www.tacomaworld.com/threads/vf-tuner-for-the-3-5l-tacoma.662948/page-4#post-23227119
    CygnusX191 and Shellshock like this.
  3. Jun 29, 2020 at 11:02 AM
    #2223
    Redline870
    Redline870 Well-Known Member
    2018 Cement Tacoma TRD Off-Road
    Are you positive? I will happily delete the post if it turns out I’m wrong. I hope I am wrong and I didn’t waste that money.
  4. Jun 29, 2020 at 11:03 AM
    #2224
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    From my understanding VFtune only come with the base editable tune. You get no access to the built tunes made by OVTune. The tunepack is whats supposed to give you the ones built by them.
    xxTacocaTxx and DES2009 like this.
  5. Jun 29, 2020 at 11:05 AM
    #2225
    OVTune
    OVTune Well-Known Member
    OVTune
    yes you can, and you will get VFT versions too. Rafael is working on them so we can release VFT of these base 2.0 finals
    wahoobie, CygnusX191 and tonered like this.
  6. Jun 29, 2020 at 11:08 AM
    #2226
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Let's say I'm 99% positive. Only @OVTune or @Rafael@OVTune can say 100%.
  7. Jun 29, 2020 at 11:10 AM
    #2227
    OVTune
    OVTune
    With tune packs you can flash both.
    Without tune pack purchase you'e not licensed to flash either. You only have access to stock files to make your own tunes.
  8. Jun 29, 2020 at 11:13 AM
    #2228
    Redline870
    Thank you for the clarification @OVTune!
    CygnusX191 and DES2009 like this.
  9. Jun 29, 2020 at 11:14 AM
    #2229
    Redline870
    Whew! Sorry about that guys, I already deleted the post
  10. Jun 29, 2020 at 11:18 AM
    #2230
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    I left your post which was quoted in mine, because sometime in the future someone else is going to ask the exact same questions.
  11. Jun 29, 2020 at 11:18 AM
    #2231
    Redline870
    I guess that raises another question then @OVTune... when the editable tune packs become available, how will we be notified and how will we access them? I assume an email will be sent out
    jomopdx likes this.
  12. Jun 29, 2020 at 11:18 AM
    #2232
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    It’s a bit complicated. To tune with VF Tuner, you need VFTune, a cable, and an editable tune. When you purchase VF, you’ll get a base tune with minimal tweaks by OVTune. The ‘Tune Packs’ give you the various versions (2.0 and possibly prior... though that last was for people that already owned a flash kit and is getting a little vague now).
    However, once the 2.0 VF tunes are out in the wild, you could conceivably get a copy of somebody’s edited 2.0 file. You would of course have to trust that it’s not been maliciously tweaked (or accidentally).
    Mat has said as much, that VF tunes could be shared (or rather it was possible and up to individual discretion). He in fact alluded to people making modifications and selling them.
    <edit> Mat’s on top of this thread and has already responded with clarifications.
  13. Jun 29, 2020 at 11:20 AM
    #2233
    Redline870
    Thanks for the info, I’m adding this to my notes for when I make a tutorial video. I don’t plan on making a video until I know the process inside and out though, I do not want to put out the wrong information.
  14. Jun 29, 2020 at 11:23 AM
    #2234
    Shellshock
    Iowa
    Just to clarify - you get the stock tune in .vft format. There’s no tweaks to it.
    When you buy the tune packs, you get the modified files.
  15. Jun 29, 2020 at 11:23 AM
    #2235
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    (Admin please delete this post if not appropriate, I don't want to break any rules and get into trouble, just trying to post helpful info that is relevant to discussions in this thread.)
    Techstream software requires a key to run that is based on your specific computer hardware OR it needs to be cracked. There are versions floating around here and there that are a bit older than current and include a key generator. Unfortunately the coding libraries used to compile the included keygen cause anti-virus programs to go nuts. Not wanting to take any chances I installed a VM and ran the keygen in the sandbox, then deleted the VM. Most people aren't that experienced or paranoid.
    Wanting a newer version, I found a website that allows you to post your TS hardware key and they will generate a reciprocating key for you for free that doesn't involve any anti-virus alarms: mhh*auto.com/Forum-Automotive-Activation-Key-Codes-Requests (remove the asterisk * in domain and yes there are two h's.) I can neither confirm nor deny that I may or may not have created a fake gmail account and requested a key that may or may not have worked correctly for the latest version 15.x of TS software. You *MUST* first introduce yourself in this forum for some reason: mhh*auto.com/Forum-Introduce-Yourself (remove asterisk again.) Copy-n-paste underlined text into browser tab because not clickable.
    I am neither encouraging or decrying the usage of such websites on the Internet and hope this post doesn't lend itself to derailing of thread topic.
    ryanhealy and tonered like this.
  16. Jun 29, 2020 at 11:25 AM
    #2236
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    I am neither confirming nor denying that I did the exact same thing for a functional copy of TS v15.00.028
  17. Jun 29, 2020 at 11:26 AM
    #2237
    Redline870
    Damn I wish I knew this sooner. I still don’t like that I bypassed that key gen application when it pops up with a picture of the Guy Fawkes mask and Windows Defender tells me it’s a Trojan
  18. Jun 29, 2020 at 11:27 AM
    #2238
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good stuff. In some other TS and TSB threads, this has been posted and seemed to work well.
    V15 is not yet needed for any Taco ECUs as V14 below allows customizations on the 2020s. V15 is needed for 2020 4runners though.
    Not having to worry about the a/v issues is nice. If I find the need to update TS, I will follow your route.
    :cheers:
  19. Jun 29, 2020 at 11:30 AM
    #2239
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No one has yet reported an issue other than the a/v warnings / quarantine problem. If there was a real virus threat or if someone has posted about any real exploitation, I would remove the share. There are some real IT monkeys that have used the current share and I do trust them and their assessment that the current version is safe to use.
  20. Jun 29, 2020 at 11:31 AM
    #2240
    Shellshock
    Iowa
    I’m not worried about it.
    First time I did it with TS in a VM. Now its just on my tuning laptop Windows partition which doesn’t really see the world anyway.
    CygnusX191 and tonered[QUOTED] like this.
Thread Status:
