vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Apr 28, 2020 at 10:14 AM
    #221
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
    Yes, I understand that adjusting the charge voltage is for AGM batteries and not stock batteries.
    What I don't understand is what OV Tune had said, "increase the duty for the added work". I don't know what that means.
  2. Apr 28, 2020 at 10:15 AM
    #222
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Pretty sure it's because the alternator will be working harder to produce the additional output, so by increasing duty, you should be compensating for that. Someone correct me if I'm wrong
  3. Apr 28, 2020 at 10:21 AM
    #223
    BOMBS
    Ok. I get the alternator will be working harder to produce the additional output, but what is increasing duty? How do you compensate for that? Is it something that can be done with software or added on hardware?
  4. Apr 28, 2020 at 10:21 AM
    #224
    OVTune
    OVTune Well-Known Member
    OVTune
    Yes this is what I meant. Additional voltage requirements and if you have heavy electrical loads you should increase the duty cycle to account for that.
  5. Apr 28, 2020 at 11:02 AM
    #225
    BOMBS
    Cool. Got it.
  6. Apr 28, 2020 at 11:51 AM
    #226
    moondog1
    moondog1 Well-Known Member
    GA
    01 Prerunner, 04 4x4
    I know this has been beaten to death in the other threads with no reported claims so far... But I'm on the fence for vF Tuner for my 2020 MT because I have an extended warranty up to 100k that I'm worried about voiding. I'd like to do the tune, but if my truck that I owe money on takes a dump that's going to really suck if I void my warranty.
    Any additional input or thoughts?
  7. Apr 28, 2020 at 11:52 AM
    #227
    Shellshock
    Iowa
    You can always flash back to stock if you needed to
    I’ve been tuned since approximately 20k miles.
  8. Apr 28, 2020 at 11:54 AM
    #228
    moondog1
    GA
    Few trips to the dealer since? I have no doubt the tune is amazing and will address what I don't like about it.
    Did/do you flash back before your trips to the dealer? And thank you for the reply.
  9. Apr 28, 2020 at 11:55 AM
    #229
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    What if I told you, there was no dealer....
    Bought used at 34k - tuned ever since and am now around 55k
    Shellshock likes this.
  10. Apr 28, 2020 at 11:57 AM
    #230
    wahoobie
    chris
    Suffolk, VA
    I thought this clip of info was informative for those who don't know about Duty Cycle:
    https://www.zena.net/htdocs/AltBatFAQ/dutycycle_A.shtml
    taco.matt, BOMBS and Markc1024 like this.
  11. Apr 28, 2020 at 11:57 AM
    #231
    Shellshock
    Iowa
    I did my 2 free maintenances but aside from that my truck has only been to the tire shop.
    I wouldn’t bother flashing back to stock unless you have some issue with the drivetrain.
    moondog1[QUOTED] likes this.
  12. Apr 28, 2020 at 12:03 PM
    #232
    Karminski
    Karminski Well-Known Member
    Virginia
    2016 Tacoma D/C M/T TRD Off-Road
    Other than the fact that the truck drives abnormally well, there should really be no way for the dealer to know that the tune is loaded.
  13. Apr 28, 2020 at 12:15 PM
    #233
    BOMBS
    Thanks man. That makes sense and the info was helpful for my understanding of what a duty cycle is in reference with an alternator.
  14. Apr 28, 2020 at 12:31 PM
    #234
    Markc1024
    Markc1024 Well-Known Member
    It seems based on that explanation that the designed duty cycle of an alternator is static for a given voltage; depicting how much it should run at that load. If one were to increase the voltage, that could over stress the alternator - therefore you would want to decrease the duty cycle about the same % that you increased the voltage?
  15. Apr 28, 2020 at 12:58 PM
    #235
    Frank_Zuccarini
    Frank_Zuccarini Obscure Member
    Frank
    Chicagoland
    AC-TRD-OR-4x4-Barcelona Red
    Not everyone here knows what ‘Duty Cycle’ means, if you would be so kind as to explain the term.
    Frank
    BOMBS likes this.
  16. Apr 28, 2020 at 1:08 PM
    #236
    Markc1024
    Wish I could - I'm trying to learn along with the rest of us. Just my take-away from that article, but I can't say for sure if it's an accurate representation.
  17. Apr 28, 2020 at 1:13 PM
    #237
    Markc1024
    I did find the below in a discussion related to GM ECM controlled charging systems. It seems to correlate with the values in the graphic Mat posted previously:
    Commanded Duty Cycle Generator Output Voltage
    10% 11 V
    20% 11.56 V
    30% 12.12 V
    40% 12.68 V
    50% 13.25 V
    60% 13.81 V
    70% 14.37 V
    80% 14.94 V
    90% 15.5 V
  18. Apr 28, 2020 at 1:21 PM
    #238
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    Roughly put, it's the amount of time something "works". If your air conditioner runs for 10 minutes and then is off for 10 minutes, and continues that way all day, it is operating at 50 % duty cycle. In electronics, it is similar. If a device outputs a signal, (or voltage), for half a second and then 0 for half a second, it is at 50% duty cycle. If it outputs for 0.75 seconds and then nothing for 0.25 seconds, it is operating at 75% duty cycle. You can use any time interval, it's just easier to visualize if 1 second time frame is used for reference.
  19. Apr 28, 2020 at 1:32 PM
    #239
    Markc1024
    Thanks, this seems pretty straightforward and makes sense. The relationship, and corresponding changes when making voltage changes, is what I think we're trying to ensure we understand. Is it a design constraint for a given alternator? or, just a reflection of how long it needs to be on for a given level of demand? Possible both it would seem.
  20. Apr 28, 2020 at 3:26 PM
    #240
    fake4x4
    fake4x4 Well-Known Member
    Los Angeles, California
    3rd Gen Tacoma TRD Off-Road DCSB
    Cool stuff
    i have an AGM and it would be nice if i didnt have to top off my battery all the time
Thread Status:
