vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Apr 29, 2020 at 1:46 AM
    #261
    Sunsetsearider
    Sunsetsearider Well-Known Member
    San Francisco
    2017 DCLB OR/1998 5 Lug
    Yep. Lock it on the slime and unlock it for the turn.
  2. Apr 29, 2020 at 7:48 AM
    #262
    InternationalHarvester
    InternationalHarvester VF Pro Licensed, KDMAX Authorized Vendor
    Sierra Nevada
    2017 TRD DC LB OR 4x4
    KDMAX Tooooned
    I sent him the system ID that I got using Flash Manager (the one we use now to download tunes)
    ...hope I did that right
  3. Apr 29, 2020 at 7:57 AM
    #263
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    I did the same. I believe we did it right. I got my keys (vF and flash mngr) and it worked on my flash manager and was able to flash my truck with 2020 beta.
  4. Apr 29, 2020 at 9:21 AM
    #264
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    I have 2x pc1400 g35's. Can you tell me why you chose the one you did? just curious
  5. Apr 29, 2020 at 9:34 AM
    #265
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Because I had a winch on board, but I felt that a single 34R-pc1500 would be overkill
  6. Apr 29, 2020 at 9:39 AM
    #266
    OVTune
    OVTune Well-Known Member
    OVTune
    We cannot host user created files, if we did we would be liable for those files
  7. Apr 29, 2020 at 9:44 AM
    #267
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Makes sense.
    wahoobie likes this.
  8. Apr 29, 2020 at 9:46 AM
    #268
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    A lot of really good ideas being mentioned. I bet that in general, screenshots of the affected tables that people have modified for specific purposes will be the most common thing to share... (I ASSUME) that will allow people to use the knowledge and effort of someone else to apply to their ECU and tune preferences, without causing a massive database.
    paleh0rse[QUOTED] likes this.
  9. Apr 29, 2020 at 9:54 AM
    #269
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Perhaps a template could be created that everyone completed in a standard format: ie text file or spreadsheet. This could be attached in the same post as the tune.
    Text file would be easiest because someone could look at that right away on the forum.
  10. Apr 29, 2020 at 9:55 AM
    #270
    Shellshock
    Iowa
    I wish I had your optimism that people could follow simple directions lol
  11. Apr 29, 2020 at 9:56 AM
    #271
    RushT
    North Texas
    It’s a win win. If they use it, great. If not, it’s just fodder for a dumpster fire. TW being TW after all.
    whatstcp, paleh0rse and ihatemytruck like this.
  12. Apr 29, 2020 at 10:03 AM
    #272
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    I would be open to suggestions from other TW users as far as "settings" or whatever for a vFTune, that I could incorporate into my own tune if I chose to do it. But I wouldn't just load and run any tune from another TW user. Tunes from Mat come with a degree of trust. Tunes from Vlady, not so much.
  13. Apr 29, 2020 at 10:05 AM
    #273
    Shellshock
    Iowa
    ^ this
    I wouldn't blindly trust TW but ill gladly borrow pieces and share information.
  14. Apr 29, 2020 at 10:08 AM
    #274
    ihatemytruck
    Dave
    Southern California
    Totally agree. I don't think I could load up and run a user tune.
  15. Apr 29, 2020 at 11:22 AM
    #275
    SpeySquatch
    2016 TRD OR DCSB
    So which one(s) for an AGM battery?
    taco.matt likes this.
  16. Apr 29, 2020 at 11:42 AM
    #276
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    I would not necessarily go by that as it is a GM spec. Your best bet is to change it in VF one step at a time and actually measure the voltage/current. That is unless someone comes up with actual Toyota information.
    From what I gather, the duty cycle in the Toyota ECM is not controlling the same thing as the GM ECM. I would have to dig into it further, but again, don't just go by what you read, you should verify. The computer systems and electronics on our trucks are not cheap to fix...
  17. Apr 29, 2020 at 11:48 AM
    #277
    OVTune
    OVTune
    Here is what I would recommend begin with.
    change the voltage trigger in the ECU from 14v to 14.6 volts.
    Do not change anything else.
    Confirm you are getting adequate charging voltage by checking.
    if not, increase duty cycle 2% at a time.
    verify again.
    If you need additional charging voltage AND you have excessive amounts of power draw, (extra lights... running the outlet in the bed, etc) you may want to increase duty cycle slighty more.
  18. Apr 29, 2020 at 12:36 PM
    #278
    SpeySquatch
    2016 TRD OR DCSB
    Nice! Can’t wait to be able to try this. Had my truck on the battery tender every day
    TWTaco likes this.
  19. Apr 29, 2020 at 12:39 PM
    #279
    TWTaco
    TWTaco Well-Known Member
    Dave
    Will be the first thing i use vF tuner for!
  20. Apr 29, 2020 at 6:03 PM
    #280
    crunchytaco13
    crunchytaco13 Well-Known Member
    ‘17 PRO MT Cement
    TRD CAT
    Bumping this question here - Can we send in System ID now, or do we need to wait for Tacoma support release in a couple days?
Thread Status:
