vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Jul 25, 2020 at 3:59 PM
    #2881
    e46_ema
    e46_ema Well-Known Member
    Emanuel
    Brevard County, Florida
    2020 Tacoma TRD Pro / 2018 Porsche 911 Carrera
    I'm in exactly the same boat 04B81 2.0 91 Premium Stock Not THX sometimes it downshifts way to early on corners.
    VB25[QUOTED] likes this.
  2. Jul 25, 2020 at 4:21 PM
    #2882
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    Indeed. I love it but more miles I drive the more like stock it drives. This is exactly what I payed for to stop.
    tacocart762 likes this.
  3. Jul 25, 2020 at 5:53 PM
    #2883
    tacocart762
    tacocart762 Well-Known Member
    desert55gr
    Santa Clarita Valley
    2017 Tacoma TRD Offroad Dbl Cab Long Box
    1.5in Bilstein 6112 Front,1in Alcan Leaf Rear with Bill 5100's. Battle Armor side step,bull bar, and rear step.
    Is this true? The truck is reverting to stock driving characteristics after some time has gone by with the tune installed?
  4. Jul 25, 2020 at 6:15 PM
    #2884
    VB25
    2018 TRD OR ACLB AT
    It's still way better, responds quicker shifts smoother, and winds the engine out a bit more if your really on the pedal, But I'm feeling like i am getting earlier shifts now. Still not as early as stock. I wonder why my truck needs to be in one of it's overdrive gears (5th) at 55Km/h (Approx 35mph) rolling around residential areas even with the 2.0 premium 04A61 NON-THX tune. With ECT on its in 3rd gear at around 2600-3000rpm at those same speeds (Exactly the same behavior as stock) and just causes a ruckus and makes the truck all herky-jerky. Also- Transmission fluid levels have been physically checked by me a year ago using proper procedure. The Tune did stop the mild driveline clunk I had coming to a stop, though :D I don't regret purchasing the tune, But did I maybe do something wrong installing it? I know I installed the correct file, got a confirmation that the flash was successful, and reset AT/LV right after. I also have hundreds of KMs/miles on 2.0 at this point.
    tacocart762[QUOTED] likes this.
  5. Jul 25, 2020 at 6:26 PM
    #2885
    Redline870
    Redline870 Well-Known Member
    2018 Cement Tacoma TRD Off-Road
    Have you guys reset the AT and LV values? That made a big improvement for me, especially since I didn’t know to reset the AT values the first time around. I also switch to the THX version which I like WAY more than the non_THX version
    CygnusX191 and VB25 like this.
  6. Jul 25, 2020 at 6:32 PM
    #2886
    VB25
    2018 TRD OR ACLB AT
    Certainly did reset the values. I fully understand why it's important, too. Hows THX at lower speeds compared to non? The trucks highway performance certainly improved but lower speeds are still meh sometimes. Could it be because I reset that stuff right after flashing? Should I have cycled the ignition before resetting? My first AT reset said unsuccessful so I tried again immediately and it completed successfully.
  7. Jul 25, 2020 at 6:43 PM
    #2887
    Shellshock
    Iowa
    This is the recommended way
    Turn to on (engine not running)
    Click identify to verify connectivity and ECU revision
    Flash tune
    Turn truck off
    Start truck to verify it starts and flash was successful
    Turn truck off
    Reset values
    Turn truck off
    Start and idle for 10 minutes
  8. Jul 25, 2020 at 6:49 PM
    #2888
    VB25
    2018 TRD OR ACLB AT
    Right on! this should be in the VF instructions... I will attempt to re-flash it tomorrow. I reset everything right after the flash completed without starting truck, Then I shut it off and started for the 10-15 minute idle. I wonder if that somehow affected things. I know there is an update to VFtuner, Do I need to install it if my computer has not updated windows or anything since my last flash?
  9. Jul 25, 2020 at 6:53 PM
    #2889
    Shellshock
    Iowa
    You can use what you’ve already got installed
    CygnusX191 and VB25[QUOTED] like this.
  10. Jul 25, 2020 at 7:07 PM
    #2890
    VB25
    2018 TRD OR ACLB AT
    Excellent. Thanks for the assistance. I'll report back tomorrow.
    CygnusX191 likes this.
  11. Jul 25, 2020 at 7:12 PM
    #2891
    Redline870
    The THX version really woke the truck up at lower speeds. Re-flash to THX, what have you got to loose? It only takes a few minutes. Reset the LV & AT values again and put some miles on it, I think you’ll be pleasantly surprised.
  12. Jul 25, 2020 at 7:15 PM
    #2892
    e46_ema
    Emanuel
    Yes I did reset the LV & AT following those same instructions mentioned. The truck drives better than stock but I don’t understand why it wants to be in 5th in 35-40 mph In residential areas under light trottle input. I still get the bumpy jerky speed bump hump feeling from 1,100 to 1,500 rpm on this same scenario. 5th at 40mph+/- I can replicate it very easily and the passengers on the truck notice it as well.
    VB25 likes this.
  13. Jul 25, 2020 at 7:16 PM
    #2893
    VB25
    2018 TRD OR ACLB AT
    This is good to hear. Just in time for my days off :D Following the steps Shellshock posted I will flash prem. 2.0 THX stock tyre with a reset tomorrow. Thanks for the suggestions!
    CygnusX191 and e46_ema like this.
  14. Jul 25, 2020 at 7:18 PM
    #2894
    VB25
    2018 TRD OR ACLB AT
    I, too am currently experiencing the bumpy jerky speed bump hump feeling from 1,100 to 1,500 rpm in those scenarios.
    e46_ema[QUOTED] likes this.
  15. Jul 25, 2020 at 7:27 PM
    #2895
    e46_ema
    Emanuel
    For some reason I feel it has to do with the Atkinson Cycle but im not an expert in the subject.
  16. Jul 25, 2020 at 7:30 PM
    #2896
    VB25
    2018 TRD OR ACLB AT
    Could be. Feels kinda torque converter lock unlocky, too. Does your ECT hold around almost 3000RPM just putting along in residential areas like mine?
  17. Jul 25, 2020 at 7:36 PM
    #2897
    e46_ema
    Emanuel
    Yes. I wish there was sweet spot between the two.
  18. Jul 25, 2020 at 7:40 PM
    #2898
    VB25
    2018 TRD OR ACLB AT
    I hear ya. The truck really doesn't like staying in 4th for any amount of time. With or without the tune. Odd, since its the 1:1 gear.
  19. Jul 25, 2020 at 7:49 PM
    #2899
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Ginger 3.0?
    Man, the 2.7 AT don't drive like that at all lol.
  20. Jul 25, 2020 at 8:21 PM
    #2900
    e46_ema
    Emanuel
    I’m going to try 91 Non THX 33” and see if it changes anything.
Thread Status:
