vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Aug 25, 2020 at 12:33 PM
    #3481
    moondog1
    moondog1 Well-Known Member
    GA
    01 Prerunner, 04 4x4
    I'm almost 100% positive mine does it in 2nd too. It's just not as obvious as it does in first if that makes any sense.
    I just found this page https://www.tacomaworld.com/threads/3rd-gen-manual-trans-characteristics.528380/page-7
    It describes exactly what I experience in several posts.
    CygnusX191 likes this.
  2. Aug 25, 2020 at 12:39 PM
    #3482
    moondog1
    GA
    Quoting from another thread here, is there a way to completely disable DFCO or is that a horrible idea?
    Karminski likes this.
  3. Aug 25, 2020 at 12:40 PM
    #3483
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I can 100% confirm that both the 2.0 DFCO test tunes and 2.0 MT Final have DFCO well below 1k. There are a few ways to observe this other than the butt dyno. The Insta MPG readout will go full red. If you are monitoring PIDs, Open Loop, Closed Loop, and DFCO will be shown. And, if you blip the throttle, you will see it hitch when the injectors come back on. This was how we tried to sort through the 1st gear issue.
    I am not sure what post you are referring to in that link.
  4. Aug 25, 2020 at 12:41 PM
    #3484
    moondog1
    GA
    Last rapid fire post sorry, how does the truck know it's in 1st gear on our 6mt?
    And as always thanks for the help!
    tonered[QUOTED] and CygnusX191 like this.
  5. Aug 25, 2020 at 12:43 PM
    #3485
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yeah. You can't completely disable it or your motor would be konking out all the time. Where it cuts in for 2nd through 6th is about as low as you would want it. We tried a bit lower and it stumbled.
    BTW, that OVT post is from a looooong time before it was tested. He learned a ton about the ECU after that. RAM dumps and such.
  6. Aug 25, 2020 at 12:47 PM
    #3486
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    Hahaha! That is a great mystery since all we have are the neutral switch and the two clutch pedal limit switches. I believe (could be wrong) that the ECU compares wheel speed to engine speed and reactively calculates the gear. Similar to the way that aftermarket gear indicators on motorcycles work. Of course between gears, the ECU has to be guessing.
    On 2.0, we now only have one throttle map for all gear and neutral. The anti-stall 1st gear issue seems to be triggered by very low speeds. I can hear it firing off when I am moving the Taco around in my garage and the RPMs dip when off the throttle. @OVTune 's guess was that if he could find the anti-stall feature, he might be able to fix 1st gear.
    I have not seen anything jumping out at me in vF that would allow us to do anything here at this point.
  7. Aug 25, 2020 at 12:50 PM
    #3487
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    So you're loving that big ol' torque bump. Driving with only 15% of the pedal is amazing.
    CygnusX191[QUOTED] likes this.
  8. Aug 25, 2020 at 1:27 PM
    #3488
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    And flooring it in second is just a ride
    tonered[QUOTED] likes this.
  9. Aug 25, 2020 at 1:28 PM
    #3489
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes, it is. :D
  10. Aug 25, 2020 at 1:29 PM
    #3490
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    A s pulling 3rd while getting on the highway..... Yee, and I cannot emphasise this enough, haw.
  11. Aug 25, 2020 at 1:30 PM
    #3491
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    So you went back to stock and modified from there vs modding 2.0?
  12. Aug 25, 2020 at 1:34 PM
    #3492
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :rofl::rofl:
    It is just all the gears. Resting my foot in 6th is quality.
    Amazing what was hiding under there. I can't even begin to imagine why they would do what they did with the stupid Stock tune.
  13. Aug 25, 2020 at 1:44 PM
    #3493
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    Makes me want to regear my AT slightly just to be in the same groove. Here's to hoping the perf AT final 2.0 is on par as much as possible.
    ihatemytruck and tonered like this.
  14. Aug 25, 2020 at 1:44 PM
    #3494
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    Yes, because 2.0 editable files are not released yet. I expect in time I will take what I have learned modifying the stock tune to goldilocks 2.0.
    ihatemytruck and CygnusX191 like this.
  15. Aug 25, 2020 at 1:46 PM
    #3495
    92ehatch
    Kinley
    Hendersonville NC
    Gotcha
  16. Aug 25, 2020 at 1:49 PM
    #3496
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yeah, uhhhh, sorry, but . . . . The 3.909 ratio is the other monster mystery. It's like they don't want the AT to see OD? :D
    ihatemytruck likes this.
  17. Aug 25, 2020 at 1:54 PM
    #3497
    wahoobie
    chris
    Suffolk, VA
    4.88/5.29 budget is being considered
    EDIT: it's because they are gonna slap a hybrid e-assist in there for the low end for the 4th gen
    CygnusX191 and tonered[QUOTED] like this.
  18. Aug 25, 2020 at 1:57 PM
    #3498
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is a tough budget to swallow. But, I do hear about better MPGs.
    Hahahaha! We'll see about that. I'm no fan of pulling around two powertrains. Just gimme full EV when it's time.
  19. Aug 25, 2020 at 1:58 PM
    #3499
    dunlap837
    2018QSDCLBSR5
    Lol. Except the stock tune shifts into OD at about 36mph. They tried to have both worlds.
  20. Aug 25, 2020 at 2:01 PM
    #3500
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    OR and PROs still get 4.30, yes?
    That's what the ECT button is for :D
Thread Status:
