vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Sep 4, 2020 at 2:10 PM
    #3821
    SpeySquatch
    2016 TRD OR DCSB
    Do you have the values you entered for the spots in VF?
    I used these:
    ECT set to 95 30 and up only.
    Phase duty 1 14.7
    Phase duty 2 90
    Phase duty 3 95
    Phase duty 4 90
    Phase duty 5 95
    Phase duty 6 13.6 - 102.39
    Phase duty 7 13.6 - 102.39
    Phase duty 9 - 90
    Phase duty 10 14.7 max 2 - 102.39
    Disable control set to 0 - 3.57
    Base phase additional additive - 0
    Phase duty minimum - 67.84
    Phase duty maximum 14.7 - 102.39
  2. Sep 4, 2020 at 2:15 PM
    #3822
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    Everything I did is in my post I quoted above:
    https://www.tacomaworld.com/threads/vf-tuner-for-the-3-5l-tacoma.662948/page-192#post-24111805
    only I set 30-168 to 94 instead of 93. If it’s not shown in the images in my post that I quoted, I didn’t change it.
    SpeySquatch[QUOTED] likes this.
  3. Sep 4, 2020 at 2:15 PM
    #3823
    OVTune
    OVTune Well-Known Member
    OVTune
    Reg keys will be going out in a moment
    tonered likes this.
  4. Sep 4, 2020 at 2:25 PM
    #3824
    SpeySquatch
    2016 TRD OR DCSB
    @OVTune
    is there anything wrong with these values for an AGM battery? Feedback on here has me second guessing and I don't want to assume anything. Thanks
    Phase duty 1 14.7
    Phase duty 2 90
    Phase duty 3 95
    Phase duty 4 90
    Phase duty 5 95
    Phase duty 9 - 90
  5. Sep 4, 2020 at 2:28 PM
    #3825
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    The .VFT file is exactly the same as the .P5F of the same description, except user adjustable correct?
  6. Sep 4, 2020 at 2:32 PM
    #3826
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yessir.
  7. Sep 4, 2020 at 2:32 PM
    #3827
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Yes
    tonered likes this.
  8. Sep 4, 2020 at 2:46 PM
    #3828
    Mooseditty17
    AJ
    WI
    Ok. So I adjusted the Accelerator throttle request map. Multiplied all but the 89.9s by. (* 125) 25%.
    See how twitchy the old girl gets. I kinda want it to feel like, how far I press down, is how far the throttle body opens. My dad's first gen tundra seemed like it had more power than my 2nd gen just because of the excellent throttle response. Even though the 2nd gen had 45 more ponies.
    tonered[QUOTED] and johntoyota like this.
  9. Sep 4, 2020 at 2:55 PM
    #3829
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good luck!
    I keep wanted to do the same over here.
  10. Sep 4, 2020 at 3:03 PM
    #3830
    Mooseditty17
    AJ
    WI
    Just went for a spin. I like it! Might even adjust the lower middle to middle upper sections a tad higher.
    This shit rocks!
    Well done @OVTune, @Rafael@OVTune
  11. Sep 4, 2020 at 3:43 PM
    #3831
    Uscgamecock7
    Uscgamecock7 Well-Known Member
    Nick
    West Columbia, SC
    2015 Tacoma Trd Sport DCLB 4x4(SOLD) 2017 Tacoma Trd OR 4x4(SOLD) 2024 T4R TRD PRO
    Let me know when your finish adjusting I may want to run your new file!!
    Mooseditty17[QUOTED] and DES2009 like this.
  12. Sep 4, 2020 at 3:59 PM
    #3832
    Mooseditty17
    AJ
    WI
    Is there a way to effectively eliminate the Atkinson's cycle with VF Tuner? I want full available power at all times. Also, what is the AICS? What the sudden surge of power with this? It kinda reminds me of my two stroke motocross days... but I'd like to get as much low end grunt outta this bitch as possible. Such a turd on the low end. I'm probably too scared to try what the answers are for all of this, and the soon to come performance tunes pretty much alleviate these issues right?
  13. Sep 4, 2020 at 4:31 PM
    #3833
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    You can run one of the SFOB tunes (super full Otto, version B) tunes to eliminate the Atkinson cycle.
    SFOB for Premium fuel will give you the most torque down low that you can get without forced induction.
    AICS is Toyota's version of a variable length intake manifold system. It can be tweaked to engage at various RPMs, but Mat
    has said there is definitely a sweet spot, and that is what he programmed.
  14. Sep 4, 2020 at 5:11 PM
    #3834
    Mooseditty17
    AJ
    WI
    Where can I find this magical SFOB you speak of? What's better about the 2.0?
  15. Sep 4, 2020 at 5:51 PM
    #3835
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Well, you'd need an MT.
    That will be available in the Tow tune when it is released.
  16. Sep 4, 2020 at 6:07 PM
    #3836
    Shellshock
    Iowa
    Correct. You need to up the duty cycle
  17. Sep 4, 2020 at 6:08 PM
    #3837
    Shellshock
    Iowa
    phase duty 1, leave at the default (76.79)
    GPatriot and SpeySquatch[QUOTED] like this.
  18. Sep 4, 2020 at 6:37 PM
    #3838
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    Little more drive time on my 2.0 premium stock THX 35 AGM tune and it seems to stay around 14.4 V all the time. That’s about where I was aiming so I’m going to leave it for a bit.
    mZiggy likes this.
  19. Sep 4, 2020 at 6:46 PM
    #3839
    Mooseditty17
    AJ
    WI
    Well then. Await the tow tune I shall.
    Duck hunting in the AM for this guy!! Night gentleman!
  20. Sep 4, 2020 at 6:47 PM
    #3840
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Enjoy!
Thread Status:
