vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Sep 9, 2020 at 5:57 AM
    #4021
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    I've heard of people trying the 35 tunes with 33s and noticed little to no difference. Give er hell. Might be better, who knows. Keep me posted
    ihatemytruck[QUOTED] likes this.
  2. Sep 9, 2020 at 6:01 AM
    #4022
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
    Hook me up with your skills on VF Tuner.
  3. Sep 9, 2020 at 6:40 AM
    #4023
    GPatriot
    GPatriot Well-Known Member
    Cincinnati, Ohio
    2016 Black Tacoma Sport 4x4 V6 DCSB AT Loaded
    KDMaxPro 10.0, OME 2" Med Duty lift, RCI Sliders, RoofRack, Skid Plate, etc.
    I'm on 31.6" tires on the 35" tune lol. Runs pretty good, especially with ECT on. However I also installed a speedometer calibrator which changes the shift points in the ECM and that helps even more.
    P.S. I also went back to the THX tune as well. Liking it.
    Mooseditty17[QUOTED] likes this.
  4. Sep 9, 2020 at 7:10 AM
    #4024
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    @Mooseditty17
    Since I am a stock tire tune and wanting to retain my AGM settings I copied/pasted your edits on the single table from your tune and went for a quick drive so far. I am mostly ECT-on all the time and I feel like this edit has improved some pedal feel without being overly aggressive. It just moved the modulation to a point where the pedal doesn't need to be pressed as far as prior. I can see playing with this some more over time but it was not too aggressive for my stock rig/gears/tire size. Thanks for taking the plunge and sharing it!!
    I see this update as a tweak for foot-to-brain go go sauce.
  5. Sep 9, 2020 at 7:16 AM
    #4025
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nice work, @Mooseditty17 !
    Mooseditty17 and ihatemytruck like this.
  6. Sep 9, 2020 at 8:13 AM
    #4026
    Saeros
    Saeros #dealermole
    Canada, Eh!
    2022 Venza Limited
    I'll definitely give this a go! Thanks for sharing :)
    Mooseditty17[QUOTED] and tonered like this.
  7. Sep 9, 2020 at 8:32 AM
    #4027
    ohioboater
    ohioboater Well-Known Member
    2017 DCLB 4x4 Sport
    Are there separate tables available in VF for throttle sensitivity in D versus D + ECT? In other words, can we keep Mat's throttle settings in 2.0 for normal D mode but increase them by 25% when (and only when) ECT is enabled? Or is that something that's still in development?
    xxTacocaTxx likes this.
  8. Sep 9, 2020 at 8:54 AM
    #4028
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    Quick question for anyone that may know, does the ecu adjust throttle based on steering angle? My truck majorly bogs in turns but as soon as I straighten out the wheel it seems to take off with ease. I can mash the pedal to the floor in a turn or push it a 1/4” and I get the same result.
  9. Sep 9, 2020 at 8:54 AM
    #4029
    su.b.rat
    su.b.rat broken truck
    no, that's your steering pump stealing your power.
  10. Sep 9, 2020 at 9:03 AM
    #4030
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    I changed the tire size in the drive train control to the equivalent of stock tire size on your file. Gonna flash it and check it out in a couple hours when I leave for lunch.
  11. Sep 9, 2020 at 9:08 AM
    #4031
    VB25
    2018 TRD OR ACLB AT
    Thanks for the suggestion I’m Somewhat aware of the steering pump surge. Can’t understand how it can rob 3/4s of the engines power though. Odd
  12. Sep 9, 2020 at 9:09 AM
    #4032
    ihatemytruck
    Dave
    Southern California
    Not that I've seen.
  13. Sep 9, 2020 at 9:10 AM
    #4033
    Mooseditty17
    AJ
    WI
    I haven't seen it. It would certainly be a good thing to be able to do. You could essentially have your own performance map switching. That'd be the shit! @OVTune , is this currently possible?
  14. Sep 9, 2020 at 9:10 AM
    #4034
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    At idle, the engine is making very little power and the variable assist rack is going to be sucking its hardest. So, it makes sense to me, esp if you have bigger, stickier tires.
  15. Sep 9, 2020 at 9:14 AM
    #4035
    Mooseditty17
    AJ
    WI
    It's definitely a placebo as far as "performance" gains. Just seems like the truck actually moves when it asked to move.
    wahoobie[QUOTED] likes this.
  16. Sep 9, 2020 at 9:15 AM
    #4036
    Mooseditty17
    AJ
    WI
    I've used this to my benefit when hooking up to trailers on uneven ground. Sometimes the extra revs from wiggling the steering wheel is enough to hook up without overshooting!
    tonered[QUOTED] likes this.
  17. Sep 9, 2020 at 9:18 AM
    #4037
    Mooseditty17
    AJ
    WI
    Let me know of any improvements you come up with. I greatly appreciate the feedback!
    :cheers:
  18. Sep 9, 2020 at 9:30 AM
    #4038
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    Post #44818 in the dev thread by OVTune implies that yes it does. I recall him saying outright that it does but can’t find the post.
    Also on the stock tune i can replicate throttle limit based on steering angle at a fixed accelerator angle every single time on a certain corner near my house. Pedal to the floor and it will go at a turtle pace until wheel straightens out, then takes off.
    The band aid fix I use is to run higher rpm either through s mode or modifying shift points so the engine can make more torque at limited throttle.
  19. Sep 9, 2020 at 9:37 AM
    #4039
    Shellshock
    Iowa
    just went and found that post, its from about 18 months ago.. a lot has changed since then
    https://www.tacomaworld.com/threads...lopment-thread.495735/page-2241#post-20677692
    I would think that the throttle limit controls he found in the last few days will help with this issue.
    tonered likes this.
  20. Sep 9, 2020 at 9:38 AM
    #4040
    dunlap837
    2018QSDCLBSR5
    Yes I never experienced this in 2.0 so I’m sure things changed for the better. I’m just saying the stock tune would do this.
Thread Status:
