vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Sep 10, 2020 at 5:42 PM
    #4141
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    @tonered
    HOW TO I ADD A ZIP FILE TO MY SIGNATURE? OR DO I HAVE TO POST IT THEN LINK TO THAT POST? IF THAT'S THE CASE, HOW THE HELL DO I DO THAT o_O
    CygnusX191 and tonered like this.
  2. Sep 10, 2020 at 5:56 PM
    #4142
    Shellshock
    Iowa
    Host it on Dropbox or google drive or one of the 100 other file sharing services and create a link to it
    it’s way easier than trying to attach to posts and link to them
  3. Sep 10, 2020 at 5:57 PM
    #4143
    Mooseditty17
    AJ
    WI
    F*ck it. Here's the file if you want to try it. 04B04_Reg_Stock_THX_33 with 2D throtle tables tweaked.
    A different approach to a "performance" feeling throttle. I'll figure out how to link it later... Need to learn on my own!
    Sorry for BLOWING up the thread today. I think after the training seminars I may need a twelve step program :yay:
    #tuneraddiction
    BOMBS, CygnusX191, b3itz and 3 others like this.
  4. Sep 10, 2020 at 5:58 PM
    #4144
    Shellshock
    Iowa
    It’s all good. This is exactly why vF tuner was created and released!
    CygnusX191, wahoobie, tonered and 2 others like this.
  5. Sep 10, 2020 at 6:16 PM
    #4145
    DaveEEE
    DaveEEE Well-Known Member
    2024 Tacoma Off Road
    Hi I need some help with VF tuner s/w, I have the VF tuner s/w downloaded, I have sent my system ID in to OVtune and they sent me the master key. I have entered the master key and the the s/w came back with the system ID screen and all the buttons are grayed out along with no choices in the drop down for the interface ( Tactrix s/w is loaded). I have turned off Window security. What am I missing?
    Thanks
  6. Sep 10, 2020 at 6:17 PM
    #4146
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Hey.
    Google gives you 15gb on Drive if you have a Gmail account.
    But, sharing has changed a bit and got a bit more complex. If you want some help there, let me know.
    Of course, you can just drop the file on here like you did.
    :cheers:
    CygnusX191 likes this.
  7. Sep 10, 2020 at 6:18 PM
    #4147
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You need to send that System ID to OVT to get a REG file. It is separate from the Master Key.
  8. Sep 10, 2020 at 6:21 PM
    #4148
    Mooseditty17
    AJ
    WI
    I got a link on my signature, but it's like 3 post #s off??? right page, but wrong spot on the page! how the hell did i manage that? :rofl:
    tonered[QUOTED] likes this.
  9. Sep 10, 2020 at 6:30 PM
    #4149
    Mooseditty17
    AJ
    WI
    I figured it out!!
    Does this mean I've transitioned into an official Member?
    tonered likes this.
  10. Sep 10, 2020 at 6:56 PM
    #4150
    alegerlotz
    alegerlotz Well-Known Member
    Los Angeles
    2017 Tacoma Limited 4x4
    I did this today... hoping to get my .reg file soon.
    I bought the cable through OV as well... hoping they have them in stock so it ships soon! :fingerscrossed::fingerscrossed::fingerscrossed:
  11. Sep 10, 2020 at 7:02 PM
    #4151
    DaveEEE
    I just sent OV support the system ID for the 2nd time,to get the registration key- I just I got confused between the master key and the registration key, Thanks for your quick response
    How long does it typically take for them to turn around registration keys?
    Thanks again
  12. Sep 10, 2020 at 7:42 PM
    #4152
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    As short as a couple days. It could be a week if they're swapped. The file comes from a vendor in the UK.
  13. Sep 10, 2020 at 7:43 PM
    #4153
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If the Tactrix was available for purchase, it should be in stock.
  14. Sep 11, 2020 at 2:25 AM
    #4154
    Mooseditty17
    AJ
    WI
    What happens if I make 3D adjustments to my liking on one file. 2D adjustments to my liking on another then stack both increased values on the two different tables into one file???
    I don't see anything change in the 3d table when I upped the 2d values. Is this "stackable"? Or bad idea???
  15. Sep 11, 2020 at 2:59 AM
    #4155
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    Neither table is a direct accelerator to throttle map. The ecu uses both maps in its throttle calculation. So I expect they would be “stackable”. Without knowing the formula, best you can do is trial by error and take it slow.
    I have only modified the 2D throttle limit maps but intend to eventually modify the 3D airload cap map in the same tune. Try a tune with both modified and let us all know how it goes.
    Mooseditty17[QUOTED] likes this.
  16. Sep 11, 2020 at 3:43 AM
    #4156
    Mooseditty17
    AJ
    WI
    Thanks for the input. I'll give er a go! Have you done the smoothing Mat recommend:
    Airload control - Control Airflow
    Airload control - Expected Airflow
    I'm assuming to just do the values he had highlighted and not the entire 800-2000 range across the table?
  17. Sep 11, 2020 at 4:17 AM
    #4157
    dunlap837
    2018QSDCLBSR5
    Have not done it yet. I do not know the function of those tables so I would not go messing outside that range yet.
    I have only done shift points and throttle limits, and honestly think I could be happy without touching anything else ever again. But of course I will. I am very interested to look at the timing tables in a SFOB file.
    ihatemytruck likes this.
  18. Sep 11, 2020 at 5:05 AM
    #4158
    Mooseditty17
    AJ
    WI
    What changes did you make? What was your goal with these changes?
    Sent you a PM
  19. Sep 11, 2020 at 6:22 AM
    #4159
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    I know Mat said he was unavailable for the next few days, but I'm hoping when he gets back he will elaborate. I was wondering the same thing about smoothing out the whole thing, or just that range.
    Mooseditty17[QUOTED] and tonered like this.
  20. Sep 11, 2020 at 6:23 AM
    #4160
    ihatemytruck
    Dave
    Southern California
    I'd be interested in seeing the timing, and other changes in the SFOB file as well.
    tonered likes this.
Thread Status:
