vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Sep 12, 2020 at 7:06 AM
    #4221
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    Here ya go
    tonered likes this.
  2. Sep 12, 2020 at 7:09 AM
    #4222
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    High
    Highlight what you want changed. On the 10-key, press *. To increase by 25%, type 125 then press enter.
    tonered likes this.
  3. Sep 12, 2020 at 7:12 AM
    #4223
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    In general, how much of a percentage translates to a real world change that can be noticed?
    Mooseditty17 and tonered like this.
  4. Sep 12, 2020 at 7:26 AM
    #4224
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Thanks guys.. the smoothing function (CTRL-I) will pull down your values if you highlight cells with noticeably lower numbers in them.. just like I thought. If you watch the effects of your changes in real time on the 3D model of the map in question, you'll see what I mean. Might have to play with increasing certain areas individually..
  5. Sep 12, 2020 at 7:28 AM
    #4225
    Mooseditty17
    AJ
    WI
    I
    25% has shown to be quite a jump, and very noticeable on the 2d throttle changes I made. I personally always decrease my percentages the higher the values get. For the throttle as an example again most of what it's lacking is at the bottom. So to help smooth things out I decrease the % as I go up in values.
    mZiggy[QUOTED], MOC221_ and tonered like this.
  6. Sep 12, 2020 at 7:29 AM
    #4226
    Mooseditty17
    AJ
    WI
    I
    I watch that map every time I make a change! Helps me understand that much more what to expect.
    tonered, MOC221_[QUOTED] and Supr4Lo like this.
  7. Sep 12, 2020 at 7:29 AM
    #4227
    Supr4Lo
    Surprise, AZ
    Thanks for the tip!
    MOC221_[QUOTED] and tonered like this.
  8. Sep 12, 2020 at 7:33 AM
    #4228
    MOC221_
    Frank
    I'm really new at this, so grain of salt lolol.
    Another idea I had was to make the values in say the 650 and 800 rpm rows the same as say.. the 1k or 1.2 rows and then smooth the whole area as detailed by Mat. That'll be another file lol.
  9. Sep 12, 2020 at 7:35 AM
    #4229
    MOC221_
    Frank
    Absolutely!
    Mooseditty17[QUOTED] likes this.
  10. Sep 12, 2020 at 7:57 AM
    #4230
    Supr4Lo
    Surprise, AZ
    Worth a try, but I wonder if at those low rpms with a higher load if opening the throttle more would slow the air velocity having an inverse effect on torque.
    But for full disclosure I don't know shit about Fuc......
  11. Sep 12, 2020 at 7:57 AM
    #4231
    Mooseditty17
    AJ
    WI
    @Rafael@OVTune
    Is there an update on this? Mine won't save the changes. 25,600.78 reappears after being saved.
    tonered likes this.
  12. Sep 12, 2020 at 8:02 AM
    #4232
    Supr4Lo
    Surprise, AZ
    Same
    tonered likes this.
  13. Sep 12, 2020 at 8:02 AM
    #4233
    Mooseditty17
    AJ
    WI
    In this post you state alternatively the 2d maps can be changed... Im currently running a stacked tune with both the 3D and 2D tables modified. Is that not a good idea?
  14. Sep 12, 2020 at 8:20 AM
    #4234
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    I dunno... Mooseditty must have figured out a shortcut for that? He seems to re-flash and test approximately every two hours.
  15. Sep 12, 2020 at 8:26 AM
    #4235
    MOC221_
    Frank
    Unsure lol..
    It's not really a big deal, just gotta get through that first few miles of retarded surging/bogging etc.
    FOR SCIENCE! :cookiemonster:
  16. Sep 12, 2020 at 8:28 AM
    #4236
    Mooseditty17
    AJ
    WI
    LOL!
    Lots of gas $. I should be giving it more time for a fair assessment as well. But changes are noticable in as few as 30 minutes. Including the 10 minute idle. I'm always apprehensive on the initial drive after idle. But 5 miles or so into it, the changes start showing up. I do lots of start / stop in town driving. Mixing up Slow acceleration, hard acceleration, then a hwy drive and back to city streets. By the second round of city streets the throttle comes alive as if the learning curve has flattened. Maybe it's all in my head, but seems to work for me.
    DES2009[QUOTED], tonered and MOC221_ like this.
  17. Sep 12, 2020 at 8:46 AM
    #4237
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    No idea. I thought all shift tables were condensed in one or a few.
  18. Sep 12, 2020 at 8:51 AM
    #4238
    Mooseditty17
    AJ
    WI
    Are you ID 04B04?
  19. Sep 12, 2020 at 8:52 AM
    #4239
    Vlady
    Issy, WA
    I did put 25% up to 33 accelerator, 20 for next 2, and 10 for last for 3,4,5,6 and did a few runs. I did not notice any crazy effects. Slightly improved accelation on long inclines on 6th and 5th.
  20. Sep 12, 2020 at 8:53 AM
    #4240
    Vlady
    Issy, WA
    Yes
Thread Status:
