vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Sep 13, 2020 at 1:55 PM
    #4321
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Hot diggity damn!!! Can you post that file for me to look at please? You've just made MANY of people very happy food sir!
  2. Sep 13, 2020 at 1:58 PM
    #4322
    ForceOfG
    ForceOfG Well-Known Member
    Portland, OR
    16' DCLB 4x4 Off-Road
    5.29 Yukons Stage 2 Icons 265/70/17 OVTuned
    Certainly can! I’m out n about at the moment but later today I will share what I did.
    Mooseditty17[QUOTED] likes this.
  3. Sep 13, 2020 at 1:59 PM
    #4323
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Now we just need to find that darn table that tells it what gear to go into when shifting to 'S'. It's usually 4th, but occasionally 5th if you're really motoring along.
  4. Sep 13, 2020 at 2:02 PM
    #4324
    RushT
    North Texas
    I wonder if it would make sense to simply customize those lower limits to keep it from bogging down too much in higher gears? Say 1400 in 6th, 1300 in 5th, 1200 in 4th 1000 in 3rd, 800 in 2nd, and 600 in 1st? Something like that for example.
  5. Sep 13, 2020 at 2:10 PM
    #4325
    Frank_Zuccarini
    Frank_Zuccarini Obscure Member
    Frank
    Chicagoland
    AC-TRD-OR-4x4-Barcelona Red
    You're a pioneer and clever man. Thanks for discovering and sharing this little tid bit.
    Frank
    Mooseditty17 likes this.
  6. Sep 13, 2020 at 2:18 PM
    #4326
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Making us, or at least me, 04A61 guys jealous!
    RushT likes this.
  7. Sep 13, 2020 at 2:46 PM
    #4327
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    Can confirm. 04A61 here and super jelly. Looks like fun :D
    CAG Gonzo[QUOTED] likes this.
  8. Sep 13, 2020 at 5:47 PM
    #4328
    Mooseditty17
    AJ
    WI
    Any adjustments needed to the Torque Converter tables?
  9. Sep 13, 2020 at 5:58 PM
    #4329
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    Does ovtune let you disable the door chimes so I can leave my door open and listen to the radio in the driveway without the freaking dinging? I searched the thread but didn't see anything specific to open doors, just seat belts. I want the dash indicator to still show the door is a jar if I drive off though...
    xxTacocaTxx likes this.
  10. Sep 13, 2020 at 6:01 PM
    #4330
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    I don't think its required to make adjustments to TC tables if you adjust shift points, just that you want to from a performance point of view. I am pretty sure the ECU is smart enough to unlock for a shift regardless. But if you start raising shift points above the TC lock/unlock points, you can end up with maps telling the TC clutch to lock up when it is not ideal, unnecessarily reducing torque sent to the wheels.
  11. Sep 13, 2020 at 6:02 PM
    #4331
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Not OVTune, but Techstream probably
  12. Sep 13, 2020 at 6:07 PM
    #4332
    mZiggy
    mZiggy Honey badger
    Marc
    tonered and Shellshock like this.
  13. Sep 13, 2020 at 6:32 PM
    #4333
    NorrinRadd
    WA
    xxTacocaTxx and mZiggy[QUOTED] like this.
  14. Sep 13, 2020 at 6:41 PM
    #4334
    ForceOfG
    Portland, OR
    I did not adjust the TC tables so it still unlocks/locks as normal. File that am using should be linked here. IF anyone decides to use this tune its OVTunes Premium octane mapping and I've made adjustments to throttle sensitivity, throttle limits, some shift point changes, ACIS, and the crown jewel Gearlock with ECT.
    As far as limiting the gears above a certain RPM to me it seems completely do-able you just need to modify the minimum values on upshift tables but you'll need to know at what speed. Say you want to limit 6th to above 1500 RPM, thats roughly 60 MPH so that would be your minimum value at zero accelerator angle in the table. The thing I haven't figured out yet is if the speeds in the shift tables are truly in kph or not. For example, the table for the ECT 4 to 5 shift is showing that it shouldn't upshift until 59 kph (36ish mph) at least but in the real world its actually 52 mph for me. Maybe the tire ratio table has something to do with that?
  15. Sep 13, 2020 at 7:45 PM
    #4335
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    I believe Mat said before it is actually MPH, but I can't remember for sure.
  16. Sep 13, 2020 at 7:59 PM
    #4336
    Idahotaco88
    Idahotaco88 Well-Known Member
    Steven
    2017 black AC OR
    Kings 2.5 with adjusters, icon rxt stage 2. SCS stealth blue on 35s
    Anyone playing with dump tube tunes yet ?
  17. Sep 13, 2020 at 8:00 PM
    #4337
    ihatemytruck
    Dave
    Southern California
    I forgot to ask, are your files regular or premium fuel?
  18. Sep 13, 2020 at 8:55 PM
    #4338
    ForceOfG
    Portland, OR
    I think I came close to figuring it out! It is in MPH but the speeds are multiplied by a percentage to get the actual shift point, probably based on what ever tire diameter you input.
    I put in a 32.5" diameter and my shift speeds are all about 13% lower than what VFtuner is showing. IE the 4 to 5 upshift is 58.86 in VFTuner. If you multiply that by .87 gets to be around 51.2 MPH as my shift point. Which it just about is and same with all the other shift point formulas for ECT it seems. Did a test and set one up-shift speed and one down-shift speed for all the ECT shift tables so that regardless of pedal input it would shift at only one speed per gear so I can compare the real world speed to the table speed and I repeatedly got the same numbers.
  19. Sep 13, 2020 at 9:39 PM
    #4339
    Millerious
    Millerious Member
    I noticed a while back that the "drive train control - gear size" values are about that percentage lower than what they should be, ie 4th gear is at 0.83:1 instead of 1:1. 1st through 6th are all that way... about 20% lower than they should be, actually. Maybe it could be these settings vs the tire size?
    I've been too nervous to change them, but I'm going to test a file with those values changed to what they should be and see what happens. I've got everything else pretty dialed in for my preferences. Maybe that will push those shift points up? I've already bumped them all up about 25%, but I also notice the real life shift points are still lower than what I set them at.
  20. Sep 13, 2020 at 10:02 PM
    #4340
    Millerious
    Millerious Member
    ya, don't try that. It had the opposite effect I was looking for. Shift points all went down. I got a few miles out and flashed back to where I was before that change.
Thread Status:
