vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Sep 14, 2020 at 1:31 PM
    #4381
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Rodger that.
  2. Sep 14, 2020 at 1:34 PM
    #4382
    Mooseditty17
    AJ
    WI
    Will our prior made tunes have to be redone from scratch with this update, or can we open them with updated VF, and carry on where we left off?
    jomopdx and ihatemytruck like this.
  3. Sep 14, 2020 at 1:38 PM
    #4383
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    So far the numbers haven’t made sense. The tire size is half the total tire height from what I could guess but .80 made no sense for diff size. Updated VF and now it reads the almost correct gear size for 4.88 (4.80) but gear ratios, although they have changed with the VF update are still off. If they are suppose to be accurate to real world numbers then 5th gear is set up to 6th gear ratios. If there’s a separate number that need to be factored in then that’s fine but we should be given that secret code not have to guess things.
    That’s been the problem so far.... I don’t know and I have absolutely nothing to reference to find the answers. It’s a matter of change values and test and in regards to this particular issue (gear size and stuff) it’s not a problem but when it starts to get into fuel, spark control and other critical parameters I think guessing and testing could be really dangerous.
    I know this sounds like ungrateful bitching and it is a bit of complaining but I do realize that this is a great and powerful tool we have in our hands and maybe just a little guidance would go a LONG way to productivity at this point. It feels like OV just threw a hand grenade into the monkey exhibit at this point :rofl:
    And no, I’m not angry or anything. I totally respect and appreciate what OV has done.
    Tharris242 likes this.
  4. Sep 14, 2020 at 1:43 PM
    #4384
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Awesome, thanks!
    wahoobie, tonered and Mooseditty17 like this.
  5. Sep 14, 2020 at 1:46 PM
    #4385
    ihatemytruck
    Dave
    Southern California
    Wondering the same thing. If it's just a glitch in the software, or are the actual tunes going off those numbers.
    inksin likes this.
  6. Sep 14, 2020 at 1:51 PM
    #4386
    OVTune
    OVTune Well-Known Member
    OVTune
    you can just open it and continue where you left off.
    There is a internal rounding error in vFT on the hundredth decimal place in VFT on certain tables. I am working on that right now.
    most maps are what they should be, fuel,spark,vvt, etc.
    Everything will be sorted very soon, with accurate representations.
    Also when you click the info button on the tables it will include information about the table. You'll see, that is all being updated. So you can click a button and explains exactly what the map does
    BOMBS, wahoobie, Stormpeacock and 5 others like this.
  7. Sep 14, 2020 at 2:02 PM
    #4387
    ihatemytruck
    Dave
    Southern California
    The info button telling what it does will be awesome. Definitely will speed up the learning and understanding curve!
    Stormpeacock, inksin and tonered like this.
  8. Sep 14, 2020 at 2:10 PM
    #4388
    Shellshock
    Iowa
    YESSSSSS :bananadance::jellydance::kona:
    hr206, Mooseditty17, tonered and 2 others like this.
  9. Sep 14, 2020 at 2:15 PM
    #4389
    ihatemytruck
    Dave
    Southern California
    You said it way more colorfully than I did lol
  10. Sep 14, 2020 at 2:16 PM
    #4390
    Mooseditty17
    AJ
    WI
    Sweet!!!!!:bananadance::dancingbacon::jellydance::kona::locked::taco:
    wahoobie, Stormpeacock and tonered like this.
  11. Sep 14, 2020 at 2:18 PM
    #4391
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    IBTL? Put that on the Dev thread. :rofl::rofl:
    Shellshock likes this.
  12. Sep 14, 2020 at 2:19 PM
    #4392
    Mooseditty17
    AJ
    WI
    I have no idea what that means... He looked like a happy guy. And I'm happy now :broccoli:
    tonered[QUOTED] likes this.
  13. Sep 14, 2020 at 2:25 PM
    #4393
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Hahahaha! In Before The Lock.
    :locked: is a good one to post in a Friday thread just before the mods nuke it. It is usually 100% happiness until that happens.
    :anonymous:
  14. Sep 14, 2020 at 4:28 PM
    #4394
    ForceOfG
    ForceOfG Well-Known Member
    Portland, OR
    16' DCLB 4x4 Off-Road
    5.29 Yukons Stage 2 Icons 265/70/17 OVTuned
    So I went out and ran some tests to learn a bit more about how each shift map is used. I ran through 2wd/4wd/S-mode only/used the different traction button settings and without a doubt the only tables that changed anything for me were the first primary shift tables. The others did absolutely nothing on my neighborhood strolls and their was a clear indicator the the first table had changed shift points (I could not shift above 2nd gear).
    Haven't tried the acceleration shift tables and I have not tried 4lo yet but I feel one map may be dedicated to that...
    Millerious and ihatemytruck like this.
  15. Sep 14, 2020 at 5:53 PM
    #4395
    OVTune
    OVTune
    New version will be released this week.
    Updated map naming to some tables
    Updated scaling for several tables - including VVT
    Updated info table for map help
    and more.
    Version will be 1.2.5.0
    you can check your version by clicking "about" in vF Tuner.
    New tables will include:
    throttle limiters
    Evap / purge solenoid control
    per cylinder fuel compensations
    and more.
    Right above the DOWNLOAD button on the main page will have the current version info
    Glenn_R, cdoghump, MOC221_ and 11 others like this.
  16. Sep 14, 2020 at 6:01 PM
    #4396
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    So easy even a "Caveman" can do it! I like it! Nice job Mat!
    Mooseditty17 and ihatemytruck like this.
  17. Sep 15, 2020 at 6:11 AM
    #4397
    OVTune
    OVTune
    We have found speed limiter control
    cruise control minimum speed 1
    cruise control minimum speed 2
    and more.
    will be included in latest vF Tuner.
    BOMBS, Stormpeacock, go2cnavy and 9 others like this.
  18. Sep 15, 2020 at 6:40 AM
    #4398
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    @OVTune - You said this platform will have years of improvements ahead and you are delivering on that. Thanks for your continued research to the tuning options!
  19. Sep 15, 2020 at 6:59 AM
    #4399
    Mooseditty17
    AJ
    WI
    Nice!!!! Keep up the good work boys!
    ihatemytruck, tonered and wrightme43 like this.
  20. Sep 15, 2020 at 7:31 AM
    #4400
    OVTune
    OVTune
    We will also be including several cruise control tables.
Thread Status:
