vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Sep 15, 2020 at 7:35 AM
    #4401
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    This is not a serious request, but someone who speaks American and understands drivability, it would be nice if you rewrite whatever code/logic that cruise control uses to function ‘normal’. I remember driving years ago using cruise control often on highways and never experienced what the Tacoma does on highway driving. The second gen I had sucked as well and was bone stock. For some reason it always seemed to drop two gears instantly and would hold that gear for a long time after cresting a hill and then going on a flat or even downhill. So I’ve not used cruise control since 2015!
  2. Sep 15, 2020 at 7:37 AM
    #4402
    Shellshock
    Iowa
    pretty sure thats already being worked on
    edit: patch coming. see next post.
    ihatemytruck, wahoobie and tonered like this.
  3. Sep 15, 2020 at 7:37 AM
    #4403
    OVTune
    OVTune Well-Known Member
    OVTune
    we have a patch planned for cruise control that simplifies everything and will be in vF Tuner. But stock functions will be released first
    BOMBS, Mooseditty17, lapoltba and 4 others like this.
  4. Sep 15, 2020 at 7:51 AM
    #4404
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Definitely awesome to continue to have more options with vFtuner
    Mooseditty17, mZiggy and tonered like this.
  5. Sep 15, 2020 at 8:10 AM
    #4405
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    New throttle limiter tables..
    Will this be related to the Air Load tables you showed us how to tweak, or something else?
    Also, can anything to do with Rev Hang or DFCO (1st gear) be squeezed into this update?
    iexc and tonered like this.
  6. Sep 15, 2020 at 8:15 AM
    #4406
    OVTune
    OVTune
    it's the 1rst gear 2wd, 4h, 4l tables.
    I'll check what I can regarding rev hang / dfco
    Egnaro, wahoobie, tonered and 2 others like this.
  7. Sep 15, 2020 at 8:17 AM
    #4407
    MOC221_
    Frank
    There's another layer to this throttle limiting fuckery? Holy shit I thought I was doing good with modding the air load tables.. that alone made a difference!
    Thanks a bunch Mat, waiting 5 minutes for the revs to drop is bs lol
    ihatemytruck, Supr4Lo and tonered like this.
  8. Sep 15, 2020 at 8:17 AM
    #4408
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It's an onion about the size of the Taco.
    inksin, ihatemytruck, Supr4Lo and 3 others like this.
  9. Sep 15, 2020 at 8:18 AM
    #4409
    MOC221_
    Frank
    IKR?
    Jesus.
    tonered[QUOTED] likes this.
  10. Sep 15, 2020 at 8:19 AM
    #4410
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :rofl:
  11. Sep 15, 2020 at 8:22 AM
    #4411
    MOC221_
    Frank
    No we're getting somewhere!
    :burnrubber:
    tonered likes this.
  12. Sep 15, 2020 at 8:27 AM
    #4412
    MOC221_
    Frank
    If we can just get the fuel to come back on around 800-900 during full lift like it does in 2nd.. oh boy. Gimme
    tonered likes this.
  13. Sep 15, 2020 at 8:30 AM
    #4413
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    Might the adaptive cruise control following distances be buried in there somewhere?
    PhogDog likes this.
  14. Sep 15, 2020 at 9:04 AM
    #4414
    Shellshock
    Iowa
    Not that this is super critical but something i noticed today
    There's a typo in the credit unlock screen - Whould
    wahoobie likes this.
  15. Sep 15, 2020 at 9:05 AM
    #4415
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Whould is good as the 2Lo Witch. :rofl::rofl:
    :cheers:
    b3itz and wahoobie like this.
  16. Sep 15, 2020 at 9:09 AM
    #4416
    Wolfkinteeth
    Wolfkinteeth Member
    Derrek
    Ohio
    2016 4x4 AT offroad
    Kruiser 4.0, cold air intake, flow through exhaust.
    Will (is) there (be) control for deceleration fuel cut off?
    MOC221_ likes this.
  17. Sep 15, 2020 at 9:10 AM
    #4417
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Last couple of days I was comparing 2 files - one with changes to throttle for normal gears, other with changes to 3D airload (3 tables) only. Bumped to 25% and smoothed out those 2 tables.
    Both drove nicely, but changes to airload tables have +/-.
    on low rpms and 40 mph roads, the truck goes to 5th/TC locked and creates a slight TC shudder effect
    -the tranny smoothly downshifs under a slight pressure on the accelerator, behaves like "normal" AT.
    -Mpg went up by a few decimals.
    -throttle responsiveness through all gear and engine loads.
    But for now I'm going back to play with D2 tables until I get more knowledge on airload tables.
    GPatriot and inksin like this.
  18. Sep 15, 2020 at 9:10 AM
    #4418
    MOC221_
    Frank
    Mat said he is looking into it for us.
    On M/T, it's already been altered above 1st gear.
    Don't know about slushbox.
    Wolfkinteeth[QUOTED] and tonered like this.
  19. Sep 15, 2020 at 9:57 AM
    #4419
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    Sounds like you can adjust the 5th gear shift and TC tables and eliminate your negative?
  20. Sep 15, 2020 at 10:31 AM
    #4420
    ForceOfG
    ForceOfG Well-Known Member
    Portland, OR
    16' DCLB 4x4 Off-Road
    5.29 Yukons Stage 2 Icons 265/70/17 OVTuned
    @OVTune I was wondering if you'd be able to give me a real brief overview of how the intake timing tables work? From research I know that we have the VVTI-iW on the intake cams which I believe gives us up to 80 degrees of advance on the intake valves. However it looks like its limited to 60 in the tables. I was also curious how the tables work. It looks like at idle and coasting with foot off the pedal the intake advance is 30 degrees which is also not reflected in the intake tables I have.
Thread Status:
