vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Sep 15, 2020 at 10:34 AM
    #4421
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Those are speed related. I think TC shudder is more torque/load dependent.
  2. Sep 15, 2020 at 10:45 AM
    #4422
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    TSAVO, xxTacocaTxx, Supr4Lo and 2 others like this.
  3. Sep 15, 2020 at 10:50 AM
    #4423
    OVTune
    OVTune Well-Known Member
    OVTune
    cam timing tables are about to be updated too,
    but there is >
    base cam timing tables
    high speed cam timing angle
    high load threshold
    idle cam timing
    etc
    ForceOfG[QUOTED] likes this.
  4. Sep 15, 2020 at 10:58 AM
    #4424
    Vlady
    Issy, WA
    I hope one of them has a clue to rpms drop in 3rd..
  5. Sep 15, 2020 at 10:58 AM
    #4425
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    If you’re problem is in 5th gear with TC locked at this speed, why not just move the TC lock curve or gear shift curve up to run 5th unlocked or in 4th? 40 mph is pretty low for 5th gear imo.
  6. Sep 15, 2020 at 11:01 AM
    #4426
    OVTune
    OVTune
    VVT angle changing, by itself, cannot make the crank spin 400 rpm slower. it defies the laws of physics.
    Also, you shouldn't use airload tables for trying to modify the torque converter.... use the torque converter tables.
    BOMBS, ihatemytruck and tonered like this.
  7. Sep 15, 2020 at 11:02 AM
    #4427
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :rofl:
    But what about that new adjustable length timing chain?
    :stirthepot:
    ihatemytruck likes this.
  8. Sep 15, 2020 at 11:04 AM
    #4428
    Vlady
    Issy, WA
    Could you help investigate it then? It is above our pay grade. That's is only flaw at the moment.
    Let me know what you need.
  9. Sep 15, 2020 at 11:05 AM
    #4429
    OVTune
    OVTune
    I can't investigate it without data that can consistently replicate it happening, with all variables. I know you say it happens when intake VVT drops, but I need to see everything. not screenshots of the data. Send me the logs (use techstream to convert to CSV).
  10. Sep 15, 2020 at 11:22 AM
    #4430
    ForceOfG
    ForceOfG Well-Known Member
    Portland, OR
    16' DCLB 4x4 Off-Road
    5.29 Yukons Stage 2 Icons 265/70/17 OVTuned
    I've done a few logs and I cant quite replicate your scenario but there are situations where my RPM drops 150-200 as well mainly in straight line moderate acceleration and to me it looks like its the ignition timing dropping drastically. Load goes up about 30-40%, and ignition timing drops anywhere from 15 to 30 degrees, at the same RPM right after a 2 to 3 upshift. Still looking in to it, would love to see the additional tables.
  11. Sep 15, 2020 at 11:24 AM
    #4431
    OVTune
    OVTune
    If the RPM is happening *as a shift* is about to occur, then it may be the torque reduction for shifting tables... which you guys currently don't have in vF Tuner.
    but then at the same time, rpm will drop when it shifts..
  12. Sep 15, 2020 at 11:33 AM
    #4432
    Vlady
    Issy, WA
    Thats the first thing I looked, but there is no shifting going on prior,during and after the event. Sending log shortly
  13. Sep 15, 2020 at 11:37 AM
    #4433
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    Rubber Band Mod
    tonered[QUOTED] likes this.
  14. Sep 15, 2020 at 11:39 AM
    #4434
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :D When timing belts aren't just right.
    I know what this engine needs, a three mode TC on the front side also? :bananadead:
  15. Sep 15, 2020 at 11:43 AM
    #4435
    SpeySquatch
    2016 TRD OR DCSB
    Anyone mess with 04B04 4.88 33” files besides alternator changes?
  16. Sep 15, 2020 at 11:50 AM
    #4436
    Saeros
    Saeros #dealermole
    Canada, Eh!
    2022 Venza Limited
    I know I have sent you about 2 logs in the past regarding this issue. You were always confident in being able to fix it saying it was a shift point thing. I do remember seeing the drop in VVT angle as well and mentioned it then but I am assuming the computer is adjusting vvt angle as a result of other things happening, ie the RPM changing due to torque converter stuff or whatever is going on in order to compensate????
  17. Sep 15, 2020 at 12:14 PM
    #4437
    Vlady
    Issy, WA
    19628 submitted. 2.0 b04 final Jun 2020 release.
    BTW, I don't see the throttle reduction at the event I specified in the ticket. The throttle position (deg) is advancing during the drop..
    Thanks.
  18. Sep 15, 2020 at 12:15 PM
    #4438
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    @Mooseditty17 and @ForceOfG have both put out files to try with various modifications. to make it work for 4.88 and 33s I believe all you need to do is just modify the drivetrain control values for tire size and diff1 and diff2. That's how I've been doing it so far and nothing blew up yet
  19. Sep 15, 2020 at 1:40 PM
    #4439
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    still nothing for decatted dump tubes?
  20. Sep 15, 2020 at 1:58 PM
    #4440
    OVTune
    OVTune
    There will be 2 tables for dump tubes (both catted and uncatted). if you have dump tubes just set the tables to 0 in your file
    su.b.rat likes this.
Thread Status:
