vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Sep 16, 2020 at 6:59 AM
    #4481
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It was posted in this thread, I believe?
    It was probably the last time that OVT mentioned 04B14?
    b3itz[QUOTED] likes this.
  2. Sep 16, 2020 at 7:00 AM
    #4482
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    Found it - thank you! I'm sure my bad TOB will love this testing :)
    tonered[QUOTED] likes this.
  3. Sep 16, 2020 at 7:03 AM
    #4483
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Cool!
    No different than normal driving. I really doubt that it would grenade for a very long time.
  4. Sep 16, 2020 at 7:18 AM
    #4484
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    ??? a little help to a dumb question. When you update to the newer version of VFTuner Software do you "un-install the app" or simply download over the existing? Anyone? TIA
  5. Sep 16, 2020 at 7:25 AM
    #4485
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Has there been any feedback on this?
    I'm adding the AGM tweaks to it now, then i'll flash it.
    Maybe it'll fix my throw out bearing so i don't have to drop my transmission this weekend. Can you tell i'm salty?
    Also - i'm currently running b14 2.0 sfob 93 prem. Will this 2.0 test tune include sfop and the high octane? i need ALL OF IT :)
    tonered likes this.
  6. Sep 16, 2020 at 7:25 AM
    #4486
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    In this thread, back in May it was just overwrite, then in June it was you must uninstall - as found by searching "uninstall" from OVTune posts. It likely depends on "what" is being updated as to the required process, but I would certainly expect that a full uninstall would always work. It just might be overkill in "some instances we do not really know".
    tonered likes this.
  7. Sep 16, 2020 at 7:31 AM
    #4487
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Sorry. I just woke up pissed. Thanks for the feedback.
    ihatemytruck[QUOTED] and inksin like this.
  8. Sep 16, 2020 at 7:32 AM
    #4488
    GoldenBrew
    Golden, Colorado
    Thanks! trying to get it loaded for a friend and thinking it may be best to simply wait for the new version and go from there. Install steps 1-3 done but not #4 - I think that is the problem.
  9. Sep 16, 2020 at 7:36 AM
    #4489
    wahoobie
    chris
    Suffolk, VA
    @OVTune - any thoughts on the developer adding in support for in-app version checking to pull the releases as they post. Most of my work software does that and even lists the release notes link. Very handy to alert the users of a new update and get it in everyones hands so you don't get bombarded with tickets for things in the app that are fix/enhanced over time.
  10. Sep 16, 2020 at 8:13 AM
    #4490
    Kleach18
    Kleach18 Well-Known Member
    2016 TRD Offroad
    After making the alternator charging changes is there a way to see what the alternator is charging via OVT data logger in real time?
  11. Sep 16, 2020 at 8:15 AM
    #4491
    OVTune
    OVTune Well-Known Member
    OVTune
    select control module voltage
    ihatemytruck and b3itz like this.
  12. Sep 16, 2020 at 8:15 AM
    #4492
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Yeah, it's under Select PIDs > Control Module voltage
  13. Sep 16, 2020 at 8:16 AM
    #4493
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Meh - Jynx!
    But use a voltmeter to be safe. Read it at the battery
  14. Sep 16, 2020 at 8:45 AM
    #4494
    ForceOfG
    ForceOfG Well-Known Member
    Portland, OR
    16' DCLB 4x4 Off-Road
    5.29 Yukons Stage 2 Icons 265/70/17 OVTuned
    Yup I noticed that as well. It looks more pronounced than it is, it only dropped by about 2% but thinking about it again it shouldn't have done that anyway and just keep the throttle consistent. :annoyed:
  15. Sep 16, 2020 at 8:54 AM
    #4495
    Kleach18
    2016 TRD Offroad
    Maybe I'm missing a setting I'm supposed to change. I used the .VFT file Ovtuning posted back in this thread somewhere to edit the 4b04 tune that a member posted a few pages back. Highest I'm seeing the control module voltage PID go is 14.1v.. Did I miss changing a setting somewhere besides the "alternator constant" map definitions section?
  16. Sep 16, 2020 at 8:55 AM
    #4496
    Shellshock
    Iowa
    Did you change the duty %?
  17. Sep 16, 2020 at 8:58 AM
    #4497
    Kleach18
    2016 TRD Offroad
    Yeah I opened the file for the most recent 2.0 a member posted a few pages back and also opened the alternator file OVTuning posted and compared the alternator constant files and made all the changes.
  18. Sep 16, 2020 at 9:00 AM
    #4498
    Kleach18
    2016 TRD Offroad
    What was the final number for the "duty cycle" everybody decided on was best while running a Northstar AGM 27F?
    Thinking maybe I pulled on older file that was updated multiple times. Lots of pages to search through
  19. Sep 16, 2020 at 9:33 AM
    #4499
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    I used the settings from Post #737 Only I upped My ECT from 93 to 94. That gave me 14.5V at the battery using a volt meter. I also have a 24F battery not a 27F. Maybe start with with that and you can always bump up the ECT Value to increase voltage.
  20. Sep 16, 2020 at 9:34 AM
    #4500
    Shellshock
    Iowa
    Mine is set at 94 and i increased the duty cycle by 20%
    Kleach18 likes this.
Thread Status:
