vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Sep 17, 2020 at 8:38 AM
    #4541
    Redline870
    Redline870 Well-Known Member
    2018 Cement Tacoma TRD Off-Road
    Have you changed your spark plugs? I had misfires at less than 30k miles... turns out Toyota left my plugs loose.
    GPatriot and Shellshock like this.
  2. Sep 17, 2020 at 9:26 AM
    #4542
    GPatriot
    GPatriot Well-Known Member
    Cincinnati, Ohio
    2016 Black Tacoma Sport 4x4 V6 DCSB AT Loaded
    KDMaxPro 10.0, OME 2" Med Duty lift, RCI Sliders, RoofRack, Skid Plate, etc.
    Because of you guys mentioning having loose spark plugs I went ahead and had mine replaced a couple weeks ago at 56k miles. It definitely runs better and the power is more consistent.
    I'm thinking mine were loose too.
    johntoyota and Redline870 like this.
  3. Sep 17, 2020 at 9:28 AM
    #4543
    Redline870
    It made a very noticeable difference on my truck as well
  4. Sep 17, 2020 at 9:32 AM
    #4544
    OVTune
    OVTune Well-Known Member
    OVTune
    mine weren't even finger tight on my 2017
    BOMBS, Mooseditty17, b3itz and 2 others like this.
  5. Sep 17, 2020 at 9:37 AM
    #4545
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There is speculation here between bad factory torque and potential lean running in the Stock tune causing this. Do you have any idea here?
    Thankfully, all of mine were good.
    Also, how many 4Hi miles do you have now? :D
  6. Sep 17, 2020 at 9:39 AM
    #4546
    OVTune
    OVTune
    Hard to say, but if I had to guess, they were loose from the factory. Not sure how it running lean would make all 6 equally loose. Although I did have one of them, I believe it was specifically cylinder 6, that was so loose I'm surprised my engine didn't feel like it was running on 5 cylinders.
    My truck is torn apart right now for pictures / install guide on the oil pan.
    I'm also putting it back together with the larger 900+cc injectors and setting up a tune for 15-20+psi.
    Mainly just to see how far the drivetrain goes before it really breaks. I wlll be very surprised if 4Hi survives 20psi launches
    BOMBS, inksin, Mooseditty17 and 6 others like this.
  7. Sep 17, 2020 at 9:43 AM
    #4547
    Redline870
    Cylinder 6 was very loose on mine as well. That’s the one that had a lot of blow by residue on the coil
  8. Sep 17, 2020 at 9:44 AM
    #4548
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks! Someone posted an article where it was noted that an effect of lean running (don't want to say the word :rolleyes: ) could cause plugs to back out. I tried searching for that post but couldn't find it.
    All six of yours were loose? Wow! I think the most noted in other threads was two really loose with some under torqued.
    :hattip: Just curious.
    Some seriously nice parts in the TT kit.
  9. Sep 17, 2020 at 9:46 AM
    #4549
    Shellshock
    Iowa
    I had one that was loose - not falling out like some peoples, just like finger tight at best. I think it was the middle one on the drivers side, whatever number that is
    tonered[QUOTED] likes this.
  10. Sep 17, 2020 at 9:46 AM
    #4550
    OVTune
    OVTune
    yea all 6 were pretty loose but cyl 6 was practically just sitting in there hanging out not even in the head it was so loose. (not literally).
    I think it's the opposite.
    The loose plug will create a misfire condition.
    Misfires are notoriously read as "lean" on an O2 sensor.
    So the loose plug is creating the lean condition.
  11. Sep 17, 2020 at 9:52 AM
    #4551
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Again, wow! Hopefully, folks will get in there and check them. The left side wasn't as bad as I had thought it was going to be, with the plenum left on.
    Good stuff. That makes a lot of sense.
    Thanks!
  12. Sep 17, 2020 at 10:17 AM
    #4552
    GPatriot
    Cincinnati, Ohio
    Am I guessing correctly that loose plugs aka misfire condition could also give me that "bumpy road" feeling? There's one section of uphill I drive home on everyday and it did there, every time. That section is a little bumpy too so I was so conflicted :annoyed:
    To explain it better it just felt like inconsistent power. I'm pretty sure it's gone now.
  13. Sep 17, 2020 at 10:26 AM
    #4553
    OVTune
    OVTune
    No, after testing, testing, and more testing, I think the actual cause of this is the exhaust cam.
    From 1000 to about 2000 rpm, depending on load, the exhaust cam will go into a maximum retard state (for maximum overlap) and it causes this. I am able to consistently replicate it on my truck.
    I've wrote a patch to simply exhaust cam tuning, but it's not out yet.
    diyman, 92ehatch, MOC221_ and 5 others like this.
  14. Sep 17, 2020 at 10:30 AM
    #4554
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    @OVTune - Thank you, can't wait for the patches......we need stinkin patches!
    Mooseditty17 and tonered like this.
  15. Sep 17, 2020 at 10:31 AM
    #4555
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nice! Thanks.
  16. Sep 17, 2020 at 10:34 AM
    #4556
    OVTune
    OVTune
    if you saw how Toyota controls the exhaust cam.... why? why? ...why? why???
  17. Sep 17, 2020 at 10:37 AM
    #4557
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    FTFY:
    :rofl::rofl:
    RangerComa, MOC221_, wahoobie and 5 others like this.
  18. Sep 17, 2020 at 11:05 AM
    #4558
    InternationalHarvester
    InternationalHarvester VF Pro Licensed, KDMAX Authorized Vendor
    Sierra Nevada
    2017 TRD DC LB OR 4x4
    KDMAX Tooooned
    Haven’t checked plugs. I changed the crankshaft position sensor, but didn’t affect or effect or whatever the misfire count. Truck runs fine on newest tune.... thought maybe it was tune related since it was the only thing that changed at the same time the misfires all but went away. Truck also ran fine on stock tune. I’ll check the spark plugs though. Thanks for the advise!
    Added note: truck actually has fewer misfires on newest iteration of tune than it did stock. Nice work Mat!!
  19. Sep 17, 2020 at 11:32 AM
    #4559
    Redline870
    Mine also ran better with the tune. Once I changed the plugs it ran WAY better. I also didn’t get any more spark knock.
  20. Sep 17, 2020 at 12:23 PM
    #4560
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I wanna go find some loose plugs now. Probably won’t though.
    tonered likes this.
Thread Status:
