vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Sep 19, 2020 at 7:51 PM
    #4861
    Shellshock
    Iowa
    @MOC221_ and I did the first gear ones but our trucks are MT, so YMMV
    It lets you get 100% throttle in 1st instead of knee capping you at 25% or whatever they are set to
    MOC221_ and Mooseditty17[QUOTED] like this.
  2. Sep 19, 2020 at 7:52 PM
    #4862
    OVTune
    OVTune Well-Known Member
    OVTune
    Look at the map and think about it.
    if you floor it, it will reference this map, and give you the amount of throttle this map says, at each rpm point.
    If you floor it, and you actually WANT full throttle at 1000, 4000, 6000 RPM, then you need to set them to 100.
    If you set it to 50, then the maximum throttle you can have (if you floor it) is 50.
  3. Sep 19, 2020 at 7:53 PM
    #4863
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    With 1st gear already being so strong, what are you guys even getting out of having 100% throttle available? 1st gear as it is is nuts.
    JBD81 and MOC221_ like this.
  4. Sep 19, 2020 at 7:54 PM
    #4864
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
  5. Sep 19, 2020 at 7:54 PM
    #4865
    Shellshock
    Iowa
    More nuts lol
    MOC221_, wahoobie and ihatemytruck like this.
  6. Sep 19, 2020 at 7:55 PM
    #4866
    OVTune
    OVTune
    I'd try unplugging the battery for a little longer. I also noticed your battery voltage was 12.8+? are you using a battery charger hooked up?
    Mooseditty17 likes this.
  7. Sep 19, 2020 at 7:55 PM
    #4867
    Shellshock
    Iowa
    It pulls smoother. Before it felt like as you accelerated, it bumped up as it sped up. Which makes sense since it was limited in diff spots.
    JBD81, wahoobie, MOC221_ and 2 others like this.
  8. Sep 19, 2020 at 7:55 PM
    #4868
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    That makes sense. Thank you for the information! I'm trying hard to understand this. Just wasn't sure if this map was like the ones labeled throttle limits normal 1-6, the one you told me NOT to change the low limits to 100 because I'd essentially have an ON/OFF throttle. Don't necessarily want that :D
    especially unexpectedly.
  9. Sep 19, 2020 at 7:57 PM
    #4869
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    I did at one point because it was getting low, so I tried it with it hooked up and without.
    I may just let it sit unplugged overnight. I have to get up at 330am and it’s 10
  10. Sep 19, 2020 at 8:06 PM
    #4870
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    do you recommend trying a different file? Or does that even matter?
  11. Sep 19, 2020 at 8:07 PM
    #4871
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Deez nuts
    Shellshock[QUOTED] likes this.
  12. Sep 19, 2020 at 8:07 PM
    #4872
    mZiggy
    mZiggy Honey badger
    Marc
    Okay, the smoothing is definitely valuable. Nice.
    ihatemytruck likes this.
  13. Sep 19, 2020 at 8:09 PM
    #4873
    mZiggy
    mZiggy Honey badger
    Marc
    I had a soft brick last summer off a test map. Couldn't flash anything. Unplugged my battery and held my cables together for a couple mins and that worked.
  14. Sep 19, 2020 at 8:14 PM
    #4874
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    ah I have it disconnected.. got them touched now.
    mZiggy[QUOTED] likes this.
  15. Sep 19, 2020 at 8:14 PM
    #4875
    Shellshock
    Iowa
    Oh right. I forgot about this trick!
    mZiggy[QUOTED] and Tac0Tic0 like this.
  16. Sep 19, 2020 at 8:28 PM
    #4876
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    gonna try to flash it early tomorrow morning. If it don’t work, I’ll be sad.
  17. Sep 19, 2020 at 10:13 PM
    #4877
    trd pr0
    trd pr0 Well-Known Member
    Geary
    san francisco
    Tacoma trd offroad cement
    AR15 knobs for the radio, ovtune, bigmouth dump tube by ovtune, manual, ripp supercharger coils, trd drop in air filter, rock sliders , trd skid, fuel tank skid ,rear shock skids, hids, meso customs
    Me too so far so good
  18. Sep 19, 2020 at 11:11 PM
    #4878
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    What if OVTune is Willy Wonka and this whole tuning process is like his chocolate factory? MTs and 04B04 got the Golden Ticket and now he is watching us to see who is gonna figure this whole thing out and be given a job to work with OV to take over the company when Mat flies away in his TT Tacoma....
    TWTaco and CAG Gonzo like this.
  19. Sep 20, 2020 at 2:31 AM
    #4879
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    Well, the battery sat unplugged all night. Just tried it again... no luck. Though the voltage was low, jumped it off then tried it again.. nothing.
    @OVTune do I need to send my ECU to you?
    I may also download the software to another computer and try?
    who knows
    :annoyed:
    I did let a friend borrow my cable to flash his tundra. I don’t see how that would be an issue. Just trying to think of anything I’ve done different.
    I’m sad.
    MOC221_ likes this.
  20. Sep 20, 2020 at 4:08 AM
    #4880
    OVTune
    OVTune
    Try a different USB, and check your OBD plug for loose pins.
Thread Status:
