vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Sep 21, 2020 at 4:51 AM
    #4921
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Did you try a new or different battery?
  2. Sep 21, 2020 at 6:12 AM
    #4922
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    this battery is a few months old, optima yellow top. But I’m going to borrow a cable today and if that doesn’t work, I’ll swap the battery with the 4runners battery.
  3. Sep 21, 2020 at 6:26 AM
    #4923
    Mooseditty17
    AJ
    WI
    Good luck man!
    Tac0Tic0[QUOTED] likes this.
  4. Sep 21, 2020 at 6:29 AM
    #4924
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    i really hope it’s the damn cable. I did let a guy borrow it, he may have not been careful with it.
  5. Sep 21, 2020 at 6:30 AM
    #4925
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    how would one go about modifyiig this stock gear tune to a 4.88 tune? ??Simple math ratio of gearing 4.88/3.91 or ?
    johntoyota likes this.
  6. Sep 21, 2020 at 6:39 AM
    #4926
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    If your OBDII is fucked, loose pins or whatever, try to get the dealer to replace it? Say you were trying to run diagnostics and couldn't connect, had intermittent connection, whichever.
  7. Sep 21, 2020 at 6:41 AM
    #4927
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    the problem though.. id have to tow it.
  8. Sep 21, 2020 at 7:05 AM
    #4928
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    What is your file name? I recently had the same error as you trying to flash 1-05 89663 04A61.vft Swapped the file name to 89663 04A61 1-05.vft and had success. Not sure if it was coincidence. The program may need to see the calibration ID first thing in the file name to work?
  9. Sep 21, 2020 at 7:25 AM
    #4929
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    the only thing I added was dump tubes to the end of it.
    I tried one that wasn’t modified and the stock file
    I have @DES2009 cable on the way to me.
    Going to try the following
    - different cable
    - different battery
    - go to Toyota and get a replacement OBD harness and swap it
    - put the truck on eBay
  10. Sep 21, 2020 at 7:43 AM
    #4930
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Did you try a different *USB* cable already? I've had some of them go bad before.
  11. Sep 21, 2020 at 7:46 AM
    #4931
    Taco16LB
    Taco16LB Well-Known Member
    Maybe something simple overlooked like not turning off the entune screen or another accessory like blind spot monitor or parking backup sensors ? Try a different USB port on the computer ?
  12. Sep 21, 2020 at 8:13 AM
    #4932
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    In the new version on vFtuner there is an option for dump tubes to get rid of CEL, whether or not a version of the tune will come out with im not sure, but I don't think so.
    Phich[QUOTED] likes this.
  13. Sep 21, 2020 at 8:14 AM
    #4933
    ihatemytruck
    Dave
    Southern California
    There's a section you can change gear ratios in.
  14. Sep 21, 2020 at 8:14 AM
    #4934
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    @Tac0Tic0 - Just adding my suggestion with these comments. If you have any aftermarket ODBII like my Kenwood HU make sure that is disabled and also close the tune you are attempting to flash in VF before sending it. I had some combination of the above (or a fluke) and had the same error but it recovered once I ensured all that was not in the way. I hope you have the same fluke and these comments resolve it!
    PhogDog, ihatemytruck and Shellshock like this.
  15. Sep 21, 2020 at 8:17 AM
    #4935
    su.b.rat
    su.b.rat broken truck
    is there any way to increase/magnify the size of the plot? even with my glasses it's hard to see with everything smushed together. i have to rotate it around to see the labels and values.
  16. Sep 21, 2020 at 8:19 AM
    #4936
    Shellshock
    Iowa
    I attached a bigger display to my computer lol
  17. Sep 21, 2020 at 8:20 AM
    #4937
    mZiggy
    mZiggy Honey badger
    Marc
    Yeah I've been using my 32" monitor lol
  18. Sep 21, 2020 at 8:21 AM
    #4938
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have not found any controls for that. The axis units also tend to run together.
    What would be neat is some visualization and operations in a spreadsheet. Or, possibly a couple different smoothing profiles in vF. CTRL + I seems to be a straight interpolation of the boundary values.
  19. Sep 21, 2020 at 8:31 AM
    #4939
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    yeah guys I appreciate the tips. I’ve flashed the truck several, several times. Since 1.01. I’ve double checked everything. Tried all the USB ports.
    about to give this other tatrix connector a shot.
    Taco16LB[QUOTED] likes this.
  20. Sep 21, 2020 at 8:55 AM
    #4940
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    @OVTune
    Random question: What does the ECU do when it is between values on a map? I can see it interpolating or sticking with the closest value.
    Also, the CC Speed setting does not seem to have an affect? First, I tried a value of 1 and then 10, hoping for a setting that I can use as low as 1st Gear around Idle. In both cases, 25mph (Stock) was still the lower bound. My main reasoning here, in the past, is school zones and those goofy, over-policed towns. Being able to get something between 10mph to 19mph CC would be killer.
    Thanks!
Thread Status:
