vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Sep 23, 2020 at 3:08 PM
    #5141
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    it’s doing the same thing in the truck. Double checked the wires. Power supply is good. It’s 12.1-12.2 the entire time it flashes.
  2. Sep 23, 2020 at 3:13 PM
    #5142
    OVTune
    OVTune Well-Known Member
    OVTune
    Any possibility you are using Windows Vista or 7 with some old USB3.0 port?
    Usually it's not possible to fail like this in recovery mode.
    Try a stock file.
    Might be time to open the ECU and verify it isn't corroded inside. Some trucks have leaky / corroded capacitors. Mostly 2016s from what we have seen.
    tonered likes this.
  3. Sep 23, 2020 at 3:14 PM
    #5143
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    I’ve used this computer several times. Did it change between one of the versions of p5 flash?
    only trying stock files
    tonered likes this.
  4. Sep 23, 2020 at 3:24 PM
    #5144
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    As far as I understand it there is no right or wrong answer to when the tc locks or unlocks. You deliver more torque to the wheels when unlocked due to the torque multiplication effect at the expense of lost energy due to heat generation by fluid shear. When locked, you lose torque multiplication but save fuel by delivering torque more efficiently because you are not generating waste heat. Generally you want the tc unlocked at lower rpms where the engine is making less torque. Where you lock up will be a function of how you want to optimize torque multiplication vs efficiency, and perhaps your trans cooler’s cooling ability at the extreme.
    I’m not an expert but thats how I understand it.
    G8R_Taco and inksin[QUOTED] like this.
  5. Sep 23, 2020 at 3:28 PM
    #5145
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    I’m off tonight if you need me to make a road trip with my laptop. Less than an hour away.
    @OVTune do you think that would help or do you think his truck ECU is fried?
    Or bring your ECU to me with your bench setup.
    tonered and DES2009 like this.
  6. Sep 23, 2020 at 3:32 PM
    #5146
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    Thank you, that was a good explanation, won't feel so worried about actual lock up points right now and can fine tune that later. sent you a pm too
    Mooseditty17 likes this.
  7. Sep 23, 2020 at 3:44 PM
    #5147
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Noooooooo!
    That sucks.
  8. Sep 23, 2020 at 3:58 PM
    #5148
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    shocking...
  9. Sep 23, 2020 at 5:03 PM
    #5149
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    I decided to start playing with those today. Seems like changing "gear 5" and "gear 6" are the normal driving maps. I think gear 1-4 are for a cold engine - I noticed for the first few miles the TC lock/unlock behavior is different.
    Long story short. I changed my 2 and 3rd gear unlock points so the TC stays unlocked at lower speeds and it improved neighborhood driving speed smoothness. Could pull in 3rd slipping the TC w/o needing a downshift to 2nd.
    Saeros and Mooseditty17[QUOTED] like this.
  10. Sep 23, 2020 at 5:19 PM
    #5150
    CorbinDallas
    CorbinDallas Well-Known Member
    Corbin
    Tacoma
    16 MT OR
    Sorry to ask, been away for some time. I am on 2.0 MT. Is vf tuning worth the "upgrade" from the legacy tuning option (aka dongle)
  11. Sep 23, 2020 at 5:20 PM
    #5151
    Shellshock
    Iowa
    Yes. It’s free
    wahoobie and Mooseditty17 like this.
  12. Sep 23, 2020 at 5:22 PM
    #5152
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    I miss my dongle so much.
    DES2009 and Mooseditty17 like this.
  13. Sep 23, 2020 at 5:26 PM
    #5153
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    That's what she said? :anonymous:
    cemented, Scott4032, tonered and 2 others like this.
  14. Sep 23, 2020 at 6:05 PM
    #5154
    ForceOfG
    ForceOfG Well-Known Member
    Portland, OR
    16' DCLB 4x4 Off-Road
    5.29 Yukons Stage 2 Icons 265/70/17 OVTuned
    By chance did you confirm this by logging or with the butt dyno? Only reason I ask is because I've been logging for weeks and yet to see my TC lock in gears 1-3. Maybe I'm running a different tune or something?
  15. Sep 23, 2020 at 6:08 PM
    #5155
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I run OBD Fusion and I don’t think I see my TC lock in 1-3 either.
  16. Sep 23, 2020 at 6:34 PM
    #5156
    dunlap837
    2018QSDCLBSR5
    04A61 does not allow TC lock in gears 1-3.
    BlazinBlue likes this.
  17. Sep 23, 2020 at 6:37 PM
    #5157
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Totally rookie question, but, how are you logging? Techstream, or VF?
  18. Sep 23, 2020 at 6:59 PM
    #5158
    ForceOfG
    Portland, OR
    Yup I've been using techstream. I cant get the OVTune loggers to monitor as much as what techstream can do.
    Vlady and Tac0Tic0 like this.
  19. Sep 23, 2020 at 7:26 PM
    #5159
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
  20. Sep 23, 2020 at 7:53 PM
    #5160
    hr206
    Western Washington
    Butt dyno. I have another errand to run tomorrow so I'll see if I can figure out logging. I do pay attention to revs fluctuations associated with each shift and if I think the TC unlocks I do modulate the gas a bit to see if the revs rise independent of speed w/o a downshift which is more noticeable.
Thread Status:
