vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Sep 24, 2020 at 2:16 PM
    #5201
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    You can just go to your throttle limits for gears 1 through 6 and multiply everything by *105 or *110. Currently they're at about 25% higher than the stock 2.0 OV tune. I played with 30% overall increase and thought it was too much, however you might like it! I wanted the vehicle to be more responsive but still drivable to where I don't have to tiptoe around the throttle.
  2. Sep 24, 2020 at 2:19 PM
    #5202
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Question: are the values seen in the tables percentages themselves, or do you do the math and plug in the appropriate/resulting value?
    Finally have some time off, starting to play with some stuff.
  3. Sep 24, 2020 at 2:24 PM
    #5203
    Mooseditty17
    AJ
    WI
    I believe they are percentages. So when pressing the Throttle down 5%, the throttle body will open x percentage out of 100.
    Focus more on the percentage you're increasing that number by, as opposed to what that number actually is to eliminate too much headache and overthinking.
  4. Sep 24, 2020 at 2:26 PM
    #5204
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    On that note, anyone flashing a lot that wants a backup plan ready to go.... I'm putting together a few kits that will plug directly into the ECM and your Tactrix. No jumper wires or fiddling required.
  5. Sep 24, 2020 at 2:26 PM
    #5205
    mZiggy
    mZiggy Honey badger
    Marc
    Yeah that's what I was trying to identify. Like, if it says 30. If that means 30% or not, because 5% more could then bring it to 35, or to 31.5
    xxTacocaTxx likes this.
  6. Sep 24, 2020 at 2:27 PM
    #5206
    Mooseditty17
    AJ
    WI
    You're one hell of a handy guy to have around...
  7. Sep 24, 2020 at 2:29 PM
    #5207
    Mooseditty17
    AJ
    WI
    :boom::boom::boom::boom:
  8. Sep 24, 2020 at 2:30 PM
    #5208
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :spending:
    :rofl:
  9. Sep 24, 2020 at 3:04 PM
    #5209
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    I really considered this also after this happened. I think it would help out anyone on the edge about tuning. I just don’t know where to get the ecm harness from?
    DES2009 likes this.
  10. Sep 24, 2020 at 3:24 PM
    #5210
    TWTaco
    TWTaco Well-Known Member
    Dave
    Yes it is. Its working great i added the 1st gear throttle limiter today going to flash it tonight.
    Mooseditty17[QUOTED] likes this.
  11. Sep 24, 2020 at 3:29 PM
    #5211
    Shellshock
    Iowa
    @lapoltba is a harness wizard. He did the pnp 2lo mod and is working on a 2lo & locker anytime mod too
    ihatemytruck, tonered, inksin and 3 others like this.
  12. Sep 24, 2020 at 4:00 PM
    #5212
    trd pr0
    trd pr0 Well-Known Member
    Geary
    san francisco
    Tacoma trd offroad cement
    AR15 knobs for the radio, ovtune, bigmouth dump tube by ovtune, manual, ripp supercharger coils, trd drop in air filter, rock sliders , trd skid, fuel tank skid ,rear shock skids, hids, meso customs
    What cause it to brick
  13. Sep 24, 2020 at 4:06 PM
    #5213
    lapoltba
    CT - 06076
    As Mat noted, I guess there are issues with some ECMs having corrosion internally which is never good. My understanding is that using the flash software (not Techstream), it should be almost impossible to brick your ECM. I haven't gotten that deep into it to have a good answer.
  14. Sep 24, 2020 at 4:19 PM
    #5214
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    And it turned out that @Tac0Tic0's ECU didn't brick. The issue was his notebook got flakey. o_O
    xxTacocaTxx and Mooseditty17 like this.
  15. Sep 24, 2020 at 4:28 PM
    #5215
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I’m guessing those dents are from your forehead? :rofl:
  16. Sep 24, 2020 at 4:36 PM
    #5216
    lapoltba
    CT - 06076
    I thought he said his truck wouldn't start....? Or am I thinking of someone else?
  17. Sep 24, 2020 at 4:45 PM
    #5217
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    truck definitely didn’t start. A partial flash def locks out the ECU. But yeah it wasn’t “bricked”
    tonered, DES2009 and lapoltba[QUOTED] like this.
  18. Sep 24, 2020 at 4:48 PM
    #5218
    lapoltba
    CT - 06076
    Ok, thanks for confirming my memory isn't *that* bad. I try to follow here, but have been too busy to get everything lately. It is my understanding that there is really no way to permanently brick this ECM without catastrophic damage. Everything we would see is normally going to be a "soft brick" which is recoverable by the method you used.
    wahoobie and Tac0Tic0[QUOTED] like this.
  19. Sep 24, 2020 at 4:51 PM
    #5219
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    Yeah that’s about what I gathered!
  20. Sep 24, 2020 at 4:59 PM
    #5220
    Kleach18
    Kleach18 Well-Known Member
    2016 TRD Offroad
    What am I doing wrong. I update to the latest version of vfTuner when it is released. Why does it still take 5-10 minutes for the program to open up!?
    b3itz likes this.
Thread Status:
