vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Sep 25, 2020 at 1:47 PM
    #5301
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Looking for some clarification:
    When you flash a new or different tune, it erases learned values. The reason for the clear at and clear LV buttons, is due to the fact it doesn't always clear all of those values in their entirety, correct?
    Edit:
    So let's say I go and I run a 93 performance octane tune, then I decide to go to my homemade tune and don't clear either the LV or AT fields .. Will I now have some sort of a hybrid tune? Is it possible for those uncleared values conflict with new values?
    tonered likes this.
  2. Sep 25, 2020 at 1:48 PM
    #5302
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    From what I understand, correct.
    tonered likes this.
  3. Sep 25, 2020 at 1:48 PM
    #5303
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nope. When you pull the battery terminals or flash a tune, the DTCs are reset. The engine and AT LVs stick, unless you do the Resets.
    xxTacocaTxx and wahoobie like this.
  4. Sep 25, 2020 at 1:49 PM
    #5304
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :D
    Annnnnd, go! :bikewheelie:
  5. Sep 25, 2020 at 1:54 PM
    #5305
    Mooseditty17
    AJ
    WI
    :argue::duel:
  6. Sep 25, 2020 at 1:57 PM
    #5306
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :drunk:
    :laughing:
  7. Sep 25, 2020 at 1:59 PM
    #5307
    Mooseditty17
    AJ
    WI
    The reason I ask this is because I've noticed that while doing little adjustments: let's say on a shift point, that by not clearing the LV or at fields it seems like a much smoother transition. But then I started wondering how messy would that be if you had huge changes. Even something as simple as different octane.
  8. Sep 25, 2020 at 2:04 PM
    #5308
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. Resetting and idling gives some wonky running. If you want to test back to back small changes, you can skip it. Some folks around here have never done the Resets.
    My problem is that doing them made such a big difference after the first time that I tried them, I can't resist the clean slate when flashing. I need help.
    ihatemytruck and BlazinBlue like this.
  9. Sep 25, 2020 at 2:05 PM
    #5309
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    This was from @OVTune , but I don't have the actual post to quote, just saved the text:
    "Regarding reset AT / LV.
    So this isn't confusing
    Resetting LV / AT after a flash = not required
    Resetting LV / AT after a flash = is not harmful, and may be done at your discretion
    Resetting LV / AT after a flash = Should be done IF you have drivability issues (very odd shifting behavior, very odd engine behavior, or you hear any knock/detonation)
    Resetting LV / AT after a flash = May make the truck run noticeably rougher for the first few miles (especially the transmission)
    Resetting LV / AT should NOT be done just because you feel like doing it.
    Resetting the LV / AT should NOT be done if you haven't recently flashed.
    If you Reset LV / AT right after a flash = the first 25mi to 50mi, the trucks shifting characteristics can be ignored
    If you Reset LV / AT or even flashed the truck and are making judgements without putting AT LEAST 25 miles on the truck, you are not getting an accurate representation of how the truck will perform."
  10. Sep 25, 2020 at 2:08 PM
    #5310
    Mooseditty17
    AJ
    WI
    Perfect. Thank you!
    tonered[QUOTED] likes this.
  11. Sep 25, 2020 at 2:12 PM
    #5311
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome! :cheers:
  12. Sep 25, 2020 at 2:43 PM
    #5312
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    I’m trying Moosedity’s tune right now. It’s helped some with the cruise control. I went to play golf today and had to drive on the interstate there and back. Both times at 72-73 mph, the rpms only went up a few hundred rpms (only dropped to 5th) on hills/overpasses. I was pleasantly surprised. If you are on 04B04,you need to try it.
    I also got 17 mpg! I haven’t seen that since stock!
    TWTaco likes this.
  13. Sep 25, 2020 at 2:53 PM
    #5313
    Saeros
    Saeros #dealermole
    Canada, Eh!
    2022 Venza Limited
    I agree that his tune is pretty spot on! I have tweaked the shift points / torque converter stuff to my liking. I've also turned up the sensitivity on the throttle to my liking as well. Good stuff.
    tonered and Mooseditty17 like this.
  14. Sep 25, 2020 at 3:02 PM
    #5314
    Uscgamecock7
    Uscgamecock7 Well-Known Member
    Nick
    West Columbia, SC
    2015 Tacoma Trd Sport DCLB 4x4(SOLD) 2017 Tacoma Trd OR 4x4(SOLD) 2024 T4R TRD PRO
    I ran his tune tow tune to the beach which was about 180 miles each way. I was averaging about 17.4 mpg each time.
  15. Sep 25, 2020 at 3:16 PM
    #5315
    PapaRee
    PapaRee Pro Tuner
    Kreg
    It’s so crazy to me that we get better gas mileage with performance tunes!
    I think this truck just loves to run around 2000-3000 rpms.
    wahoobie, tonered and TWTaco like this.
  16. Sep 25, 2020 at 3:28 PM
    #5316
    Shellshock
    Iowa
    You get better fuel economy with some rpms. My MT will regularly see 20+ mpg at 70 mph and 2450 rpm. The AT tries to run at 1800 and bogs down and kills fuel economy.
  17. Sep 25, 2020 at 4:00 PM
    #5317
    Distance87
    Distance87 Well-Known Member
    Garrett
    Driving up some mountain.
    2016 blue dcsb sr5 taco tss
    3 inch lift, custom exhaust with Flowmaster hp-2 muffler. Bedrack, decked system, arb on board air system, fabfours vengeance winch bumper with smittybilt X20 winch, dual car seats.
    Does any one know of some one making a performance off road 4x4 tune or a tune with a ghost cam
  18. Sep 25, 2020 at 4:51 PM
    #5318
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    I think the engine runs fine enough at 1800. The real problem to me is the throttle and shift curves would be so flat for so much pedal travel, and then shoot up so fast. If you were running 1800 rpm and say 6-7% throttle, and you needed just a hair more, it was very difficult not to end up at 3700+ and say 30% throttle. Thats unnecessary and would just kill fuel efficiency.
    Toyota did a fine job getting fuel efficiency when your only load is drag. And this engine rips at the top end too, for what it is. They just couldnt figure out how to smoothly get from one end to the other.
    Tharris242 and PapaRee like this.
  19. Sep 25, 2020 at 5:22 PM
    #5319
    imjohn
    imjohn Well-Known Member
    I’m new to a lot of this stuff so forgive me for asking. How would I go about using his tune? I just updated my truck to the 04B04 and it’s pleasant so far.
  20. Sep 25, 2020 at 5:47 PM
    #5320
    Shellshock
    Iowa
    Do you have vf tuner? Grab his file and flash it
Thread Status:
