vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Sep 25, 2020 at 7:57 PM
    #5341
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It sounds like you're still having trouble in the bottom end, like I did. Take a peak at my thread in the Perf and Tuning from and compare the V1 and V2 maps, esp the second set where I over-smoothed the bottom end.
    https://www.tacomaworld.com/threads/ovt-vf-torque-limit-edit.685741/
    Karminski[QUOTED] likes this.
  2. Sep 25, 2020 at 8:03 PM
    #5342
    Distance87
    Distance87 Well-Known Member
    Garrett
    Driving up some mountain.
    2016 blue dcsb sr5 taco tss
    3 inch lift, custom exhaust with Flowmaster hp-2 muffler. Bedrack, decked system, arb on board air system, fabfours vengeance winch bumper with smittybilt X20 winch, dual car seats.
    Fuel wont be a problem im going to take a stock if concrentaed race fuel with me so that nomatter what I can have higher octane
  3. Sep 25, 2020 at 8:06 PM
    #5343
    Distance87
    Garrett
    I need majority or hp and torque within 500 rpm and 3500 rpm basically crawling rpms up to a high rpms for 4l just incase.
  4. Sep 25, 2020 at 8:10 PM
    #5344
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    You're going to get the best of what is available with this tune. Toyota isn't going to deliver, ever. OVT, IMHO, is the only alternate option. Low end torque is greatly improved. All I can suggest is to find someone near you that is willing to let you go for a ride, or flash your ECM for you. I honestly don't think you will be disappointed.
    Mooseditty17, tonered and Shellshock like this.
  5. Sep 25, 2020 at 8:13 PM
    #5345
    Distance87
    Garrett
    I'll do all the research and studying i need to do to build the tune. I am hoping com delivers on some cam options especially since Magnuson released their sc.
  6. Sep 25, 2020 at 8:16 PM
    #5346
    lapoltba
    CT - 06076
    You shouldn't have much to do when starting from the tune pack..... The base 2.0 tunes are solid.
    Look at some of the Mag SC threads here and elsewhere. The initial launch is not that exciting. I hope for their sake they have a proper tune available soon.
    ihatemytruck and Mooseditty17 like this.
  7. Sep 25, 2020 at 8:18 PM
    #5347
    Distance87
    Garrett
    But wcs ill just do a 4bt or 6bt td swap if i can't get the computer worked out
  8. Sep 25, 2020 at 8:20 PM
    #5348
    lapoltba
    CT - 06076
    Go for it. If that's the kind of torque you are looking for, you're never going to get it out of a NA V6. It's that, or trade it in for something you want.
    Mooseditty17 and tonered like this.
  9. Sep 25, 2020 at 8:25 PM
    #5349
    Distance87
    Garrett
    I want the taco and im probably going to run the mag sc or build a compound turbo kit for it maybe a triple turbo set up to get the torque im after
  10. Sep 25, 2020 at 8:26 PM
    #5350
    lapoltba
    CT - 06076
    I like the Taco too. It's a great platform. Take a look at the OVT twin turbo setup. They spool up very quickly and I think that will be the closest to what you are looking for.
  11. Sep 25, 2020 at 8:28 PM
    #5351
    Distance87
    Garrett
    They are sold out as of yesterday
  12. Sep 25, 2020 at 8:31 PM
    #5352
    lapoltba
    CT - 06076
    First batch was only 25. Keep an eye on it, they will be available again. I think you will be disappointed with the Mag. SC based on my understanding of your expectations.
    Shellshock likes this.
  13. Sep 25, 2020 at 8:35 PM
    #5353
    Distance87
    Garrett
    I can make the mag work if I have to with a pulley swap to get greater boost
  14. Sep 25, 2020 at 8:36 PM
    #5354
    Distance87
    Garrett
    But a tt set up or a ct setup will be easier. But a 3t setup would be epic
  15. Sep 25, 2020 at 8:41 PM
    #5355
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    IMHO, it is going to need more than a pulley. More than half of the FI kits is the tune.
    wahoobie and lapoltba like this.
  16. Sep 25, 2020 at 8:43 PM
    #5356
    lapoltba
    CT - 06076
    You could, but you would need dyno time and someone familiar with VFT. The choice is yours. I agree that you aren't going to find what you are looking for with a NA motor.
  17. Sep 25, 2020 at 8:52 PM
    #5357
    Distance87
    Garrett
    Thats why I'm hoping comp puts out some cams for the taco. If i can get a cam swap the mag and low ratio pulley swap i i think i can get into the 325-350ftlbs range if need be ill put a dry 50 shot in font of the maf to make the air denser
    xxTacocaTxx likes this.
  18. Sep 25, 2020 at 8:59 PM
    #5358
    Shellshock
    Iowa
    Next round of turbos is November and can hit those numbers and higher
  19. Sep 25, 2020 at 8:59 PM
    #5359
    Distance87
    Garrett
    I've got time to get it all figured out
  20. Sep 25, 2020 at 9:01 PM
    #5360
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I am not an expert here, but I sort of feel that with VVTiW, there's enough control there to flow a lot. OVT is noting 500hp / tq on his biggest setup.
Thread Status:
