vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Sep 27, 2020 at 4:23 AM
    #5401
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    Excited to play with this patch. It always seemed strange to me for Toyota to use a torque based throttle, but not a torque based shifting logic.
  2. Sep 27, 2020 at 6:13 AM
    #5402
    OVTune
    OVTune Well-Known Member
    OVTune
    it will be an option in a new version of vF Tuner. you load your file, you select to apply the patch, vF Tuner patches your file, the new tables and controls become active.
    I'd still recommend taking it to the dealer if you can easily repeat it. It can happen as a random occurrence from the software / logic but if you can easily repeat it then maybe something else is causing it.
    wahoobie, Ron1965 and ihatemytruck like this.
  3. Sep 27, 2020 at 6:24 AM
    #5403
    OVTune
    OVTune
    tonered, wahoobie, inksin and 3 others like this.
  4. Sep 27, 2020 at 7:04 AM
    #5404
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    wahoobie likes this.
  5. Sep 27, 2020 at 7:43 AM
    #5405
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    Will this upcoming patch also touch up the air load tables as well?
  6. Sep 27, 2020 at 8:05 AM
    #5406
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    @OVTune
    Could you please help explain the tuning of the 3D transmission torque maps a bit?
    The tune I'm running now is absolutely awesome... with the exception of a ridiculously hard 3rd to 4th upshift at full throttle.
  7. Sep 27, 2020 at 8:44 AM
    #5407
    Karminski
    Karminski Well-Known Member
    Virginia
    2016 Tacoma D/C M/T TRD Off-Road
    I have some issues with 04B14 that sound a bit similar. I'd like to smooth out M/T acceleration in 4th gear from 2000 RPM to 3200 RPM. Acceleration is smooth with very light throttle and very smoot at WOT, but in the middle its a bit herky-jerky. I've not had luck modifying the AirCrontrol Tables to try and smooth it out. I was going to try and read the tables you posted above, but can't open them without additional credits :wink:
    tonered and su.b.rat like this.
  8. Sep 27, 2020 at 8:47 AM
    #5408
    Mooseditty17
    AJ
    WI
    @Vlady
    Is this specific to your tuning files or in general something we should all apply?
  9. Sep 27, 2020 at 8:53 AM
    #5409
    su.b.rat
    su.b.rat broken truck
    agree
    Karminski[QUOTED] likes this.
  10. Sep 27, 2020 at 9:39 AM
    #5410
    OVTune
    OVTune
    If you're an MT guy making a tune based on our latest Tune release, those ECUs are patched. You need to focus on the large 3D per gear torque tables, specifically the very first table, as the ECU has been patched to use that table for calculating throttle in all gears.
  11. Sep 27, 2020 at 9:40 AM
    #5411
    Vlady
    Issy, WA
    If you look at page 206, the post stated to smooth out 800 to 2000 in those 2 tables for 0.82 and 0.99.
    We both have a curve in 1000 to 2000 at 200 to 500 airload.
    I'll see if it helps with my dead pedal
    GPatriot, inksin and Stormpeacock like this.
  12. Sep 27, 2020 at 9:59 AM
    #5412
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    How do air load and engine load relate to each other? What do they individually actually mean? Google hasn't been as helpful as I'd hoped.
    Do they need to be edited together to produce the appropriate response? Does editing only one axis fuck everything up? What's an appropriate edit for example, for whatever result?
    I downloaded Mat's example map but without the 'compare map' feature, it'd be agonizing to go through the maps to try to figure out the differences, and without actually knowing what I'd be looking at or editing, the information would be effectively useless. Currently feeling a touch above retarded.
    GPatriot, inksin and tonered like this.
  13. Sep 27, 2020 at 10:19 AM
    #5413
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    I haven’t got to it yet, but I was going to copy all the cells from Mat’s and paste into excel, same with the version I have on my tune, and do the compare there. Really easy in Excel. Then once I see it, I’ll adjust from there.
  14. Sep 27, 2020 at 10:24 AM
    #5414
    OVTune
    OVTune
    I only edited 2 tables and listed what they were.
    Airload / airflow is the ECUs way of limiting the total volumetric calculation.
    As we know, there is no map sensor. So the ECU relies solely on the MAF + internal calculations of air. MAF alone doesn't give you the entire picture. So the ECU uses these air tables to map the amount of air given at various engine loads and RPMs and will use that to instruction the throttle.
    Then there is the inverse table of it.
    Imagine it as a VE limiter map + inverse VE limiter map based on internally calculated air @ sea level + whatever the ECUs calculation of what manifold pressure *would be* at a given throttle angle. Since MAP pressure is calculated which is nuts.
  15. Sep 27, 2020 at 12:23 PM
    #5415
    InternationalHarvester
    InternationalHarvester VF Pro Licensed, KDMAX Authorized Vendor
    Sierra Nevada
    2017 TRD DC LB OR 4x4
    KDMAX Tooooned
    Hope we get a change log on the next release. Would love to know what is being wrapped up in the performance release. Seems like a lot of people are on the same page and Mat could roll this stuff up with whatever other magic seasoning he puts on it. @OVTune
    GPatriot likes this.
  16. Sep 27, 2020 at 12:35 PM
    #5416
    Vlady
    Issy, WA
    Highly recommend to update these 2 tables.
    Improved performance significantly.
    Did a quick spin and the tranny did not kicked down to 4th on step incline like it used to do.
    Dead pedal seems gone in 5th. I was pushing 80 mph in 5th , TC locked on long incline and did want to push my luck with state troopers.
    VB25, wahoobie, PapaRee and 1 other person like this.
  17. Sep 27, 2020 at 1:07 PM
    #5417
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks for the explanation.
    Mooseditty17, wahoobie and su.b.rat like this.
  18. Sep 27, 2020 at 1:17 PM
    #5418
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
  19. Sep 27, 2020 at 1:26 PM
    #5419
    mZiggy
    mZiggy Honey badger
    Marc
    @OVTune I believe before you'd said that the airload or throttle tables were different from MT to AT. Or other tables, idk, can't remember. For those of us who are looking at customizing both, what sort of differences should we be aware of and how will those translate to our edits?
    Also, I'd sent you an email via zendesk WRT to another tuning/vF question that I've got
  20. Sep 27, 2020 at 2:46 PM
    #5420
    SELAroadrunner
    SELAroadrunner Well-Known Member
    Ron
    WSNC
    17 Sport
    wheel decals
    I’m down wit da sickness, but seriously I am interested for the AT 2.0 Final
    Sunsetsearider and tonered like this.
Thread Status:
