vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. May 3, 2020 at 11:00 AM
    #541
    rpete67
    rpete67 Active Member
    Rod
    2018 Cement Tacoma TRD 4x4
    Did the other ECU's get released for VF? Thx
  2. May 3, 2020 at 11:16 AM
    #542
    JaTe
    JaTe Well-Known Member
    Maryland
    2017 Tacoma TRD OR DCSB
  3. May 3, 2020 at 11:18 AM
    #543
    rpete67
    Rod
    Cool, Missed that. Thx
  4. May 3, 2020 at 11:23 AM
    #544
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Good! Then all this battery stuff will be finished up for the few that need it. After that, hopefully you'll have time to finish up 2.0 Final+Final for the rest of us uncleansed masses. :D
    LstMinutePanic, GPatriot and PhogDog like this.
  5. May 3, 2020 at 11:42 AM
    #545
    LDS 77
    LDS 77 Well-Known Member
    2016 OR
    @OVTune Any update on the “Master Key Email not Recognized” error? Or are we standing by.
  6. May 3, 2020 at 11:52 AM
    #546
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
    So...if we have a desktop shortcut icon, don't click on that?
  7. May 3, 2020 at 11:56 AM
    #547
    GPatriot
    GPatriot Well-Known Member
    Cincinnati, Ohio
    2016 Black Tacoma Sport 4x4 V6 DCSB AT Loaded
    KDMaxPro 10.0, OME 2" Med Duty lift, RCI Sliders, RoofRack, Skid Plate, etc.
    Yes double click that aka open vF tuner first.
    I would open up the instructions he made though. He goes through it step by step.
    Friday in the instructions I stopped at "send System ID info" lol
    BOMBS likes this.
  8. May 3, 2020 at 11:56 AM
    #548
    OVTune
    OVTune Well-Known Member
    OVTune
    Check pm
  9. May 3, 2020 at 12:10 PM
    #549
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Mat, will there be a feature or option to compare two files and have the software highlight or tell you which values are different? I could see that being very useful.
  10. May 3, 2020 at 1:43 PM
    #550
    Kclamer
    Kclamer Well-Known Member
    Konstantin
    2018 Toyota Tacoma TRD Off-Road 4x4
    2.5" lift, 4.88 gears
    The Optima Yellow Tops I have in my truck take 14.8V to fully charge. This summer I am also adding in a battery into the bed for my camp buildout so there is potential for a very heavy load on that alternator, possibly 100A or so. I have a 130A alternator so it has the capacity.
  11. May 3, 2020 at 2:21 PM
    #551
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    The compare feature is there and there is an option to highlight cells in the tables that are changed. I’m not sure how the highlighting changes and carries over once a file is saved though. There are a few options for making altered cells visible though.
  12. May 3, 2020 at 2:54 PM
    #552
    OVTune
    OVTune
    SuperBad, xxTacocaTxx, BOMBS and 5 others like this.
  13. May 3, 2020 at 3:01 PM
    #553
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    To clarify, if we load the new version and look at your test tune you posted earlier, we can see what was tweaked to increase charging voltage, correct?
    Also, any chance we can get a 1.05 or other tune on vF so we can move beyond stock from a new baseline?
    ihatemytruck likes this.
  14. May 3, 2020 at 3:03 PM
    #554
    OVTune
    OVTune
    yep you can see what I did.
    Can't post any "tuned" versions quite yet. Have some back end code to do on them.
  15. May 3, 2020 at 5:09 PM
    #555
    Jacked05
    Jacked05 Well-Known Member
    Josh
    North Carolina
    18 TRD OR Premium MT
    Any idea when us MT guys will get a go with this?
  16. May 3, 2020 at 5:11 PM
    #556
    cameleon50
    cameleon50 Well-Known Member
    Weatherford, Tejas!
    YotaWerx'd 2017 TRD PRO CEMENT
    Hammer Hanger, Kings 2.5, ICON Leaf + UCA, Marlin, OEM Audio Plus, OVTune, Nitro 5.29, MESO, Victory 4x4
    @OVTune & @Markc1024 - If I use the zip file to tune the alternator, does 2.0 Final write over this? I also have a NorthStar AGM and do appreciate the extra effort on the voltage adjustment.
  17. May 3, 2020 at 5:54 PM
    #557
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    You will lose 2.0 final and be back on stock tune with more voltage to your alternator.
  18. May 3, 2020 at 6:17 PM
    #558
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    So if we have the registry key from last year for OVTune, can the same one be used for VF Tuner?
    Do I have to even re-install the key?
  19. May 3, 2020 at 6:42 PM
    #559
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Use the same one. Should install itself, mine did.
    RedLantern likes this.
  20. May 3, 2020 at 6:53 PM
    #560
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    He said next week sometime
Thread Status:
