vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Sep 29, 2020 at 10:09 PM
    #5601
    banjoist13
    banjoist13 Well-Known Member
    Ian
    Humboldt County, CA
    2016 Off-Road 4x4 Manual Transmission
    BAMF Alumisteel front bumper, BAMF dual swing high clearance rear bumper, RCI full skids, C4 Fab Rock Sliders, Rago Fab LCA skids & rear shock mount skids, Method Trail 701 Wheels, ARB dual onboard air system under hood, Taco Tunes speaker system, Rago fabs center consol MOLLE, Weboost Drive Sleek OTR, SDHQ Billet Battery Terminals, Gofast Camper, Morimoto XD headlights and taillights, Accutune custom tuned Fox 2.5 adjustable front w/650lb Eibach springs and rear shocks, Deavers stage 3 leaf springs, Martin off-road camper rack, Cammo & Covers Tactical Seat covers,
    So I spent the evening doing a bunch of math and such and think I am close to recreating the stock alternator ECU settings increased for an AGM battery but still following their fluctuations based on duty cycle so folks won't burn anything out. Right now it sits at about 14.55v at about 1500 rpm. I will continue to tweak it a bit after some road testing tomorrow until I get it perfect and then will post the full settings.
    BortisYeltzen, b3itz and marinemonkey like this.
  2. Sep 30, 2020 at 12:07 AM
    #5602
    ry18Tac
    ry18Tac Well-Known Member
    North Texas
    2018 Quicksand Tacoma TRD 4x4
    Ovtuned
    Did 2018 04A61 files ever come available? I haven’t seen anything about 2018’s
    Diesel475 likes this.
  3. Sep 30, 2020 at 12:43 AM
    #5603
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    My issue with this theory, my truck did not do this in 1.05 but started in 2.0
    No difference between 2.0 reg, premium, or sfob variants.
    1.05 did not have this lunging problem.
    2 things changed between 1.05 and 2.0 that i think caused it.
    Changes to Dfco and the single torque map.
    Funny though when comparing the primary throttle table from stock to ovtune , he did not modify that table.
  4. Sep 30, 2020 at 1:28 AM
    #5604
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    There are 2.0 VFT formats available, but not the super duper premium excelsior final final Final 2.0, so no gearlock and other fancy stuff.
    ry18Tac[QUOTED] likes this.
  5. Sep 30, 2020 at 2:29 AM
    #5605
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Has anyone ever tried to use cruise control with a gear lock tune? What were the results??
  6. Sep 30, 2020 at 5:32 AM
    #5606
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The Air Load Control was not modified from Stock either.
    If you look at my Primary Throttle map edit, which I am not using at the moment, I did go back and smooth the first four columns to ease the tip in. That did not cause the lunging though. I only experienced that after editing the 2.0 tunes. Never before.
    I can see why it happened to me looking between my V1 and V2 Air Load Control maps. V2 is working very well right now. The little kick of torque at about 1,500 at moderate throttle is gone, tip in feels spot on, and the tune feels smoother overall.
    My opinion on the Primary Throttle is that, since OVT noted 87.5% is the max possible value, the negative values just add range to the total values. Approximately 100% total to work with. Making those reflect the throttle percentage directly just makes the range tighter. Basically, it was a Pedal Commander set too high. Esp when combined with the base throttle percentage that you were seeing. In normal driving, I typically use between 14% and 30%-ish with tip in in the low 20s. Sharpening that is not a benefit to me. I do intend to try a different edit there after I see what the transition is to 87 on this current tune.
    mZiggy and Shellshock like this.
  7. Sep 30, 2020 at 5:35 AM
    #5607
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. 04A61 Base Full is available as a Tune Pack. You just need to request it from OVT.
    ry18Tac[QUOTED] and Shellshock like this.
  8. Sep 30, 2020 at 6:03 AM
    #5608
    Mooseditty17
    AJ
    WI
    I wonder if that it what caused my hard shift. "I found the 6300 RPM fuel cutoff at around 75 mph in 3rd gear. I've bumped the 80%+ values in the 3-4 upshift down below 100 to see if that makes the shift happen before 6300." I really need an answer as to why that was happening. @BlazinBlue experienced it on a Non user adjusted tune, and @TWTaco and I both had it happen on one of my tunes. The upper values for 3-4 upshift we're well over 100. 108-113 I thought. Even if it "shouldn't really hurt anything" it was cringe worthy to experience.
    BlazinBlue, Stormpeacock and TWTaco like this.
  9. Sep 30, 2020 at 6:04 AM
    #5609
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    I'm really enjoying my frankntune.....this stuff is awesome!
  10. Sep 30, 2020 at 6:43 AM
    #5610
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    is the newest "performance tune" you posted a premium octane or regular? Nice work too and thanks for sharing!
  11. Sep 30, 2020 at 6:50 AM
    #5611
    Mooseditty17
    AJ
    WI
    All have been regular. You can certainly run premium with it. Shouldn't go the other way, hence why I've been doing Reg tunes.
    GoldenBrew likes this.
  12. Sep 30, 2020 at 6:50 AM
    #5612
    TWTaco
    TWTaco Well-Known Member
    Dave
    I used it all the time gear lock with CC it will pull a lot of the smaller hills and slowly bog down and force you to downshift but it is way better then just CC. The best part is it allows you to choose when to down shift and one gear at a time not the 6th to 4th we are dealing with now!
  13. Sep 30, 2020 at 7:07 AM
    #5613
    Quacktacular81
    Quacktacular81 Unknown Member
    SW Colorado
    2020 Tacoma TRD Off-Road
    Not sure if it would cause a hard shift, but it did surprise me at first. I was watching the tach so I knew about where I was at, but still lifted a bit and it made the shift. Likely dropped into the 52 range where I was well above the value. My new values are about +4 from the 2.0 originals:
    80: 90.149
    95.703+: 98.689
    I think somewhere in this 280-page madness @OVTune mentioned that the 3.5 was good to a couple hundred more than 6300, but honestly, it kind of felt like it was running out of the powerband by then anyway.
  14. Sep 30, 2020 at 7:11 AM
    #5614
    Shellshock
    Iowa
    It can run to 7250
  15. Sep 30, 2020 at 7:31 AM
    #5615
    Mooseditty17
    AJ
    WI
    Automatics as well? I realize it's the same engine, but can the trans handle those RPMs?
  16. Sep 30, 2020 at 7:41 AM
    #5616
    Pinchaser
    Pinchaser Flipper Crazy
    Alan
    2020 Tacoma ECU 04B82 AT
    Hi guys. I've been reading all the posts for weeks now, and took the plunge to join in the fun. Needed to order a laptop too, so can't get started quite yet, but reading all the good things here and wondering what will directly apply to my truck. Can't wait to get the shifting sorted out! I have a 2020 Tacoma AT with a build date in April 2020, what is the likely ECM # i have?
    (Going to tune my truck; feeling like a teenager again)
  17. Sep 30, 2020 at 7:41 AM
    #5617
    Shellshock
    Iowa
    I dont see why it wouldn’t. I’m sure mat’s done it on the TT kit which is gonna be also pushing more power and it hasn’t exploded..
  18. Sep 30, 2020 at 7:42 AM
    #5618
    Shellshock
    Iowa
    04B80 or 04B81
  19. Sep 30, 2020 at 7:50 AM
    #5619
    OVTune
    OVTune Well-Known Member
    OVTune
    Transmission (AT) has no problem doing 7500 RPM.
    I've personally revved to 7500 RPM on my AT IN BOOST.
    ownubad, Diesel475, Lando3210 and 5 others like this.
  20. Sep 30, 2020 at 7:53 AM
    #5620
    Quacktacular81
    SW Colorado
    @OVTune Can I get an example of the Airload changes that you provided in the 04B04 example in a 04B80 file?
    Also clarification on the First Gear Throttle Limiter - Does it only affect first gear or all gears?
Thread Status:
