vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Oct 1, 2020 at 4:09 PM
    #5721
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    there is a CSV of these as well, so i can see the actual numerical values. however, a minute of time creates a huge log. A 30 min drive creates an enormous log that i spend a lot of time holding the down arrow on my keyboard.
    maybe the degrees is in stepper (servo?) motor degrees rather than throttle angle?
    maybe i have the wrong items in the log (im using matts logger)
    suggestions for a different logger?
    tonered[QUOTED] likes this.
  2. Oct 1, 2020 at 4:11 PM
    #5722
    OVTune
    OVTune Well-Known Member
    OVTune
    14 to 17* at idle is very common and normal on DBW systems.
    These do not have idle air controllers like older cars, where the TB can be fully closed
    ihatemytruck, MOC221_ and tonered like this.
  3. Oct 1, 2020 at 4:13 PM
    #5723
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Servo angles might be it?
    I believe those PID are good.
    I have used both the TS logger and the one on the last version of FM. Both worked fine. The TS one only does a set amount of time.
    When monitoring, I mainly use a BT adapter and the Torque app.
  4. Oct 1, 2020 at 4:15 PM
    #5724
    92ehatch
    Kinley
    Hendersonville NC
    ahh yes, the ol honda IACV
    good to know. Thanks for chiming in
    tonered likes this.
  5. Oct 1, 2020 at 4:21 PM
    #5725
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks, Mat.
    The idle air explanation make a ton of sense.
    I can put that to bed!
  6. Oct 1, 2020 at 4:32 PM
    #5726
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    One of these guys may figure this out soon.. we'll be sure and let you know :D
    tonered likes this.
  7. Oct 1, 2020 at 4:33 PM
    #5727
    banjoist13
    banjoist13 Well-Known Member
    Ian
    Humboldt County, CA
    2016 Off-Road 4x4 Manual Transmission
    BAMF Alumisteel front bumper, BAMF dual swing high clearance rear bumper, RCI full skids, C4 Fab Rock Sliders, Rago Fab LCA skids & rear shock mount skids, Method Trail 701 Wheels, ARB dual onboard air system under hood, Taco Tunes speaker system, Rago fabs center consol MOLLE, Weboost Drive Sleek OTR, SDHQ Billet Battery Terminals, Gofast Camper, Morimoto XD headlights and taillights, Accutune custom tuned Fox 2.5 adjustable front w/650lb Eibach springs and rear shocks, Deavers stage 3 leaf springs, Martin off-road camper rack, Cammo & Covers Tactical Seat covers,
    This should answer your question somewhat. Check Mat's tunes for more specific numbers for the '18+ and then modify from there. You just need to make sure the charging goes down as temps go up. Pm me if you have any questions. I run a '16 manual but I can help a bit if you give me numbers from his tune.
    A note for AGM folks:
    Spent some time doing research into the charging voltage vs temp for AGMs. Screen Shot 2020-10-01 at 4.13.18 PM.jpg
    The voltage input should follow this curve down as the engine heats up or we risk frying the battery. I am finally getting a handle on exactly what each number means and will finish polishing them this weekend when I have time to go for longer drives and log voltage vs engine temps. If you run your battery in extra cold temps max voltage can be increased up to 15v but you should have multiple tunes so when the weather gets warmer you can switch back. If you live where it is crazy hot all the time I would dial these numbers at the top end down just a bit.
    Here are some updated numbers that put 14.69 max voltage at the battery terminals and will drop them as it heats up. It is the later phases I will tighten up so we all can never max out vs the engine temp. You may have to change these a bit if you are running '18+ Tacoma's.
    Base phase duty ECT(max voltage vs engine temp): 97.825,97.825,97.601,96.622,95.164,93890,93.210,91.523,91.523
    Phase duty 1-82.265
    Phase duty 2-67.601
    Phase duty 2 base voltage 13.6v-97.922
    Phase duty 3- 64.140
    Phase duty 4- 65.531
    Phase duty 5- 71.023
    Phase duty 9- 71.023
    Phase duty Base Voltage 13.6v- 97.922
    Phase duty minimum -67.8743
    Do not change maximums under any circumstances.
    here is the odyssey extreme tech specs. The info needed is on page 17 and our engines run at the far right of the chart above.
    https://www.odysseybatteries.com/docs/us-ody-tm.pdf
    johntoyota, Karminski, b3itz and 5 others like this.
  8. Oct 1, 2020 at 5:21 PM
    #5728
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    This is great, thanks. I should probably consider editing my own AGM settings then, bring them down a bit.
    For the record though, I'm not sure you really answered the question that @TFly asked however.
  9. Oct 1, 2020 at 5:27 PM
    #5729
    banjoist13
    Ian
    Humboldt County, CA
    Thanks,
    Edited my answer a bit.
  10. Oct 1, 2020 at 5:45 PM
    #5730
    ry18Tac
    ry18Tac Well-Known Member
    North Texas
    2018 Quicksand Tacoma TRD 4x4
    Ovtuned
    I gotcha, so gears 1-2-3 will have the same values and then 4-5-6 will have the same values?
    I also noticed in the picture I sent that gears 1-2 have the same top values but 3rd gears top ones are a little different but not by much.
    Mooseditty17[QUOTED] likes this.
  11. Oct 1, 2020 at 5:53 PM
    #5731
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    question for those of you who used P5F before moving to VFT.....Did you un-install all of the P5F software before installing the VFT ? If so did doing this remove your "registration" which does not change (unless you use a different computer). Just trying to clean somethings up and eliminate the confusion = especially software conflicts and files. TIA.
    @OVTune ???
  12. Oct 1, 2020 at 5:56 PM
    #5732
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    I converted from a dongle to REG key before installing VF. I had no issues uninstalling before installing FM. The REG key stuck. As long as your system ID does not change, you can use the same REG key file anyway.
  13. Oct 1, 2020 at 9:24 PM
    #5733
    ry18Tac
    North Texas
    Ovtuned
    Is there a way to multiply a table value by a percentage on a laptop keyboard without the 10-key pad? I saw a video where you press the * on the 10 key and the multiply box pops up. But my laptop doesn’t have the 10-key.
  14. Oct 2, 2020 at 12:17 AM
    #5734
    92ehatch
    Kinley
    Hendersonville NC
    On windows 10 you can use the on screen keyboard.
    That's how i do it.
    To get to it hit your start button and type on screen and it should show up in your list
  15. Oct 2, 2020 at 12:19 AM
    #5735
    92ehatch
    Kinley
    Hendersonville NC
    The reg key is imbedded in windows registry. Uninstalling fm does not remove it.
    With that said, i left everything installed and just installed vf, it's a separate program
    tonered and MOC221_ like this.
  16. Oct 2, 2020 at 4:20 AM
    #5736
    MOC221_
    Frank
    So, maybe Primary Throttle table values represent drive voltage percentage for the throttle motor?
    That would make more sense in my head lol
    Negative to haul it shut and keep it there?
    I know there's a spring involved too.
    Anyway, negative values equal close the damn thing.
    tonered likes this.
  17. Oct 2, 2020 at 5:41 AM
    #5737
    Karminski
    Karminski Well-Known Member
    Virginia
    2016 Tacoma D/C M/T TRD Off-Road
    Very cool, any chance you might be able to save these tables to an Excel or a CSV file so a different ECU could do a comparison with what they have? 04B14 here :wink:
    tonered likes this.
  18. Oct 2, 2020 at 5:47 AM
    #5738
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Assuming you still have the top row of numbersa, Shift + 8?
  19. Oct 2, 2020 at 5:49 AM
    #5739
    Karminski
    Virginia
    Doesn't seem to work :oops:
  20. Oct 2, 2020 at 5:52 AM
    #5740
    Stormpeacock
    Stormpeacock IG: @storm.peacock
    Rich
    Atlanta, GA
    19 Cement Offroad
    MCB Elite Performance Tuned 5.29 Differential Gearing 35" Kenda M/T on Steelies SOS Bumpers, Skids, and Sliders Ranch Camper Shell
    You could also open a spreadsheet (excel or free Google sheets), paste the value(s), do the math, then copy the new values back over.
Thread Status:
