vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Oct 3, 2020 at 4:52 PM
    #5841
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    So for each gear: S2 does the half lock and #2 does full lock?
  2. Oct 3, 2020 at 5:15 PM
    #5842
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    That sounds a little too high.
  3. Oct 3, 2020 at 5:31 PM
    #5843
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    Yeah I undid that very quickly.
    ihatemytruck[QUOTED] likes this.
  4. Oct 3, 2020 at 6:02 PM
    #5844
    ForceOfG
    ForceOfG Well-Known Member
    Portland, OR
    16' DCLB 4x4 Off-Road
    5.29 Yukons Stage 2 Icons 265/70/17 OVTuned
    Yea in a nutshell.. I havent tested S2 for all of the gears yet but my guess is that's the map that controls the partial lock/unlock. If its S2 in the locking tables that means that map controls when to go from full unlock to half lock. Vice versa for the unlocking tables. S2 in unlocking tables controls when to go from full lock to half unlock. This is probably most pronounced around 45-50 MPH as you give it more gas it feels like a downshift but its really going from partial unlock 5th to full unlock 5th. Techstream will show an unlock the entire time depending on the situation.
    I did test gears 4-6 and made sure that map #2 controls full locking and unlocking in D and S mode while map #3 controls them in ECT. I didn't really feel a need for testing the lower gears.
    My next goal is to see if there are specific maps for 4Hi and 4Lo
    GPatriot likes this.
  5. Oct 3, 2020 at 6:04 PM
    #5845
    TWTaco
    TWTaco Well-Known Member
    Dave
    :popcorn::popcorn::popcorn::popcorn:
  6. Oct 3, 2020 at 6:07 PM
    #5846
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    I figured out how to make it bang rev limiter before shifting. Whoops
    Shellshock and ihatemytruck like this.
  7. Oct 3, 2020 at 6:17 PM
    #5847
    ry18Tac
    ry18Tac Well-Known Member
    North Texas
    2018 Quicksand Tacoma TRD 4x4
    Ovtuned
    That’s what I’m thinking.
    I also looked at the TC locking tables for the original 2.0 map and all the tables for for 1st and 2nd were maxed out at 255.99 also. So I guess to get it to not lock at all you just put all values to the max.
  8. Oct 3, 2020 at 6:23 PM
    #5848
    ry18Tac
    North Texas
    Ovtuned
    Did you raise the tables for the “2” tables for 4-6 or did you max them out to test?
  9. Oct 3, 2020 at 6:33 PM
    #5849
    ForceOfG
    Portland, OR
    I did not max them out but that could be a way to do it.. I set them all to one speed thats attainable and then used techstream to confirm. I made them a speed that is glaringly different from what the original table has. For example I set all of the Unlock 6th Gear 2 cells to 70 which is about 66 MPH. Went logging for a couple of hours and the changes were always immediate so once I saw that it could unlock even when im doing 65 on the highway I knew that was the table. FYI the stock TC table doesnt unlock if you're over 55 MPH no matter how much pedal you give it so it was pretty obvious. Then I switch to different modes like S and ECT to see if the TC still behaved the same or not.
    ihatemytruck likes this.
  10. Oct 3, 2020 at 6:42 PM
    #5850
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    That seems too high for most batteries...
    Sorry, I see the others saying the same thing now. I'm a little behind :cheers:
    ihatemytruck and MDFM31[QUOTED] like this.
  11. Oct 3, 2020 at 7:10 PM
    #5851
    Idahotaco88
    Idahotaco88 Well-Known Member
    Steven
    2017 black AC OR
    Kings 2.5 with adjusters, icon rxt stage 2. SCS stealth blue on 35s
    Playing with your tune a bit I set it for catless dump tubes and 35s with 5:29 gears. Love how it drives. And no check engine light either!! So stoked. Set my start idle a bit lower because I don’t have the cats to warm up fast. Exhaust even sounds better. Keep up the good work
    PapaRee likes this.
  12. Oct 3, 2020 at 7:33 PM
    #5852
    ry18Tac
    North Texas
    Ovtuned
    When you say raise by 10, do you mean 10% or raise each value 10?
  13. Oct 3, 2020 at 7:38 PM
    #5853
    ForceOfG
    Portland, OR
    I meant actually 10 not 10%. I think doing 10% across the board is going to increase some of the cells to much, but it all comes down to personal preference.
  14. Oct 3, 2020 at 7:42 PM
    #5854
    ry18Tac
    North Texas
    Ovtuned
    Thanks for clarifying. I began to wonder because I raised the 4th and 5th gear 2 (all the green-yellowish cells) by 10% and it really only raised the number by a few points. I felt like that didn't seem right because it would ultimately result in a few mph change.
    Idahotaco88 likes this.
  15. Oct 3, 2020 at 7:43 PM
    #5855
    Shellshock
    Iowa
    Done in my truck a couple times..
    tonered and Idahotaco88 like this.
  16. Oct 3, 2020 at 7:53 PM
    #5856
    Saeros
    Saeros #dealermole
    Canada, Eh!
    2022 Venza Limited
    This might be wine fueled ... Let's be honest.... This IS wine fueled... But a huge thanks to @OVTune @Mooseditty17 @ForceOfG for giving us the tools to actually fix and get these trucks driving to our own personal liking. It wouldn't be possible without the VFTuner software and the ballsy folk playing with their trucks tune and giving the rest of us the motivation and knowledge to make the changes on our trucks.
    Huge kudos. Much love. My truck is finally almost perfect.
    Thanks!!!!!!!
  17. Oct 3, 2020 at 8:10 PM
    #5857
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    So i went and edited 3rd gear according to your findings. Went for a some miles and it seems helped. Encountered a few these events in 4th though. Will apply same changes and see if it gets eradicated.
    Nice job!!!.
  18. Oct 3, 2020 at 8:14 PM
    #5858
    ry18Tac
    North Texas
    Ovtuned
    What all changes did you make? I've been messing with the tables but I just want to make sure I'm on the right track since I haven't been able to flash and test yet.
  19. Oct 3, 2020 at 8:57 PM
    #5859
    Stormpeacock
    Stormpeacock IG: @storm.peacock
    Rich
    Atlanta, GA
    19 Cement Offroad
    MCB Elite Performance Tuned 5.29 Differential Gearing 35" Kenda M/T on Steelies SOS Bumpers, Skids, and Sliders Ranch Camper Shell
    :drunk:
    Saeros[QUOTED] likes this.
  20. Oct 3, 2020 at 9:21 PM
    #5860
    Vlady
    Issy, WA
    I reverted all my changes back(650 miles via mountains passes got me thinking), except 3 airload tables and edited TC Locking 3rd gear 5 to S3 and TC Unlocking 3rd gear 5 to S3.
Thread Status:
