vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Oct 4, 2020 at 11:23 AM
    #5881
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    My TC changes are all on perf_9.29. Perf+2.5 was great. I just did a 300 or so mile camping trip with it. Really awesome stuff.
    Stormpeacock likes this.
  2. Oct 4, 2020 at 11:27 AM
    #5882
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    What about Perf+2.5 did you like the most? I want to combine all of what was great into one tune and call it a day. This is beginning to consume me...
  3. Oct 4, 2020 at 11:27 AM
    #5883
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    Is anyone aware of the PID we can monitor for the partial lock up state?
  4. Oct 4, 2020 at 11:31 AM
    #5884
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Solenoid SLU
  5. Oct 4, 2020 at 11:41 AM
    #5885
    Vlady
    Issy, WA
    I did a bunch of right turns in 3rd and 4th and the issue is not there. Interestingly the ignition stopped retarding as well
    So the fix is working, I may need to go back and mod only s2 table for 3rd and 4th. I did not notice any abnormalities though.
    Tranny temps were normal.
    And I got a progress on the dead pedal in 5th at speeds between 70 to 80 on the incline.
    I have smoothed (ctrl+I) out curves in Contol airload and Expected Airload tables in 50 to 90 % load.
    Today I was able to see the throttle opening to 40 degree, maintaining the pace.
    I'm wondering if we can bump those numbers by a few.
    P.S. Normsl (expected)TC locking is still happening
  6. Oct 4, 2020 at 11:50 AM
    #5886
    ry18Tac
    ry18Tac Well-Known Member
    North Texas
    2018 Quicksand Tacoma TRD 4x4
    Ovtuned
    So I drove around a bit with the changes made to my TC Maps which were: Locking 3rd Gear S2 raised to 255.999, locking 4th Gear 2 points raised 10 points across the table, Locking 5th gear 2 table raised 5 points across the table, Unlocking 4th Gear 2 table raised 5 points across the table, Unlocking 5th gear 2 first 4 cells raised 5 points.
    My drive consisted of city driving anywhere from 25mph to 55-60mph and I monitored my OBD Fusion App (not sure how accurate this may be) and I monitored: Lock Up Status, Throttle Position, Engine Speed and Status of the Shift Status. I also can't figure out how to access my logs on OBD Fusion app yet.. they aren't showing up under "Files".
    During my drive I noticed the TC never locks in 1-3 gears and the lugging in 3rd gear is gone from the partial lock that was happening. In 4th gear the TC will lock (from what I remember) at light throttle (cruising) around 33-35mph but once you give it slight throttle increase it unlock and jump about 300rpm and accelerate smoothly. That lock-unlock is smooth and can barely be felt which is nice. 5th gear will lock while cruising in a similar situation as 4th gear around 45mph and same results when you give it slight throttle it will unlock and smoothly accelerate. I did not change the S2 tables for 4th or 5th gear since I didn't really have the issues I had in 3rd gear. I didn't test 6th gear because I haven't changed any of those tables. Overall I feel like the 5 point change to the Unlocking tables 4th and 5th 2 made a big improvement to acceleration from the cruising speeds I tested and the RPM's drop bounce up and down before it unlocks like it used to is gone. Overall I'm happy with the improvement but I'm sure there's going to be more to fully get it dialed in but I feel like I'm in a good starting spot.
    If I find out how to access the logs on OBD Fusion app I will post them to show when the TC lock/Unlocked even if its not that accurate it will still show the parameters for the TC unlock/lock situations.
    Saeros likes this.
  7. Oct 4, 2020 at 11:53 AM
    #5887
    Vlady
    Issy, WA
    Those logs under android folder. Keep digging under it
  8. Oct 4, 2020 at 12:05 PM
    #5888
    ry18Tac
    North Texas
    Ovtuned
    Android folder? Not sure I’ve seen that before
    they used to just show up under the Files tab with the date and time. But now they just log and disappear
  9. Oct 4, 2020 at 12:41 PM
    #5889
    MDFM31
    Chester Co, PA
    16 DCSBOR
    The throttle and transmission felt connected and did what I expected. While pulling a hill, it downshifted predictably then when I created and let up, it shifted back up. I had never felt so connected through the throttle in this truck before.
    johntoyota and Stormpeacock like this.
  10. Oct 4, 2020 at 12:44 PM
    #5890
    ry18Tac
    North Texas
    Ovtuned
    I’m interested in how well it runs with just the 3&4th S2 tables adjusted so those gears go straight unlocked to lock. It seems most if not all issues are due to partial locking.
  11. Oct 4, 2020 at 1:17 PM
    #5891
    Mooseditty17
    AJ
    WI
    @ForceOfG
    Gear 2 tables are full lock D mode
    S2 tables are half lock D mode
    S3 tables control ETC torque converter settings.
    This is what you've experienced correct?
  12. Oct 4, 2020 at 1:23 PM
    #5892
    ForceOfG
    ForceOfG Well-Known Member
    Portland, OR
    16' DCLB 4x4 Off-Road
    5.29 Yukons Stage 2 Icons 265/70/17 OVTuned
    Close...
    -Gear 2 tables are full lock/unlock used in D mode & S Mode
    -S2 tables are slip lock/unlock used in D mode, S Mode, AND ECT
    -Gear 3 tables are full lock/unlock used in ECT mode
    Saeros, dunlap837, ry18Tac and 2 others like this.
  13. Oct 4, 2020 at 1:30 PM
    #5893
    TWTaco
    TWTaco Well-Known Member
    Dave
    Good info thanks!
    Mooseditty17 likes this.
  14. Oct 4, 2020 at 1:36 PM
    #5894
    Mooseditty17
    AJ
    WI
    Ok. My goal here is to eliminate the TC Lock and half lock in 1-4. I still want it to lock when towing as it always had when using gear lock. So if I leave the S3 tables alone, I'll still have locked / unlocked as designed by factory for towing.... Right?
  15. Oct 4, 2020 at 1:42 PM
    #5895
    ry18Tac
    North Texas
    Ovtuned
    And to accomplish that from what I’ve understood after reading the posts about it 10 times over is to just max out S2 tables for 1-4 gears and nothing else?
  16. Oct 4, 2020 at 1:44 PM
    #5896
    CLVol1255
    CLVol1255 Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
    Which is the ovtune on the website? I’m looking for the professionally tuned with 93 octave fuel. I’m not comfortable tuning my own truck and I’m afraid I’d screw something up
  17. Oct 4, 2020 at 1:45 PM
    #5897
    Mooseditty17
    AJ
    WI
    I believe that's the case. However I only plan on towing using gear lock therefore I will be in S mode with etc on. So... I'm thinking if I leave the S3 tables alone, but change all the rest 2 and S2 for gears 1-4, to 250.999, I will then have achieved what I'm trying for. Performance with no extra shifts in drive, and the ability to tow without burning out my torque converter while in gear lock.
    @ForceOfG ...
    Is this statement in fact correct in your eyes?
    TWTaco likes this.
  18. Oct 4, 2020 at 1:48 PM
    #5898
    ry18Tac
    North Texas
    Ovtuned
    Are you aiming for it not locking at all in 1-4?
  19. Oct 4, 2020 at 1:49 PM
    #5899
    Mooseditty17
    AJ
    WI
    While in D. Yes. In SMode w/ ETC on, I want it to lock yet
  20. Oct 4, 2020 at 1:53 PM
    #5900
    ry18Tac
    North Texas
    Ovtuned
    Then you got it right I’m pretty sure. Right now mine doesn’t lock 1-3 but does in 4-6 which is why I’m experience rpm drop of 100-200 after it shifts to 4th.
    For my next revision I’m going to take your route which is to raise gear 3&4 2 and S2 maps to 255.999? My 1-3 gears were already set to that.
    Seems like we’re both trying to accomplish the same thing. So if you get to test this theory before I get to let me know how it goes!
    Mooseditty17[QUOTED] likes this.
Thread Status:
