vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Oct 4, 2020 at 6:26 PM
    #5921
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    I read an article posted in another thread but now I can't find it. The pulsing TC lock is basically an emissions reduction function that comes with driveability and durability issues.
  2. Oct 4, 2020 at 6:50 PM
    #5922
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    So part of the solution is not to flash the Mangnuson SC tune and the other half is to use Vf tuner to make your own. Presume you can not peek into a locked tune so you can not modify Magnuson's tune - thus you don't flash it. Square one = need to identify the parameters to modify and which existing ones (shifting logic in stock vft tunes) to leave as is.
  3. Oct 4, 2020 at 6:50 PM
    #5923
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Just updated my tune with these valves and will be testing shifts and TC lock/unlock. I'm 04B31 with 5.29. Will update later.
  4. Oct 4, 2020 at 7:15 PM
    #5924
    ry18Tac
    ry18Tac Well-Known Member
    North Texas
    2018 Quicksand Tacoma TRD 4x4
    Ovtuned
    So pretty much it’s all around more beneficial to completely tune to where the TC doesn’t lock in early gears 1-4?
  5. Oct 4, 2020 at 7:21 PM
    #5925
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    If anyone wants to try out my 04b31 premium 5.29 tune let me know. Anyone have any idea how to get rid of the 5th and 6th gear governor yet?
  6. Oct 4, 2020 at 7:23 PM
    #5926
    Shellshock
    Iowa
    @uploadadventure is also 5.29 04b31
    he’ll probably try it
  7. Oct 4, 2020 at 7:32 PM
    #5927
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    Personally I'd just run the Magnuson tune and deal with it or pay someone who tunes these things for a living. I'd never want the responsibility of tuning a FI motor and trans with a program that doesn't even have a "how to" manual yet. With all the adjustments to fueling and spark I could foresee catastrophic results that someone will need $$$$ to cover. It won't be Toyota or Magnuson at that point.
  8. Oct 4, 2020 at 7:50 PM
    #5928
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    I'm enjoying you guys have at it with all the edits and applaud your commitment. I feel like I'd get annoyed having to smash in a few numbers, flash, drive, test, log, and smash different numbers. Also I see everyone talking about tables and air load and torque converters and I don't even really know how an AT works. Feels like that should be requisite material. The YouTube videos I've seen are helpful but not very good.
    So how's that tuning 101 coming? :anonymous:
    Karminski likes this.
  9. Oct 5, 2020 at 2:30 AM
    #5929
    BlazinBlue
    BlazinBlue Blue Taco Dude
    2018 TRD SPORT DCLB V6 2WD A/T
    Reference: 04A61
    When I go Full Throttle (Accelerator Pedal) I don't get Full Throttle (Throttle Blade Angle) in 1st Gear.
    After 1st Gear it is good to go. So I would like to ask again...
    @OVTune or anyone else, how do those of us with AT's get Full Throttle in 1st Gear?
    Is there some information that I am missing out on?:confused:
    3rd Gens have been out for about 5-Years.:frusty:
    Below is a log of a Full Throttle test run.
    If I logged properly;
    Line 1 = Accelerator Pedal
    Line 2 = Throttle Blade Angle
    Line 3 = Engine RPM
    Line 4 = Vehicle Speed
    Look at Line 1 you can see I have the pedal to the metal the whole run.
    Look at Line 2 and watch how the throttle blade opens full for a split second and then drops to about 1/2 and slowly ramps up to about 3/4 before shifting to 2nd Gear. No Traction Control and No Tire Spin.
    WOT LOG
    WOT GRAPH LARGE VIEW
    Also: @Mooseditty17 @inksin @Vlady @ry18Tac @ForceOfG @ AnyOneElse , HELP!!!!!
  10. Oct 5, 2020 at 3:20 AM
    #5930
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    I think there is benefit to TC lock in 4th gear. I am not sold on there being enough benefit to half lock for me to worry about trying to tune it at this point. I am planning to tune out the half lock ability and see how it goes.
  11. Oct 5, 2020 at 4:25 AM
    #5931
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Throttle limit first gear, and throttle limit 4 high. Set all values to 100. I believe techstream only shows 80 something as that's the amount of degrees it opens. 90 being maximum...
    BlazinBlue[QUOTED] and PapaRee like this.
  12. Oct 5, 2020 at 4:33 AM
    #5932
    Mooseditty17
    AJ
    WI
    Hit up @TWTaco
    GoldenBrew and PapaRee like this.
  13. Oct 5, 2020 at 5:03 AM
    #5933
    BlazinBlue
    Thank you for your reply. I made those changes. Saved the changes, reopened the tune and verified the changes before flashing. I have tried this with a couple of different tunes. Nothing changes, all of my logs show the same results (before and after).
    Before
    After
  14. Oct 5, 2020 at 5:28 AM
    #5934
    Mooseditty17
    AJ
    WI
    You are definitely changing the right map...
    BlazinBlue[QUOTED] likes this.
  15. Oct 5, 2020 at 5:30 AM
    #5935
    Mooseditty17
    AJ
    WI
    Have you made throttle limit changes to each of the gears below these maps? If you put the pedal to the floor, it should open 100%
  16. Oct 5, 2020 at 5:34 AM
    #5936
    BlazinBlue
    My truck feels the same and logs the same before and after. These map changes don't seem to do anything.
  17. Oct 5, 2020 at 5:35 AM
    #5937
    MDFM31
    Chester Co, PA
    16 DCSBOR
    I think it depends on the driving experience you want. I like having lockup in 4th, but my truck is very light compared to many others. I do think it is beneficial to have no lockup, either full or partial, in gears 1-3. I don't think these trucks with stock gears put enough power down for that.
    Lockup does a couple things-it saves fuel and lowers trans temps but you need to be making the torque or carrying the momentum to drive it through that mechanical coupling. Manual trucks (which only have a mechanical coupling) do this by using a lower diff gear set which provides more torque multiplication.
    Pulsing lockup seems like it only has drawbacks to me. I will eventually totally eliminate it.
  18. Oct 5, 2020 at 5:36 AM
    #5938
    BlazinBlue
    Yes, they make the Accelerator Pedal more responsive at part throttle, but do nothing at WOT,
    Mooseditty17[QUOTED] likes this.
  19. Oct 5, 2020 at 6:12 AM
    #5939
    Mooseditty17
    AJ
    WI
    @OVTune :help:
  20. Oct 5, 2020 at 6:14 AM
    #5940
    TWTaco
    TWTaco Well-Known Member
    Dave
    Thats strange, I definitely can feel the changes!
Thread Status:
