vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Oct 5, 2020 at 6:38 PM
    #5981
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    Has anyone played with the Accelerator- request to airload table?
    tonered likes this.
  2. Oct 5, 2020 at 6:45 PM
    #5982
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    AFAIK, folks have only been messing with the Air Load Control, Acceleration - Primary Throttle, and Throttle Management - First Gear maps.
    su.b.rat likes this.
  3. Oct 5, 2020 at 6:54 PM
    #5983
    Chadr7858
    Chad
    Colorado
    Any updates on this @ForceOfG
  4. Oct 5, 2020 at 6:58 PM
    #5984
    Chadr7858
    Chad
    Colorado
    I wonder why there seems to be a torque limitation between that rpm range.
    Tac0Tic0 likes this.
  5. Oct 6, 2020 at 2:08 AM
    #5985
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    The "Atkinson" cycle: how it works, how to eliminate it.
  6. Oct 6, 2020 at 2:18 AM
    #5986
    Mooseditty17
    AJ
    WI
    What are ignition deviation factor multipliers?
    How do we adjust these to our benefit?
    How do we control Cruise Control shift points?
    Simply put: A more detailed explanation of each map, what it does, and what the values are, would be GREATLY appreciated!
    Highlighting the ones that would benefit us most, and simply stating, this one should be left as is. Examples being the ACIS table that states .78 or 25000.**.
    Perhaps having one class dedicated to watching you go through a stock file, and how you tuned it to be a performance file. What things did you look for, and why you made the changes that you did.
  7. Oct 6, 2020 at 4:08 AM
    #5987
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    I did.
    I selected all numbers under 89 and multiplied by 10%, then i did it again. Any numbers that went over the max value i put back to below max.
    tonered likes this.
  8. Oct 6, 2020 at 4:48 AM
    #5988
    92ehatch
    Kinley
    Hendersonville NC
    My questions for you Matt.
    Why does the throttle primary for gear one show throttle angles below 14 when the trucks throttle plate doesn't close beyond 14?
    What is the relationship between the primary throttle nap and the gear specific ones? Formula? Percentages?
    Vehicle speed raw in the throttle request to air load, conversion from raw to actual speed?
    And, is the PID for relative throttle the one that should be used to monitor the position of the pedal?
  9. Oct 6, 2020 at 1:18 PM
    #5989
    ry18Tac
    ry18Tac Well-Known Member
    North Texas
    2018 Quicksand Tacoma TRD 4x4
    Ovtuned
    The values in the TC locking tables are mph right?
  10. Oct 6, 2020 at 3:15 PM
    #5990
    ForceOfG
    ForceOfG Well-Known Member
    Portland, OR
    16' DCLB 4x4 Off-Road
    5.29 Yukons Stage 2 Icons 265/70/17 OVTuned
    Is this going to include the ability for axis modification? :drool:
  11. Oct 6, 2020 at 3:17 PM
    #5991
    su.b.rat
    su.b.rat broken truck
    great news! thank you.
    tonered likes this.
  12. Oct 6, 2020 at 3:20 PM
    #5992
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    Can someone point me to the information for alternator settings for a standard (not agm) 24f battery? Or am I wasting my time to modify vft settings on this? TIA.
  13. Oct 6, 2020 at 3:22 PM
    #5993
    su.b.rat
    great idea.
    Mooseditty17[QUOTED] likes this.
  14. Oct 6, 2020 at 3:24 PM
    #5994
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    You may add this question to the list(units of measure in general). I was looking into it and to me those are in kph. There was a post from one member who slashed those numbers by 1.3 to get his mods hitting shiftting points.
    ry18Tac[QUOTED] and dunlap837 like this.
  15. Oct 6, 2020 at 3:38 PM
    #5995
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    It should say on the battery or specs what the charging voltage should be. I would imagine you wouldn't have to make any changes.
    GoldenBrew[QUOTED] likes this.
  16. Oct 6, 2020 at 5:06 PM
    #5996
    ry18Tac
    North Texas
    Ovtuned
    Thanks, I figured they were some sort of speed values. Just wanted to get an idea of what I was changing and what the result “should” be.
  17. Oct 6, 2020 at 5:22 PM
    #5997
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    This is very very unscientific but figured I'd share anyway. Yesterday morning I set all Torque Converter Locking and Unlocking "S" maps to 255, all values. Truck did seem to accelerate marginally smoother, respond to pedal input a little nicer, and lost some of that boat or cvt feeling I get sometimes. However my gas mileage on my commute plummeted from 22-23 to 19-20. Trans temps seemed to run warmer as well, I was seeing 205F pretty easily coming off of the TC prior to the cooler. Normally wouldn't expect to see that temperature as easily given the weather. I don't think 205F is that unheard of for the third gen tacos, though. Tonight I reset the gear 1-4 "S" maps to stock values. Hopefully we can all continue to learn how to monitor and tune partial lock up. Given my 2 day experiment I don't think trying to completely eliminate it is a good solution, the computer mpg estimates indicate I took a pretty good efficiency hit for a marginal driveability improvement.
    Tharris242 likes this.
  18. Oct 6, 2020 at 5:40 PM
    #5998
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    Anyone have a custom tune for 4B80 (2020) they'd like to share? Thanks
  19. Oct 6, 2020 at 6:16 PM
    #5999
    Vlady
    Issy, WA
    So i have been driving 2 days on mods to 5,6, s1,s2,s3 tables for 3 and 4.
    -Mpg did not change.
    -i did see tc temps go up to 203°, but I drove uphills and lots of stop and go traffic. 200's are normal. I saw temps higher in stop and go traffic on other iterations of the tune and stock.
    But, I have flashed with s2 only mod to 3,4 gears and will see if this is working
    Stormpeacock likes this.
  20. Oct 6, 2020 at 6:22 PM
    #6000
    Kleach18
    Kleach18 Well-Known Member
    2016 TRD Offroad
    With these recent changes everybody made are your trucks shifting to 5th gear at around 40mph and the truck sits around 1100rpms and loses all power until you give it a little more gas and the truck downshifts?
Thread Status:
