vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Oct 7, 2020 at 5:23 PM
    #6101
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Sorry, sometimes I need it spelled out in crayon.
    So does the tune pack make all 3rd gen tunes available, just needs it to be unlocked in order to access?
    Also, any idea what the differences between the TS version you provide (019) and the other one mentioned in the zip file/instructions (029 I believe)?
    The fact it exists tells me that it's out there and may have some improvements. Haven't had a chance to play around with it of course, but I definitely plan on it.
    tonered[QUOTED] likes this.
  2. Oct 7, 2020 at 5:32 PM
    #6102
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No problem.
    The TP will only include one ECU ID.
    TS V14 will access, flash, and Customize all 3rd Gens. 2016 through 2020.
    TS V15 is needed to access, flash, and Customize 2020 T4Rs. Maybe other Toyotas also, but that is the only one that I have heard about.
    ktbell444[QUOTED] likes this.
  3. Oct 7, 2020 at 5:36 PM
    #6103
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Sounds like I won't be able to use the old OVTune files on the 2017 then, bummer.
    And I see, I did see something that said "?4R," assumed 4Runner but wasn't exactly sure. Comparing the 4runner to the Tacoma, I don't see why it needs a newer version of TS. It lacks so many features compared to the taco.
  4. Oct 7, 2020 at 5:39 PM
    #6104
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. You can still flash any P5F file. FM is still available and usable separately.
    Yes. The 4Runner. It is just how TS lays out access to new ECU IDs.
  5. Oct 7, 2020 at 5:42 PM
    #6105
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    It's probably something to do with the massive tech update for the 2020 4R, at least where the gauge cluster and whatnot is concerned. Maybe I'm wrong, but that's my guess
  6. Oct 7, 2020 at 5:44 PM
    #6106
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Set all shift values on ETC maps to lowest value for each map. Then when you press ETC Pwr and go to S-mode, you're in Gear Lock. Compliments of @ForceOfG (under credited)
  7. Oct 7, 2020 at 5:45 PM
    #6107
    mZiggy
    mZiggy Honey badger
    Marc
    Plus, 2010-19 4R's have had their ECUs cracked/accessed by aftermarket companies for quite some time. 2020 support is still unavailable from OVT and Magnuson and VR, so it makes sense to me that the newer version of TS is also needed.
    The only other explanation is that I fucked up when testing on my wife's 2020 (connected with v14 and then v15), but I do not believe that I fucked up.
    tonered likes this.
  8. Oct 7, 2020 at 6:02 PM
    #6108
    OVTune
    OVTune Well-Known Member
    OVTune
    Did you request the credits in vF Tuner?
    (about > license info > bottom left > request credits (press it only 1 time, input the exact amount you purchased))
  9. Oct 7, 2020 at 6:08 PM
    #6109
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Manitoba
    3G, Tuned
    Thanks, Mat. Yes, requested in vF Tuner and paid on the website (ord #7358). I purchased 4 credits and did press that button more than once. So far no new credits. :)
  10. Oct 7, 2020 at 6:23 PM
    #6110
    OVTune
    OVTune
    Credits are on your account.
    Looks like a little issue you requested 4 credits about 10 times lol, all cleared up.
  11. Oct 7, 2020 at 6:27 PM
    #6111
    wiljayhi
    Jim
    Manitoba
    3G, Tuned
    All good now. Thank you.
    For future reference, should the credits be reflected shortly after they're purchased or is a longer wait normal?
    Edit: maybe something to do with pushing that button more than once :anonymous:
  12. Oct 7, 2020 at 6:35 PM
    #6112
    Karminski
    Karminski Well-Known Member
    Virginia
    2016 Tacoma D/C M/T TRD Off-Road
    @OVTune could you check mine as well, hopefully I didn't do the same thing :wink:
  13. Oct 7, 2020 at 6:43 PM
    #6113
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    Thanks I'll have to try it out
  14. Oct 7, 2020 at 6:55 PM
    #6114
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    Same, please PM me when you get your PM
  15. Oct 7, 2020 at 7:36 PM
    #6115
    Chadr7858
    Chad
    Colorado
    I'm loving the changes I've done to mine. It's unbelievable. I'm pulling hills in sixth that it never used to. I'd highly recommend changing the airflow tables ovtune recommended as well as dialing in the shift and accelerator tables to your liking. I also have smoothed out the Accelerator- request to airload table
  16. Oct 7, 2020 at 7:47 PM
    #6116
    ForceOfG
    ForceOfG Well-Known Member
    Portland, OR
    16' DCLB 4x4 Off-Road
    5.29 Yukons Stage 2 Icons 265/70/17 OVTuned
    Nope just some basic math. Took the max value of the table (89.976) and divided it by the amount of rows there were (24ish?) which came out to around 3.8ish so I started with 1 and I increased every row by 3.8ish.
  17. Oct 7, 2020 at 7:49 PM
    #6117
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    lol...ish
    ForceOfG[QUOTED] likes this.
  18. Oct 7, 2020 at 7:51 PM
    #6118
    ry18Tac
    ry18Tac Well-Known Member
    North Texas
    2018 Quicksand Tacoma TRD 4x4
    Ovtuned
    Smoothed out the Throttle Request to Airload? Or the other table that’s below it? Can’t remember the exact name
  19. Oct 7, 2020 at 7:56 PM
    #6119
    Idahotaco88
    Idahotaco88 Well-Known Member
    Steven
    2017 black AC OR
    Kings 2.5 with adjusters, icon rxt stage 2. SCS stealth blue on 35s
    Trying this out I only did the throttle request to air load! Will report Back tomorrow. And set my shift from 5th to 6th back to what 2.0 base was. With 5:29s and 35s the hang in 5th was to long. I am using a performance tune a member put together
  20. Oct 7, 2020 at 8:02 PM
    #6120
    Stormpeacock
    Stormpeacock IG: @storm.peacock
    Rich
    Atlanta, GA
    19 Cement Offroad
    MCB Elite Performance Tuned 5.29 Differential Gearing 35" Kenda M/T on Steelies SOS Bumpers, Skids, and Sliders Ranch Camper Shell
    Thanks. Yeah in an attempt to replicate that I changed the bottom left value to 1 then did horizontal and vertical smoothing. Numbers came out similar but gradually step instead of all be the same.
    My question was really pertaining to the gear 1-6 values for throttle. The values almost match the set throttle angles, with some minimal variability -- is there a science to that?
Thread Status:
