vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Oct 11, 2020 at 7:18 AM
    #6321
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    IMO, there's no reason to do it if there's no noticable performance difference. Thanks for the heads up.
  2. Oct 11, 2020 at 7:24 AM
    #6322
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    My main goal is the get smooth throttle and acceleration. The truck has always been lumpy and jerky.
    In my logs you can see where the throttle would jump around, up down etc.
    When i would try to take off in a hurry (full throttle) the truck would basically delay throttle, surge then i would feel a jerk, then it would smoothly accelerate.
    I narrowed it down to the throttle plate, it would slow open then surge to full throttle then close abruptly to around half way, then it would slowly open as rpm increased.
    I want the throttle plate to open and close based on my foot. You know, like a cable does
  3. Oct 11, 2020 at 7:38 AM
    #6323
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    Does it have have 2/4hi/4lo all turned up or just 2/4hi?
    Mooseditty17[QUOTED] likes this.
  4. Oct 11, 2020 at 7:38 AM
    #6324
    Mooseditty17
    AJ
    WI
    Just added the Reg file to the same post as the Premium
    DakoTaco likes this.
  5. Oct 11, 2020 at 7:39 AM
    #6325
    Mooseditty17
    AJ
    WI
    Low 4 is untouched
    johntoyota[QUOTED] likes this.
  6. Oct 11, 2020 at 7:49 AM
    #6326
    Mooseditty17
    AJ
    WI
    So tell me more about this tire roasting endeavor...
    :burnrubber::burnrubber::burnrubber::burnrubber::burnrubber:
    johntoyota likes this.
  7. Oct 11, 2020 at 8:03 AM
    #6327
    Mooseditty17
    AJ
    WI
    Who got to watch the webinar???
    Is it posted somewhere?
  8. Oct 11, 2020 at 8:09 AM
    #6328
    92ehatch
    Kinley
    Hendersonville NC
    No one yet
  9. Oct 11, 2020 at 8:19 AM
    #6329
    Mooseditty17
    AJ
    WI
    I just got done comparing a Reg file vs a Premium file. I didn't see ANY discernable differences. So either we can't make a Premium file from a Regular file, or they are the same thing with a different name. Anyone accidently run regular and notice it knocks with these new 2.0 VFT files?
    uploadadventure likes this.
  10. Oct 11, 2020 at 8:22 AM
    #6330
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Not all the tables Mat has access too, are in VFTuner yet. It’s possible the secret sauce is still in the pantry. :)
  11. Oct 11, 2020 at 8:35 AM
    #6331
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    So how would you compare the posted Regular Performance tune posted here to your Performance+9.29 tune (aside from obvious GL mod)??
  12. Oct 11, 2020 at 9:15 AM
    #6332
    Mooseditty17
    AJ
    WI
    :rolleyes:
  13. Oct 11, 2020 at 9:21 AM
    #6333
    Idahotaco88
    Idahotaco88 Well-Known Member
    Steven
    2017 black AC OR
    Kings 2.5 with adjusters, icon rxt stage 2. SCS stealth blue on 35s
    I have not logged with vf yet I am at work. but my 20 mile commute the throttle felt a lot more like 1.5 performance. I did my own air load smoothing so with the setting at (5000) and air load a bit smoother the throttle is sensitive again! Like 1/4 pedal it spins my 35s. I will log when I get off work. But no red flags and shifting feels the same. Just more bottom end power
    edit# I have also checked the timing and such all the tables are the same from each tune. I think octane ov has the power over
  14. Oct 11, 2020 at 9:36 AM
    #6334
    SpeySquatch
    2016 TRD OR DCSB
    Do you or @ihatemytruck have a 4.88 version of the latest premium tunes from @Mooseditty17 with his performance premium file? I can do the AGM settings, but have no idea how to do the gears and tires. I'm running 32's so 33" should be close
    Mooseditty17 likes this.
  15. Oct 11, 2020 at 9:51 AM
    #6335
    GoldenBrew
    Golden, Colorado
    gears and tires are way easier than AGM - just go to the drive train section and look for front and rear differential (set them to your gears - 4.88) - leave reverse as is (do not change it), and just below is tires - set it to 16.000 (radius or 1/2 diameter of 32). remember to Save Map after changes and then Export and save/rename where you want it. I have MooseDitty's latest premium octane and regular octane performance tune (has GL) but have not modified yet - waiting on him to provide a little feedback on how, other than GL, they are different from his 9.29 tune.
  16. Oct 11, 2020 at 9:58 AM
    #6336
    GoldenBrew
    Golden, Colorado
    I'm going to go ahead and mod for gears and tires (no agm for me) on both tunes MooseDitty just release - I will send them to you with 4.88's and 32's completed. Give me a while as I am going to flash the Regular Octane to the truck. All you will need to do is add the AGM and save/rename and flash. Will be sent via DM in zip format.
  17. Oct 11, 2020 at 10:00 AM
    #6337
    Mooseditty17
    AJ
    WI
  18. Oct 11, 2020 at 10:09 AM
    #6338
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Since I don’t use gearlock, I made a version with a Towing/higher shift points ECT instead. Reg octane. Stock gears. 33”tires. If any one wants it here it is
    Mooseditty17 and CorbinDallas like this.
  19. Oct 11, 2020 at 10:15 AM
    #6339
    SpeySquatch
    2016 TRD OR DCSB
    Thanks sir! Appreciate it. I have @Mooseditty17 last tune before the latest loaded on the truck, but have not driven it yet. Just realized it was for regular fuel. I’m going to run this a bit, so no rush
  20. Oct 11, 2020 at 10:16 AM
    #6340
    ry18Tac
    ry18Tac Well-Known Member
    North Texas
    2018 Quicksand Tacoma TRD 4x4
    Ovtuned
    I thought it may have something to do with the fuel cut off too. I never changed it from the 6300.
Thread Status:
