vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Oct 16, 2020 at 8:32 AM
    #6761
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Yep. There's a $100 fee if you want it sooner than what is convenient for me. :thumbsup:
  2. Oct 16, 2020 at 8:33 AM
    #6762
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    Have you or anyone else worked on a version for 04A61 with 5.29 gears? Or is there a simple-ish change I can make to your file for that?
  3. Oct 16, 2020 at 8:38 AM
    #6763
    OVTune
    OVTune Well-Known Member
    OVTune
    Looks like fun!
    I have had the worst luck this year trying to get turkey with my bow.
  4. Oct 16, 2020 at 8:39 AM
    #6764
    Mooseditty17
    AJ
    WI
    I shot a grouse last year with a field point. I was rather impressed with myself!IMG_20191025_163412465_HDR.jpg
    Stormpeacock likes this.
  5. Oct 16, 2020 at 8:51 AM
    #6765
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    Once this gets Premium octane, might it be the "ultimate tow mode"?
  6. Oct 16, 2020 at 8:52 AM
    #6766
    jschwerdtfeger
    jschwerdtfeger Well-Known Member
    Jeff
    Santa Cruz, CA
    2020 Tacoma DLCB TRD Off Road
    Fox 2.5/2.0, Deaver Expo Stage I
    Hey all, I'm sure this has been answered already, but unfortunately I couldn't find the post, so hopefully, you all can straighten me out.
    I had a 2017 TRD OR, AT, that I had OVTuned, I now have a 2020 TRD OR AT, which I'd like to do the same but it looks like the old OVTune development has stopped in favor of vForrest/roll your own.
    If I didn't want to do my own tuning, just drop a premade tune (like the old OVTune) I'm assuming I'd need both the vForrest Tuner Software + Flash Cable & the Tacoma 3.5 vF Tune Pack.
    Is this correct? Or, is there a better way to skin this cat...
    thanks!
  7. Oct 16, 2020 at 8:58 AM
    #6767
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    You will get the 2.0 tune if you get the tune pack. From there you can make changes as you see fit or just flash it as received. You will see a difference without tweaking.
  8. Oct 16, 2020 at 9:00 AM
    #6768
    Mooseditty17
    AJ
    WI
    I towed the boat down to the water to run some stabilizer through it. Personally, I think 1-3 is a little too touchy on the throttle for towing. Tip in is aggressive.
  9. Oct 16, 2020 at 9:24 AM
    #6769
    Hank_Mille
    PNW
    2016 Tacoma Limited
    Good to know - thanks!
    :cheers:
  10. Oct 16, 2020 at 9:25 AM
    #6770
    DakoTaco
    DakoTaco Well-Known Member
    North Coast
    2016 MGM OR Tacoma
    Avid front bumper guard OVtune HPS Intake Tube Meso designs counting
    Is there a laptop in that ammo bag maybe?
    Shellshock and PhogDog like this.
  11. Oct 16, 2020 at 9:34 AM
    #6771
    JaTe
    JaTe Well-Known Member
    Maryland
    2017 Tacoma TRD OR DCSB
    Does any one know if the only difference between the stock tire size, 33", and 35" tunes files is only changed at "DriveTrain Control - Tire Size" or is there more to it to change the tire size in the tune?
    Thanks!
  12. Oct 16, 2020 at 9:37 AM
    #6772
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    If you have the tunes and access to view them, open both up and compare them. You should see the differences then. Some are hard to notice but others stand out.
  13. Oct 16, 2020 at 10:12 AM
    #6773
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Just to reiterate, I can run a regular octane tune while I have 91 octane in the tank right, just not the other way around?
    ihatemytruck likes this.
  14. Oct 16, 2020 at 10:24 AM
    #6774
    disk_55FL
    disk_55FL Well-Known Member
    disk
    Buckeye
    '17 TRD Sport MT
    Correct !
    Technique[QUOTED] likes this.
  15. Oct 16, 2020 at 10:59 AM
    #6775
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Correct.
    Technically, you can do it the other way around, but you won't get much benefit. Advised against doing that
  16. Oct 16, 2020 at 11:09 AM
    #6776
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Yes. Definitely!
  17. Oct 16, 2020 at 1:00 PM
    #6777
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Just found out what happens when you don't shut the truck completely off after flashing a tune. For those wondering, it won't start. Somebody's gotta test it, right? Even if by accident, lol.
    Dirk Diggler and Shellshock like this.
  18. Oct 16, 2020 at 1:11 PM
    #6778
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    Ha, I had that happen when I helped a local guy out on Monday cause he as a start button and I have a key start.....it was a duh moment for me but we did the old REBOOT :thumbsup:
    ktbell444[QUOTED] likes this.
  19. Oct 16, 2020 at 1:46 PM
    #6779
    Uscgamecock7
    Uscgamecock7 Well-Known Member
    Nick
    West Columbia, SC
    2015 Tacoma Trd Sport DCLB 4x4(SOLD) 2017 Tacoma Trd OR 4x4(SOLD) 2024 T4R TRD PRO
    This for sure is the best my tacoma has run yet with this tune, I one hundred percent agree the last tune was super sensitive.... i was trying to go 20 in my neighborhood and it was super hard lol. AJ keep it up bud!!
    cemented and Dirk Diggler like this.
  20. Oct 16, 2020 at 1:49 PM
    #6780
    Technique
    Alex
    Utah
    Agreed. That one seems pretty solid so far. Only put a few miles on it but much more tame. Haven't got to try out the beast mode yet (ECT). But will shorty. I'll probably leave that version on for my 400 mile road trip tomorrow.
    cemented likes this.
Thread Status:
