vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Oct 20, 2020 at 5:02 AM
    #6921
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    Doing that should of eliminated full lock up. I have yet to be able to see when the truck is doing half lock up/slip lock up. I almost wonder if that's the feeling of the transmission slipping but you are for some reason gaining speed lol. I can try those settings and log it to make sure. Are you monitoring torque converter temp? Not being locked up greatly increases temp.
    Mooseditty17[QUOTED] likes this.
  2. Oct 20, 2020 at 5:10 AM
    #6922
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    I have not logged. I need to reinstall software due to a windows update
    :annoyed:
    I'd be interested in the temperatures as well. I still have the truck locking in 5th and 6th... "Cruising speeds."
    I appreciate the help :thumbsup:
  3. Oct 20, 2020 at 5:35 AM
    #6923
    GPatriot
    GPatriot Well-Known Member
    Cincinnati, Ohio
    2016 Black Tacoma Sport 4x4 V6 DCSB AT Loaded
    KDMaxPro 10.0, OME 2" Med Duty lift, RCI Sliders, RoofRack, Skid Plate, etc.
    Wait, don't we want full lock up? So making this change "TC Locking 3rd Gear S2 – set all to max" keeps the TC from locking?
    I have this issue (especially noticeable when towing) where I'll get up to speed in 3rd, it's shifts to 4th, then the TC unlocks ( or locks?) where I lose about 500 RPMs and momentum and... back to 3rd again. It sucks.
    This would be a situation where I'd want to keep the TC locked, and therefore lower tranny temps, right?
  4. Oct 20, 2020 at 5:49 AM
    #6924
    Mooseditty17
    AJ
    WI
    I was thinking the lock up brings the TC to a fully engaged situation. Now 1:1 with the engine. The lack of the fluid slipping and no longer offering torque multiplication makes the engine bog. Half lock is kind of in-between. Doesn't bog the motor, but also helps reduce temps some. 5th and 6th should lock fully as they are cruising gears. I'd find it hard to believe that with the TC half locked, and the trucks tranny cooler, anything would overheat.
    I CERTAINLY could be wrong in my theory with utilizing half lock in 4th and eliminating full lock.
    I guess that's where I would prefer to get a full lock in 4th when in SMode for heavy towing.
    GPatriot[QUOTED] likes this.
  5. Oct 20, 2020 at 6:54 AM
    #6925
    Mooseditty17
    AJ
    WI
    Quote: "So making this change "TC Locking 3rd Gear S2 – set all to max" keeps the TC from locking?"
    Correct.
  6. Oct 20, 2020 at 6:59 AM
    #6926
    Mooseditty17
    AJ
    WI
    Quote: "I have this issue (especially noticeable when towing) where I'll get up to speed in 3rd, it's shifts to 4th, then the TC unlocks ( or locks?) where I lose about 500 RPMs and momentum and... back to 3rd again."
    This is what I want to eliminate, but not at the expense of my transmission. The 2nd gen didn't have this crazy ass TC did it? I believe this is mostly an attempt at better fuel economy.
    BlkTaco47 likes this.
  7. Oct 20, 2020 at 7:00 AM
    #6927
    mot74
    mot74 Member
    Tom
    2020 Tacoma TRD 4x4
    Hey guys, sorry if this has been answered but I have searched and can't really get the info and anyone at OV is hard to get info from. I have a 2020 3.5 and bought the tuner, cable, and Tune Pack 3.5. I got the tuner and cable and installed the software. Sent files back and forth to OV. Waiting on the final response now to be able to supposedly tune my truck. My question is, where are the tune files that I bought? They do not appear anywhere when I try to open and search for them.
    wrightme43 likes this.
  8. Oct 20, 2020 at 7:01 AM
    #6928
    Mooseditty17
    AJ
    WI
    Check your download folder
  9. Oct 20, 2020 at 7:08 AM
    #6929
    Saeros
    Saeros #dealermole
    Canada, Eh!
    2022 Venza Limited
    Have you requested the tune pack from OVTune?
    wrightme43 and tonered like this.
  10. Oct 20, 2020 at 7:08 AM
    #6930
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You need to request the specific ECU ID that you want in the Tune Pack. Just reply to your Order Conf email and @OVTune will get that out to you.
    wrightme43 and Mooseditty17 like this.
  11. Oct 20, 2020 at 7:18 AM
    #6931
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I had ticket opened a while ago. Some add-on are coming in VF to help with this.
  12. Oct 20, 2020 at 7:18 AM
    #6932
    mot74
    mot74 Member
    Tom
    2020 Tacoma TRD 4x4
    I plugged it in and read the stock ECU id and part number etc then sent that to OV. Is that what they will reply with?
  13. Oct 20, 2020 at 7:22 AM
    #6933
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It depends? If you are an AT and 04B80, you might think about updating your ECU to 04B81 first? Be on the latest and greatest baseline.
  14. Oct 20, 2020 at 7:23 AM
    #6934
    GPatriot
    Cincinnati, Ohio
    Same here. I believe Mat said a while back (prob on the other thread) that the tow mode on the new map switching would keep the TC locked through all gears, because it made no sense to unlock the TC when towing. He also said on the TT thread that when locked the truck feels much more connected.
    Cant answer re: 2nd Gen. This is my first Toyota.
  15. Oct 20, 2020 at 7:47 AM
    #6935
    Chadr7858
    Chad
    Colorado
    Yeah all my previous Toyota's (I've had too many) will use the torque converter to add that extra rpm and power. When it shifts to 4th on the highway it starts unlocked and then within seconds will lock up untill you drop under the speed/throttle your tables are set at. If you raised those tables to 256 then it's always going to be unlocked and you won't loose that extra rpm. The sacrifice is generating more heat since the converter is unlocked. If I were you I would just data log the temps to make sure you're not generating too much heat on your normal drive. You could also pin the thermostat on the transmission or add a cooler if you see temps going too high. I don't know how much time you spend in fourth as every truck is different.
    I've been working on allowing 4th gear to be unlocked more myself but my situation is different since I have 5.29s and generally can pull to fuel cut in 4th uphill and don't need it to unlock that often.
  16. Oct 20, 2020 at 7:53 AM
    #6936
    mot74
    mot74 Member
    Tom
    2020 Tacoma TRD 4x4
    Apparently I am over my head here. I have had tuners for my other trucks and they were just plug in and flash. How do I go about updating my ECU?
  17. Oct 20, 2020 at 7:55 AM
    #6937
    Stormpeacock
    Stormpeacock IG: @storm.peacock
    Rich
    Atlanta, GA
    19 Cement Offroad
    MCB Elite Performance Tuned 5.29 Differential Gearing 35" Kenda M/T on Steelies SOS Bumpers, Skids, and Sliders Ranch Camper Shell
    Use techstream and install the correct cuw file. See @tonered 's signature
    tonered likes this.
  18. Oct 20, 2020 at 7:55 AM
    #6938
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    check his sig for links and how-to's
    tonered and Stormpeacock like this.
  19. Oct 20, 2020 at 8:01 AM
    #6939
    Saeros
    Saeros #dealermole
    Canada, Eh!
    2022 Venza Limited
    It's probably worth plugging your truck in and identifying your ECU. Once you have that information you email Mat asking for the tune pack fire your ECU id. He'll email you back, and that's what you flash.
    tonered likes this.
  20. Oct 20, 2020 at 8:24 AM
    #6940
    Mooseditty17
    AJ
    WI
    Perhaps with me towing a camper in the summer months I should go straight into a 4th gear lock up... Ideally I'd eliminate it in drive and while in etc or s mode have it lock right away. Does VFTuner do trans temps?
    GPatriot likes this.
Thread Status:
