vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Oct 20, 2020 at 8:38 AM
    #6941
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    I don't recall off-hand, but techstream does. You could also get one of the Bluetooth obd2 with the fusion or torque app to see it.
    Mooseditty17[QUOTED] and tonered like this.
  2. Oct 20, 2020 at 8:41 AM
    #6942
    Quacktacular81
    Quacktacular81 Unknown Member
    SW Colorado
    2020 Tacoma TRD Off-Road
    Mooseditty17[QUOTED] likes this.
  3. Oct 20, 2020 at 9:11 AM
    #6943
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    You don't want to eliminate the lock in 4th.
    I did some driving around through Cascades and 4th is you primary gear to climb hills, passes while maintaining the speed. I would imagine the towing is somewhat close to the conditions. I saw tc temps going up in 4th, tc locked up to 208° at the top of 5500 feet pass. This was before i made changes to S tables for 3rd, 4th gears. Going unlocked will warm up the tranny very fast
  4. Oct 20, 2020 at 9:15 AM
    #6944
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Thanks for the input. The whole fuss is over a 200 RPM dip. If it's going to murder my trans, I'll stick with the drop in RPMs. Really learning a lot from everyone. I think I should back off for a bit and enjoy what we've done this far. I literally drive with the radio off to hear and feel better what the truck is doing. It's becoming an obsession.
  5. Oct 20, 2020 at 9:21 AM
    #6945
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    lol, exactly why I didn't start down this path, my OCD would take over and I'd be in non-stop "just one more change" :D mode.
    I've already tried every tune you, paparee and a couple others have put out.
    PapaRee and Mooseditty17[QUOTED] like this.
  6. Oct 20, 2020 at 9:30 AM
    #6946
    GPatriot
    GPatriot Well-Known Member
    Cincinnati, Ohio
    2016 Black Tacoma Sport 4x4 V6 DCSB AT Loaded
    KDMaxPro 10.0, OME 2" Med Duty lift, RCI Sliders, RoofRack, Skid Plate, etc.
    @Mooseditty17 I thought we wanted it to stay locked in 4th, not eliminate the lock. I towed my 4200 lb camper twice from Cincinnati to and thru the Rockies since 2016; last year was to Moab and I monitored the tranny temps; they climbed but never got high enough to worry about. I'm assuming same tune conditions as you @Vlady since this was before VFTuner
  7. Oct 20, 2020 at 9:32 AM
    #6947
    GPatriot
    Cincinnati, Ohio
    And boy that first trip in 2016 to Silverton Colorado that little 200 RPM drop was DRIVING ME NUTS!!! lol
    Mooseditty17 likes this.
  8. Oct 20, 2020 at 9:51 AM
    #6948
    Mooseditty17
    AJ
    WI
    Well, by going to full lock right away, we could still eliminate the horribly noticable drop in RPMs right? And then still have the benefits of being locked of course. I'll give that a go instead.
    FYI, none of my posted tunes have 4th gear TC Lock removed. I'm just experimenting.
    johntoyota, GPatriot[QUOTED] and JaTe like this.
  9. Oct 20, 2020 at 9:59 AM
    #6949
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Read your ECU via vF Tuner (it's easier in my opinion). If it's 04B81 then you're good to go and you don't require any update. Follow the directions in the .pdf that was sent to you. The email response you receive after emailing your ECU info will contain a download link to your tune pack.
  10. Oct 20, 2020 at 10:19 AM
    #6950
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    I would consider removing torque converter lock up in fourth in ect mode if you want to make it a performance tune. I'd consider raising the values in regular mode to let be unlocked more just not all the time. Or add a big cooler and pin the tstat like me and never worry about it.
    GPatriot and Mooseditty17 like this.
  11. Oct 20, 2020 at 11:07 AM
    #6951
    GPatriot
    Cincinnati, Ohio
    I think we (or at least I) need to revisit this:
    https://www.tacomaworld.com/threads/vf-tuner-for-the-3-5l-tacoma.662948/page-312#post-24329535
    If these notes are correct then my changes to 3rd and 4th on S2 tables were only affecting a slip lock/unlock condition, not full lock/unlock as I understood it.
  12. Oct 20, 2020 at 11:15 AM
    #6952
    GPatriot
    Cincinnati, Ohio
    Our goal here is for towing, so I'd imagine we would only have 4th gear lock in ECT to get rid of the unlock and subsequent loss of rpms we don't want. Which according to the above link/post is the TC "3" tables.
  13. Oct 20, 2020 at 11:23 AM
    #6953
    Mooseditty17
    AJ
    WI
    GPatriot[QUOTED] likes this.
  14. Oct 20, 2020 at 11:25 AM
    #6954
    Vlady
    Issy, WA
    I think the issue with your graph is that you plotted % and degree.
    I've been looking at accelerator position % and throttle sensor position % and throttle sensor position is always lagging by 10+%.
    And it is across a few custom tunes published here
  15. Oct 20, 2020 at 11:43 AM
    #6955
    Rocky.Mtn
    Rocky.Mtn Well-Known Member
    Canada
    2024 Tacoma TRD OR (Hybrid)
    I'm assuming you need VF Tuner to flash .vft files to the ECU and not P5 Flash?
    Just trying to gauge whether I want to pay more and stray from final 2.0. it is cool to see guys developing new files.
  16. Oct 20, 2020 at 11:53 AM
    #6956
    Shellshock
    Iowa
    If you already have the old flash kit, the upgrade to vF is only $79
    well worth it
  17. Oct 20, 2020 at 12:05 PM
    #6957
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    You can download Vftuner and use that flash tool. It comes with the downloaded software.
    You can use the vf flash tool with your regular OVTune kit.
  18. Oct 20, 2020 at 12:56 PM
    #6958
    AtomicRyan
    AtomicRyan Well-Known Member
    Stupid question... I just got a 2021 TRD OR. Frankly, performance seems fine... not inspirational by any means, but fine... Would I be wanting to post one of these incredible customer testimonials if I were to spend $770 on the tune pack as well as software/cable? Or are these tunes more aimed at older Tacos?
  19. Oct 20, 2020 at 12:59 PM
    #6959
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    You still have the same motor and tranny as the rest of us..maybe a slightly different factory 'tune'. I just flashed my friends 2017 tacoma with one of these performance tunes and he said its like driving a whole new truck.
    If you're fine with how the truck drives now, maybe hold off. But if you start to notice weird/poor shifting and power delivery, drop the $$$. Lots of us love the tunes and they only keep getting better.
  20. Oct 20, 2020 at 1:09 PM
    #6960
    Rocky.Mtn
    Canada
    Made the purchase. Now starts the patient waiting :)
    Interested to try and flash the files here.
    ihatemytruck and wahoobie like this.
Thread Status:
