vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. May 8, 2020 at 8:37 AM
    #721
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    Since are going to purchase the VFtuner and cable you might as well purchase the "Tune Pack " for your ecu,this will give you access to OVTunes already developed tunes for your truck ;)
  2. May 8, 2020 at 8:41 AM
    #722
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    I noticed the cable is sold-out in the store. Link to an alternative?
  3. May 8, 2020 at 8:44 AM
    #723
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    JCtheHJ likes this.
  4. May 8, 2020 at 8:58 AM
    #724
    JCtheHJ
    JCtheHJ Active Member
    Alabama
    2017 Tacoma White DC TRD Off-Road MT
  5. May 8, 2020 at 9:03 AM
    #725
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    When 2.0 drops will we have access to those ovtunes and previous ovtunes in vFtuner right away? Or will these be released later on?
  6. May 8, 2020 at 10:41 AM
    #726
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
    We need to link up so you can teach me how to use the system and change the numbers around.
  7. May 8, 2020 at 11:08 AM
    #727
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    Ok. Maybe do a zoom meeting or something due to the Rona. I’m no expert by any means. Just been clicking around in the software every few days as Mat releases nuggets here and there.
    Skydvrr and BOMBS[QUOTED] like this.
  8. May 8, 2020 at 11:09 AM
    #728
    Sh2
    Sh2 Well-Known Member
    2016 Tacoma SR5 Double Cab
    Ovtune 2.0, Prinsu, 4xinnovations sliders, Southern Style Offroad Slimline with Warn VR Evo 10s
    I would love to join in...
    BOMBS likes this.
  9. May 8, 2020 at 12:11 PM
    #729
    Stormpeacock
    Stormpeacock IG: @storm.peacock
    Rich
    Atlanta, GA
    19 Cement Offroad
    MCB Elite Performance Tuned 5.29 Differential Gearing 35" Kenda M/T on Steelies SOS Bumpers, Skids, and Sliders Ranch Camper Shell
    I must have just missed the cut ordering on the 1st of May. Tactrix closed and isn't shipping until May 11th (Monday)... But it's cool, now 2.0 will be out.. I'd have to have waited anyway!
  10. May 8, 2020 at 1:48 PM
    #730
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    It would be a really short meeting. About all I know how to dig out are the alternator settings at this point.
  11. May 8, 2020 at 2:27 PM
    #731
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    @Rafael@OVTune @OVTune
    I'm just looking for a bit of clarification with regard to "Keys" for vFTuner....
    I thought I recalled seeing weeks ago that vFTuner software was not tied to a specific notebook. However there is still apparently a .reg file "key" to flash from vFTuner.
    If you already have a p5f key, they are one in the same and you can flash from vFTuner. But we can't move that p5f key to another notebook, so we are still tied to one notebook (I think) for flashing.
    For someone who has vFTuner only with no p5f, does the flash .reg key still come from the European Connection?
    Should it be possible to use two notebooks, one for vFTuner and one for p5flash while still being able to flash from vFTuner?
  12. May 8, 2020 at 3:28 PM
    #732
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    For those of you that have asked. Below is a short description of how to see the alternator changes for AGM batteries. OVTune posted a test tune in this thread. If you open both the test tune and the stock tune and compare them, you can see what you would need to change in a new tune to alter the alternator charging (pun intended). I'm assuming that you've already got vF installed and running, and downloaded the tunes available for your ECU. I'm also assuming you know how to open the files, so I'm not going through that.
    Images attached. Red box in lower left shows the 2 tunes I have open. Green box shows the alternator maps available to tweak. Brown box shows the shitty stock tune settings. I suppose in this case the values are not shitty for a standard battery, but are shitty for AGM, either way, it gets a brown box. Orange box shows OVTunes changes for AGM. You can keep opening different maps and just drag them lower in the viewer to line them up side by side. In this case, there are 8 "maps" that would need to be altered to alter your alternator charging (puns are good). I'm not showing all the alternator maps in my image, if it's not showing it's because the values were unchanged between Mat's tune and the stock tune.
  13. May 8, 2020 at 3:32 PM
    #733
    Sh2
    This is exactly what I needed, @BortisYeltzen
    Thank you
    wahoobie likes this.
  14. May 8, 2020 at 3:38 PM
    #734
    Markc1024
    Markc1024 Well-Known Member
    Thanks, I was reviewing these as well and may try to make small tweaks to the first map to see how that increments/decrements the charging voltage. I suspect some of those provide additional potential, while others target hitting a specific voltage. But I'm only guessing as I don't know their relationship to each other.
  15. May 8, 2020 at 3:38 PM
    #735
    M1Awolf
    Rob
    Montana
    Registration key received and installed successfully,thanks Mat,enjoy the beers...;) Now I just need the CUW for 04B14 and tune files for it...:)
    tonered, crunchytaco13 and Shellshock like this.
  16. May 8, 2020 at 3:45 PM
    #736
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    DISCLAIMER: I don't know that the changes made in the example I shared are "good" or "correct". All I'm showing is what was changed in the test tune provided that others verified to provide the 14.4+V needed to charge an AGM battery. The settings shown could melt your alternator for all I know. I haven't ran these settings as I don't want to run the stock tune since the new 2.0 beta is so fun (even with a few issues that are being resolved). I'm just showing how I looked at the software to see what was changed.
    ihatemytruck and PNWTacoma like this.
  17. May 8, 2020 at 4:24 PM
    #737
    OVTune
    OVTune Well-Known Member
    OVTune
    Thank you for providing that.
    Doing things like this, taking small steps, testing, seeing the result and moving forward is how things get accomplished.
    Very unlikely to damage anything as long as you don not try to crank out more than the stock max limit.
    The ECU has a test mode you can put it in and make it produce a constant 14.8v to verify the alternator works.
  18. May 8, 2020 at 4:40 PM
    #738
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    Definitely not suggesting your tweak will fry an alternator. My intent was to remind others on TW I’m not an authority on any of this. Just another monkey mashing the keyboard.
  19. May 8, 2020 at 4:41 PM
    #739
    OVTune
    OVTune
    no worries, didn't take it that way. The disclaimer is a good idea.
    We do plan to offer some better instructional material once we get the MT files released.
  20. May 8, 2020 at 5:05 PM
    #740
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    It’s my small taste of the world you live in. Hats off to you.:hattip:
    ihatemytruck likes this.
Thread Status:
