vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Oct 29, 2020 at 8:58 AM
    #7381
    NazTacoma
    NazTacoma Member
    Northern Arizona
    2017 SSM Tacoma TRD off-road
    Baja Design fog lights, Fox 2.5s on the front, 5100s w/ OME Dakar leafs, TRD 4runner pro wheels, Cooper MTP 285/70r17 tires, BAMF Sliders.
    Thank you for the help. Is there any ETA on when it will be available? I know it takes some time to build.
  2. Oct 29, 2020 at 9:03 AM
    #7382
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sorry, but no. Just that it is being worked on.
  3. Oct 29, 2020 at 9:04 AM
    #7383
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Well this code pointed me in the right direction alright!
    I'm going to go ahead and guess this wasn't put back on after they pulled my f*cking engine for the timing chain gasket replacement!!!!!
  4. Oct 29, 2020 at 9:05 AM
    #7384
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    wtf!?!?!
  5. Oct 29, 2020 at 9:06 AM
    #7385
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    Thats your intake? I would raise hell. How long have you been sucking unfiltered air?
    Mooseditty17[QUOTED] likes this.
  6. Oct 29, 2020 at 9:08 AM
    #7386
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Damn that sucks. Make sure you make the right calls so they don't deny and issues later down the road
  7. Oct 29, 2020 at 9:16 AM
    #7387
    Mooseditty17
    AJ
    WI
    Yep
    BlkTaco47[QUOTED] likes this.
  8. Oct 29, 2020 at 9:17 AM
    #7388
    Mooseditty17
    AJ
    WI
    About a thousand miles!
    A thousand miles of going to work, duck hunting, and bow hunting... AKA. A LOT of gravel roads!!!!
    Skydvrr likes this.
  9. Oct 29, 2020 at 9:20 AM
    #7389
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    Shiiiiiit man, i'd be pissed. NEW TRUCK!!
    Mooseditty17 and uploadadventure like this.
  10. Oct 29, 2020 at 9:28 AM
    #7390
    Mooseditty17
    AJ
    WI
    I tore whoever answered the phone in the service department, a new ass! I'm awaiting a phone call from the service manager. I also sent them photographs. The only thing on my mind right now is what the f*** else did they forget...
  11. Oct 29, 2020 at 9:30 AM
    #7391
    BlkTaco47
    BlkTaco47 Unhinged
    that would be a huge concern man, something as simple and obvious as that tube was left out...wtf else was passed over. scary man, hope it all works out for you.
  12. Oct 29, 2020 at 9:55 AM
    #7392
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    My check engine light doesn’t cycle on and off with the traction control button. 2017 sr
    Mooseditty17 likes this.
  13. Oct 29, 2020 at 9:57 AM
    #7393
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Of course not.
    @Mooseditty17 was asking why the TCS light was coming on with the CEL. The CEL being the primary issue here, not the TCS light. He just happened to be flicking the TCS Off button at the time.
  14. Oct 29, 2020 at 9:57 AM
    #7394
    PB FAB
    2017 SR DCSB 4x4 v6
    shitty
  15. Oct 29, 2020 at 10:17 AM
    #7395
    dunlap837
    2018QSDCLBSR5
    It is possible this was only loose and just fell apart recently when the cel came on. Shitty situation all around though.
    inksin likes this.
  16. Oct 29, 2020 at 11:41 AM
    #7396
    Quacktacular81
    Quacktacular81 Unknown Member
    SW Colorado
    2020 Tacoma TRD Off-Road
    For those of you that have played with gear locking (@Mooseditty17 & @ForceOfG, maybe others?) I have a couple of questions. This week I decided to give GL a try, so I combed through the thread and picked out the points that looked best. I initially set all of the ECT shift tables to the lowest value for each table. Went for a drive, but quickly found that upshifts from say 4th -> 5th wouldn't happen as I commanded, even when they normally would when I wasn't in ETC Pwr. I went back and revised the upshift tables to have all values set to the corresponding downshift table's lowest value. For example, 2nd -> 1st was 6.909, so I set all 1st -> 2nd values to 6.909. In my head (and so far in the truck) it makes sense. This only allows the higher gear anytime I am above the minimum to keep from bogging, but does not limit upshift request beyond that. Is this what you guys are doing? If not does anyone see a flaw in that logic?
    Secondly, I have noticed that the GL shift points seem to be completely ignored until the truck is at least partially warmed up. I've only driven it twice since implementing GL, and both have been immediately after the 2 flash changes. Not sure if it is the tune settling in, or if a different table is used when cold. Both times GL started working at about the same place down the road. I think I saw another mention of temp related shift maps, but has anyone else experience a difference between cold and warm with GL?
  17. Oct 29, 2020 at 12:08 PM
    #7397
    McFlysRide
    McFlysRide Well-Known Member
    Maryland
    2017 TRD Sport DC
    6" lift, Fox 2.5 DSC with adjusters(Rear 2.5s on the Rona’ back order) FF headache racks/Modifier&RC Cubes,DBCustoms Matte PC Grill w dual RC Cubes and amber backlit script, Westin Rails,Dropstar 20" 645B with 35.12.50.20 Nitto Trail Grapplers. MESO'd out. Rago bed mounts. Dynamat,JL650s components in all corners with dual JL 10” shallow mounts/custom box. Taco tunes amp for the doors and Monoblock for the subs.
    Not sure where else to post this...
    @OVTune any updates on the Wi-flash cable? I understand the multiple projects OV is involved with, but purchasing the Software/Tunepack and WiFlash cable back in August I'm curious if I have any options other than wait for the release if it is delayed much longer.
    BTW I've Zendeskd about this inquiry also.
    Thank you.
  18. Oct 29, 2020 at 12:23 PM
    #7398
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    That's the scary part.......another reason I hate taking my truck places to get worked on.
  19. Oct 29, 2020 at 12:31 PM
    #7399
    dunlap837
    2018QSDCLBSR5
    What you did makes sense to me. I set my values to be a bit below the stock non ect shift points. This allows me to upshift on command sooner than ect or even the stock non ect settings if I want. I may end up copying what you did though.
    And yes there does seem to be a separate map for cold shifting.
  20. Oct 29, 2020 at 12:57 PM
    #7400
    Quacktacular81
    SW Colorado
    It seems to work well having the values matched. I'll know more once I get more miles on it this weekend. One thing that could cause issues is if you were to request a downshift and an upshift at the same time. Thinking along the lines of stabbing the skinny at exactly 6.909. It should be ok as you would quickly accelerate past that and settle into 2nd, but maybe an instant of weirdness.
    Good to know there is a cold map. The point that the GL took over seemed too coincidental to be a learning issue. Perhaps after the webinar, we'll have a better understanding of what all of the shift maps represent.
Thread Status:
