vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Oct 30, 2020 at 3:49 AM
    #7421
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    I only really notice benefits of premium higher in the revs myself. And if you're trying to save a few bucks, you probably don't belong at 4000+ RPMs :D
    GPatriot, BlkTaco47 and mZiggy like this.
  2. Oct 30, 2020 at 5:14 AM
    #7422
    Mooseditty17
    AJ
    WI
    You oughta be praying for the technician :rant:
    But thanks.
    Uscgamecock7[QUOTED] and b3itz like this.
  3. Oct 30, 2020 at 5:25 AM
    #7423
    Mooseditty17
    AJ
    WI
    Looking for general consensus, or better yet, prior experience.
    If one lowers the TC unlock points to help alleviate the lock/unlock/locking it likes to do, the transmission should still know to unlock before shifting, correct?
  4. Oct 30, 2020 at 5:27 AM
    #7424
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    "The intake wouldn't have fallen off if you wouldn't have flashed some crazy custom software to your truck! Warranty void" - Toyota probably
  5. Oct 30, 2020 at 5:30 AM
    #7425
    Mooseditty17
    AJ
    WI
    Clearly their "master" technicians are a bigger danger to my truck than any aftermarket parts I've added! FFS.
  6. Oct 30, 2020 at 5:36 AM
    #7426
    Mooseditty17
    AJ
    WI
    Could it be???
  7. Oct 30, 2020 at 5:46 AM
    #7427
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    :taco:
    :bikewheelie:
    I need to catch up on some of these tunes! Running one of @Mooseditty17 original shift update tunes.
  8. Oct 30, 2020 at 5:51 AM
    #7428
    CorbinDallas
    CorbinDallas Well-Known Member
    Corbin
    Tacoma
    16 MT OR
    When I first updated the the TSB for MT (04B14) I used the flash utility to read the ECU this creating a stock 04B14 file.
    It creates the stock 04B14 file as a p5f file.
    I understand that opening VF and using the flash utility from there is the preferred way. However, it uses .vft files.
    I assume it will also be okay to still flash p5f files as well? ( Hope that all makes sense)
  9. Oct 30, 2020 at 5:57 AM
    #7429
    Mooseditty17
    AJ
    WI
  10. Oct 30, 2020 at 5:57 AM
    #7430
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    Stock tune can shift between 5 and 6 with maps calling for locked TC right? So i would say yes.
    Mooseditty17[QUOTED] likes this.
  11. Oct 30, 2020 at 5:58 AM
    #7431
    Mooseditty17
    AJ
    WI
    Valid point :tinfoilhat:
  12. Oct 30, 2020 at 6:00 AM
    #7432
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
  13. Oct 30, 2020 at 6:10 AM
    #7433
    Mooseditty17
    AJ
    WI
    Got it!
    Thank you.
    BlkTaco47[QUOTED] likes this.
  14. Oct 30, 2020 at 7:31 AM
    #7434
    Mooseditty17
    AJ
    WI
    For tc unlock
    If I want to to hold the lock longer while depressing the gas, do I raise or lower the values????
    Raise them right??
  15. Oct 30, 2020 at 7:38 AM
    #7435
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    You can flash .p5f files, you just cannot edit them.
  16. Oct 30, 2020 at 8:00 AM
    #7436
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    Survey says.....no.
  17. Oct 30, 2020 at 8:06 AM
    #7437
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    I was led to believe the opposite in previous discussion about it. Raising the values should lead to more unlocked situations.
    Think about it, raising the values to 256.xxx makes it always unlocked so raising them should make it be unlocked more.
  18. Oct 30, 2020 at 8:07 AM
    #7438
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Yes, at elevation 85 is ok. But if you plan on driving to lower elevation, I would have 87 in the tank.
  19. Oct 30, 2020 at 8:13 AM
    #7439
    Mooseditty17
    AJ
    WI
    That is true. But why then @ 21% throttle is the value higher than 7% throttle on the stock unlock table? Wouldn't that mean that at a lower percentage of throttle it will unlock at a lower mph? Damn this s*** can be confusing
  20. Oct 30, 2020 at 8:14 AM
    #7440
    Mooseditty17
    AJ
    WI
    This torque converter lock up bounces back and forth all the time because the lock and unlock are so f****** close... If once it locked you gave it a little more gas and it didn't immediately unlock it would be far more drivable
Thread Status:
