vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Nov 3, 2020 at 10:18 AM
    #7561
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    What all did you apply to get your truck to where you wanted it?
  2. Nov 3, 2020 at 10:57 AM
    #7562
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Anyone get more vibration between about 2000-2400 rpms, especially with more load? Happens stock and tuned.
    GPatriot likes this.
  3. Nov 3, 2020 at 11:19 AM
    #7563
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    Started with 2.0 thx.
    Increased accelerator request to airload about 25% for the first half of the table, about 20% for the second half. Then did some minor smoothing from there. It is similar to but slightly less aggressive than 04A61 translations of your tune I’ve looked at.
    Increased low accelerator pedal shift points.
    Decreased mid pedal 3-4 downshift to hold 4th gear a bit longer when highway passing.
    Increased gear 1 and 2 throttle limits at low accel pedal. Gear 2 matches gear 3, gear 1 is upped about halfway to gear 3.
    Implemented gear lock by ECT button.
    No other changes. I’ve been meaning to post up my tune, but it is really very similar to other tunes that have been posted.
    Mooseditty17[QUOTED] likes this.
  4. Nov 3, 2020 at 11:35 AM
    #7564
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    looking through vftuner to keep torque converter locked in S5 (5th gear) around 50mph and up with no unlock. should i be looking to modify tables. (torque converter locking 5th gear 5) and (torque converter unlocking 5th gear 5) ? i believe 6th gear the tc is fully locked. values of both those (unlock 6th gear 6 and lock 6th gear 6) tables for 6th gear are all 255.99 across the board. maybe mirror those values into 5th gear tables?
  5. Nov 3, 2020 at 12:01 PM
    #7565
    fothermucker
    fothermucker New Member
    guys! how do i replace the slider on my 2017? Trying to not order the factory replacement ($$$); I have tried ebay etc etc and can't locate a replacement
    thanks
  6. Nov 3, 2020 at 12:04 PM
    #7566
    rlc177
    rlc177 Well-Known Member
    Pretty much had this from the day I brought the truck, although since time went on its not as bad as when the truck was new. Not sure its a tunable thing since Toyota never admitted what the problem is. Two prevailing theories were akinsmode+intake and torque converter.
  7. Nov 3, 2020 at 12:05 PM
    #7567
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If you are talking about your rear window slider, I think you have the wrong thread?
    But, check out car-part.com . It searches salvage yards.
    Mooseditty17 and pinochle like this.
  8. Nov 3, 2020 at 12:05 PM
    #7568
    Max713
    Max713 Well-Known Member
    Max
    Eugene, OR
    2017 MGM TRD OR
    Wrong thread
    blitzkrieg3002 likes this.
  9. Nov 3, 2020 at 12:58 PM
    #7569
    ForceOfG
    ForceOfG Well-Known Member
    Portland, OR
    16' DCLB 4x4 Off-Road
    5.29 Yukons Stage 2 Icons 265/70/17 OVTuned
    It doesn't look like you're on 04B04 so I cant speak to the table numbers specifically but what you'll want to do is modify the locking 5th gear maps so that it is 59 (yes 59) across the board. IF you want it to lock sooner at lower pedal than just drop the first couple cells back down but regardless of pedal it'll lock at 50. To make sure it never unlocks you modify the unlock tables so that they are a value below 59. The unlock tables seem to supersede the lock tables so if you have an overlap than it will stay unlocked rather than lock.
    As a side note, once you let off the pedal it unlocks. With this map if you get back on the pedal above 50 it will stay unlocked for a second or two before locking up again.
  10. Nov 3, 2020 at 1:24 PM
    #7570
    Quacktacular81
    Quacktacular81 Unknown Member
    SW Colorado
    2020 Tacoma TRD Off-Road
    I agree that kicking on ETC at a stop and then letting the truck do its thing with those shift points would likely be less than optimal. By choosing those values I have to keep in mind that I am in control, much like a MT. I did a 700 mile road trip over the weekend, towing our trailer and loaded with bikes. Generally, I'd run in normal mode and mostly with CC. For a few big climbs I'd use the GL functionality. It is spot-on for the times when 3rd will accelerate, but 4th loses speed. Lock it into 3rd and just go.
    I think I saw that none of the current maps we have to work with control the cruise control shifting. When that releases it will be nice to get those dialed in.
  11. Nov 3, 2020 at 1:34 PM
    #7571
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    @cheesehomer , how’s the @Mooseditty17 tune (Jim.Reg_Perf+Tow) working out for you? You like it? Anything you’d change or add?
  12. Nov 3, 2020 at 1:41 PM
    #7572
    ihatemytruck
    Dave
    Southern California
    I'm just wondering if it may be the exhaust angles, because I remember Mat talking about those before and how there was some overlap. I see the maps in vF to change it, but until we get some more info about it, I don't feel comfortable messing with them.
    tonered likes this.
  13. Nov 3, 2020 at 1:46 PM
    #7573
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    All that I know is that Ducatis used to sound glorious with 45deg of overlap and sound like trash at 11deg. I wonder . . .
    ihatemytruck[QUOTED] likes this.
  14. Nov 3, 2020 at 2:51 PM
    #7574
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    ??? got me wondering too - I have a 04b04 regular_stock_thx_tow.vft that came out 9-21-2020 that I have never flashed. Wonder how the mentioned and this one compare. LMK - I could post for others to flash and evaluate. Would like same from Jim.....
    Mooseditty17 likes this.
  15. Nov 3, 2020 at 3:35 PM
    #7575
    wiljayhi
    Jim
    3G, Tuned
    @Mooseditty17 made the tune for my ECU, 04A61, and I posted the tune at the request of @cheesehomer . I was just wondering how it was working for him.
    Did you want me to post it so you can take a look at it? Compare the two in vFT?
  16. Nov 3, 2020 at 4:20 PM
    #7576
    Boltripper
    Boltripper Well-Known Member
    Hoover, Alabama
    2020 TRD Off Road Access Cab A/T in MGM
    Khaya Camper with Custom Mods - BP-51's, 4.88's, 33's', Dissent Offroad Front and Rear with Bud Built on the sides...
    So I finally got around to loading the VFTuner.. I previously had the flash kit and I'm running the 2.0 Tune from OVT.
    My question is, is its possible to add the AGM settings to the 2.0 file from OVT that I'm currently running? The VFT Software won't load the file type that I flashed with the P5F
    Or do I need to request OVT To send me that file in the Vft file format??
    Hope thats understandable.
    Best,
  17. Nov 3, 2020 at 4:21 PM
    #7577
    Shellshock
    Iowa
    You need to message zendesk and request the tune pack
  18. Nov 3, 2020 at 4:22 PM
    #7578
    wiljayhi
    Jim
    3G, Tuned
    If you need to edit a tune file it has to be .vft format
    Boltripper[QUOTED] likes this.
  19. Nov 3, 2020 at 4:22 PM
    #7579
    Boltripper
    Hoover, Alabama
    Thanks my friend.. Appreciate the quick response.
  20. Nov 3, 2020 at 5:15 PM
    #7580
    DownhillDragon
    DownhillDragon Well-Known Member
    Brody
    Austin, TX
    2017 Tacoma TRD Pro AT Cement - POWERTHIRST v2.4 Tuned
    POWERTHIRST Tuned - My Custom OVTune SSO Slimline Bumper with Stage 2 Kit + BajaDesigns 20" Light bar with Amber Backlight + Smittybilt Winch x2o 10,000lb Synthetic CaliRaisedLED Step Edition Rock Sliders SUSPENSION FRONT A.D.S. - 2.5 Adjustable Dampening Remote Resi Fronts Dirt King Upper Control Arms SUSPENSION REAR A.D.S - 2.5 Smoothie Piggy Back "Rear" Shock With Compression Adjuster Deaver Leaf Pack Cab Mount Relocate by Triple-C Chop Shop, Lago Vista, TX Nitro Gear 5.29 BFG KM3 35x12.5x17 Fuel Rebel6 17" Wheels + Full-size Spare + Rhino-Rack Spare Wheel Strap 4x Rigid Cube Ditch Lights + Cali Raised Ditch Light Hood Mount Brackets + Cali Raised Ditch Light Extension Brackets + 3x Cali Raised Switches + Light Switch Mount Bracket Snugtop Camper Shell with Carpeted Ceiling and Mounting Tracks Prinsu Top Rack and Cab Rack Hi-lift Jack + Hi-lift Jack Mount on roof DEFEND INDUST Recovery Traction Tracks (knockoff Maxtrax) Trimax ST30 Trimaflex Spare Tire Cable Lock (Round Key) 36" x 12mm K&N Intake Canvas 270 RV Awning Rooftop Sun Shelter + Prinsu Awning Brackets Fire Extinguisher w/mount Campbell Hausfeld FP209499AV - 3 Gallon Air Compressor
    So just got back from the lil trip, and here's the results: On a fresh tank of 93oct and a fresh flash of Mild+Wild, I got (and these are after accounting for tire size) 16.1 mpg on the 90 mile trip there, and 19.3 mpg on the way back, all highway miles except maybe 5 miles total on the surface streets. I assume the improvement coming home is likely due to the truck's learning settling in. I can safely say the way back is the highest mpg's I've seen like ever in that truck, since it was stock.
    I have yet to play with the Wild mode, since I didn't want to invalidate the data, but I assume I'll see a good (and fun) drop in mpgs :)
    Great work, @Mooseditty17 , this might be the tune I branch off, since I really like the idea of having two very distinct modes for different purposes. Only 6 more days till the 5.29 gears go on, so it'll be fun seeing what (other than the obvious gear maps) will need to be tweaked to maximize the new ratios!
Thread Status:
