vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Nov 4, 2020 at 5:32 PM
    #7601
    cheesehomer
    cheesehomer Active Member
    3 inch lift , 20 inch rims
    I have know idea what i was doing wrong, put a charger on while I flash , all good. I will give you feedback by the end of the weekend. thanks
    wiljayhi[QUOTED] likes this.
  2. Nov 4, 2020 at 6:19 PM
    #7602
    J.cubed.designs
    J.cubed.designs Member
    2018 Cavalry Blue Tacoma TRD Pro
    Just tuned mine last weekend! Just used one of their stock tunes because I am not savvy with this kind of stuff. It rides waaay smoother! Love it so far.
    Mooseditty17 and Stormpeacock like this.
  3. Nov 4, 2020 at 6:20 PM
    #7603
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    ?? using the 2.0 USB connection on the computer? 3.0 usually ends in failure. Or you upgraded your OS version and you now have a different Computer ID. ?? If you just had an OS system update the virus software has more and new steps to turn off before you can flash - mine just updated yesterday and they are different than two days ago.
  4. Nov 4, 2020 at 7:40 PM
    #7604
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Whew. Long night. But got a 04B31 tune updated to @Mooseditty17 awesome tune. Also with @Mooseditty17 / @tonered air load control tables.
    Going to flash the truck tomorrow and test it over the weekend. Pretty excited to see how it goes!
    AODRN, tonered and Stormpeacock like this.
  5. Nov 4, 2020 at 7:50 PM
    #7605
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Any idea what these table are for in B04? Thanks
  6. Nov 4, 2020 at 7:51 PM
    #7606
    DownhillDragon
    DownhillDragon Well-Known Member
    Brody
    Austin, TX
    2017 Tacoma TRD Pro AT Cement - POWERTHIRST v2.4 Tuned
    POWERTHIRST Tuned - My Custom OVTune SSO Slimline Bumper with Stage 2 Kit + BajaDesigns 20" Light bar with Amber Backlight + Smittybilt Winch x2o 10,000lb Synthetic CaliRaisedLED Step Edition Rock Sliders SUSPENSION FRONT A.D.S. - 2.5 Adjustable Dampening Remote Resi Fronts Dirt King Upper Control Arms SUSPENSION REAR A.D.S - 2.5 Smoothie Piggy Back "Rear" Shock With Compression Adjuster Deaver Leaf Pack Cab Mount Relocate by Triple-C Chop Shop, Lago Vista, TX Nitro Gear 5.29 BFG KM3 35x12.5x17 Fuel Rebel6 17" Wheels + Full-size Spare + Rhino-Rack Spare Wheel Strap 4x Rigid Cube Ditch Lights + Cali Raised Ditch Light Hood Mount Brackets + Cali Raised Ditch Light Extension Brackets + 3x Cali Raised Switches + Light Switch Mount Bracket Snugtop Camper Shell with Carpeted Ceiling and Mounting Tracks Prinsu Top Rack and Cab Rack Hi-lift Jack + Hi-lift Jack Mount on roof DEFEND INDUST Recovery Traction Tracks (knockoff Maxtrax) Trimax ST30 Trimaflex Spare Tire Cable Lock (Round Key) 36" x 12mm K&N Intake Canvas 270 RV Awning Rooftop Sun Shelter + Prinsu Awning Brackets Fire Extinguisher w/mount Campbell Hausfeld FP209499AV - 3 Gallon Air Compressor
    hey guys, do we have a good ETA on when the 'compare' tool on VFTuner is going to be working again? I remember seeing something a few days ago from Mat saying that he knows the cause (float comparisons being off by some miniscule decimal), but this didn't get fixed in 1.2.7.0 right?
  7. Nov 4, 2020 at 8:11 PM
    #7607
    ForceOfG
    ForceOfG Well-Known Member
    Portland, OR
    16' DCLB 4x4 Off-Road
    5.29 Yukons Stage 2 Icons 265/70/17 OVTuned
    Hint: If you change them do they also change your primary shift 1 tables?
    Not quite sure on the purpose of having two maps that do the exact same thing tho..
    ihatemytruck likes this.
  8. Nov 4, 2020 at 8:31 PM
    #7608
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have had that at times. Just keep trying. Be sure that you give the Taco a few seconds to initialize. I wait until it is done bonging. Be sure the ignition is On without the motor running.
  9. Nov 5, 2020 at 3:02 AM
    #7609
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    In 04A61 they update automatically from the primary upshift 1 table. I think they are just a legacy table from when there was only 1 shift schedule.
  10. Nov 5, 2020 at 5:44 AM
    #7610
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Manitoba
    3G, Tuned
    Thanks, Tony. @cheesehomer tried again and put a charger on the battery and it flashed ok.
    wahoobie and tonered[QUOTED] like this.
  11. Nov 5, 2020 at 5:46 AM
    #7611
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    Good stuff. A jump pack in non-boost mode helped me with a TSB flash.
  12. Nov 5, 2020 at 6:57 AM
    #7612
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    When I flash other trucks I put a battery jump on them for the process just to be safe.
    wiljayhi and tonered[QUOTED] like this.
  13. Nov 5, 2020 at 6:59 AM
    #7613
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I was a little worried about my pack lasting the time it takes for a TSB Update on an AT, but it was a champ. The CUW won't load if the volts are below a cutoff. Something like 11.5v or 11.8v?
    I haven't seen an OVT flash not kick off for that reason, but this ECU is whacktastic.
  14. Nov 5, 2020 at 7:04 AM
    #7614
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    I think it helps the ECU default to primary shift tables
  15. Nov 5, 2020 at 7:39 AM
    #7615
    Boltripper
    Boltripper Well-Known Member
    Hoover, Alabama
    2020 TRD Off Road Access Cab A/T in MGM
    Khaya Camper with Custom Mods - BP-51's, 4.88's, 33's', Dissent Offroad Front and Rear with Bud Built on the sides...
    Can someone verify the latest release of VFTuner?
    I have 1.2.7.0
    I downloaded from an old email that Mat sent, but want to verify that is the latest release.
    Thanks,
  16. Nov 5, 2020 at 7:46 AM
    #7616
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That version was just posted last Saturday. The links to the download will get you the latest version.
  17. Nov 5, 2020 at 8:27 AM
    #7617
    uploadadventure
    Dixon, Mo
    So
    New tune. So far.
    :D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D
    :101010:
    Mooseditty17 likes this.
  18. Nov 5, 2020 at 8:56 AM
    #7618
    InternationalHarvester
    InternationalHarvester VF Pro Licensed, KDMAX Authorized Vendor
    Sierra Nevada
    2017 TRD DC LB OR 4x4
    KDMAX Tooooned
    Tester?
  19. Nov 5, 2020 at 9:51 AM
    #7619
    Boltripper
    Hoover, Alabama
    If I wanted to make the ECT "On" Shifting to lock out 6th gear for when I have the camper on, how would that be accomplished?
    Thanks in advance,
    KanPanic likes this.
  20. Nov 5, 2020 at 9:59 AM
    #7620
    Sierra Nevada
    KDMAX Tooooned
    I see. Looks like you’re running one of moose’s files. Yeah, they’re great files on my truck too. Itching to flash the mild and wild variant after hearing all the feed back. Just hard to bring myself to doing it since the one I’m running works so well. Only thing I’d change is getting it to hold 3rd gear longer. And maybe more TC lock up in ECT.
Thread Status:
