vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Nov 5, 2020 at 2:57 PM
    #7641
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's my method. Although, I'm using NotePad there also.
    ihatemytruck likes this.
  2. Nov 5, 2020 at 3:14 PM
    #7642
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Added the newest Revision (3.1) of Mild+Wild. Attached the file to same link as the original Mild+Wild. Biggest change is Torque converter settings.
    Technique, inksin and uploadadventure like this.
  3. Nov 5, 2020 at 3:21 PM
    #7643
    e46_ema
    e46_ema Well-Known Member
    Emanuel
    Brevard County, Florida
    2020 Tacoma TRD Pro / 2018 Porsche 911 Carrera
    Can somebody assist me with the tune im currently running and have modified for my truck. Am I missing something, any other recommendations?
    I used OVT 2.0 04B81 Premium Stock as a base.
    Things I have currently done are:
    - Change ACIS RPM High to 3400
    - Control Airflow Smoothed x(45.833 - 110) and y(650 - 2400) on Lambda .821 and 0.999
    - Expected Airflow Smoothed x(137.5 - 297.916) and y(650 - 2400) on Lambda .821 and 0.999
    - Adjusted Tire Radius on Drivetrain Control to my current size (stock) 265/70/R16 to 15.303
    - Adjusted Throttle Request to Airload: increased all but the last two columns by 15%, smoothed columns 450 - 650, smoothed columns 250 - 475.
    - First Gear Throttle Limiter all to 100s
    - First Gear Throttle Limiter 4 High all to 100s
    - Throttle Air Flow Increased Gears 1-3 by 20%
    - Throttle Air Flow Increased Gears 4-6 by 25%
    - Increased by 10% all shift point values on Primary Shifting Maps
    Thanks for your time and input.
  4. Nov 5, 2020 at 3:33 PM
    #7644
    Mooseditty17
    AJ
    WI
    Throttle request torque map? Don't remember the exact name. Changing all values from 4k to 5k.
    Throttle request to Airload: easier way to get good results is highlight all values and press control I to make the whole map linear. Or you should raise lower and middle values considerably more IMO.
    Shift maps I'd highly recommend changing values by a Numbered value not a percentage. Raise all by 5 or by 10 etc.
    Lowering TC unlock maps helps avoid all the extra half shifts and helps maintain cooler TC temps. Holds onto lock longer before unlocking. Not sure which ones specifically for your ID though.
    And if your on 5.29s raise global speed to 225
    e46_ema[QUOTED] likes this.
  5. Nov 5, 2020 at 3:51 PM
    #7645
    e46_ema
    Emanuel
    Thanks for that. Are you able to take a look at it if I send it to you and make some changes? Or connect to my computer via teamviewer and take a look? I can pay you for your time I'm new to all this and would like to have a more experienced person take a look at it.
  6. Nov 5, 2020 at 3:54 PM
    #7646
    Mooseditty17
    AJ
    WI
    Sure.
    I can't open your ID, but you could send me screenshots. You on FB Messenger?
  7. Nov 5, 2020 at 3:59 PM
    #7647
    e46_ema
    Emanuel
    Yes. I don't know if you have used teamviewer before but by doing so you would be able to see and control my screen remotely with your computer.
    I also checked and I had set that values you mentioned to 5,000 as well.
  8. Nov 5, 2020 at 4:00 PM
    #7648
    Mooseditty17
    AJ
    WI
    How does one use TeamViewer. My it guy does it at work. I've never done it.
    Check your inbox. I sent you a PM on here.
  9. Nov 5, 2020 at 4:13 PM
    #7649
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Would this cause a dead pedal issue?
  10. Nov 5, 2020 at 4:15 PM
    #7650
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Where’s the fileeeee
    Need to add it to the AT
  11. Nov 5, 2020 at 4:53 PM
    #7651
    Mooseditty17
    AJ
    WI
    Last link in my Signature.
    PapaRee likes this.
  12. Nov 5, 2020 at 5:23 PM
    #7652
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Is it safe to assume that lower TC unlock would/could help MPG without changing performance significantly? A locked TC is more efficient but I have limited knowledge of how it interacts with the rest of the tune/ECU logic.
  13. Nov 5, 2020 at 5:34 PM
    #7653
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    ?? good question. I ran MD tune with the TC mod - very subtle different from the ECT-PWR tune - except the mpg which went down 2+mpg combined city/highway/local. BTW the ECT-PWR did result in the TC/Pan temps running significantly lower than all other prior tunes.
  14. Nov 5, 2020 at 5:37 PM
    #7654
    Mooseditty17
    AJ
    WI
    Did you try the 3.1 version yet? I'm getting 20 mpg with it. Otherwise feels the same as M+W
    PapaRee likes this.
  15. Nov 5, 2020 at 5:42 PM
    #7655
    Mooseditty17
    AJ
    WI
    Small changes in lowering the values. Like 3-5 mph and only in the 3 - 5% throttle ranges and about leave the lowest values alone. The truck WILL unlock prior to shifting. The stock values for lock and unlock are way too close. They end up bouncing in and out of lock. By lowering the UL values it helps Tremendously. I only did this for 3rd S maps and all of 4 except the 5th and 6th maps. I'm fairly certain those are the trans warm up maps. This is of course for 04B04 newer IDs have more maps and different axis values, but same principle
    ihatemytruck and PapaRee like this.
  16. Nov 5, 2020 at 5:43 PM
    #7656
    GoldenBrew
    Golden, Colorado
    only the one you sent me Saturday. So if has been modified since then the answer is no.
  17. Nov 5, 2020 at 5:44 PM
    #7657
    Mooseditty17
    AJ
    WI
    Well I took your input, logged some data and updated
    PapaRee and GoldenBrew like this.
  18. Nov 5, 2020 at 5:45 PM
    #7658
    GoldenBrew
    Golden, Colorado
    I will be downloading and flashing SOON!
    PapaRee likes this.
  19. Nov 5, 2020 at 5:45 PM
    #7659
    Mooseditty17
    AJ
    WI
    Lemme know if you approve
    PapaRee likes this.
  20. Nov 5, 2020 at 5:49 PM
    #7660
    GoldenBrew
    Golden, Colorado
    my opinion is only that - what means the most is your effort and input - to which I say THANK YOU!
    PapaRee likes this.
Thread Status:
