vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Nov 11, 2020 at 10:02 AM
    #7781
    OVTune
    OVTune Well-Known Member
    OVTune
    Yep. It's weird, toyota completely changed their naming structure from the looks of it and now ATs and MTs are both 04Cxx
  2. Nov 11, 2020 at 10:04 AM
    #7782
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks! I suppose they ran out of 04Bxx's with the 2020s.
    Even the Entune Audio Versions have rolled over.
    wahoobie likes this.
  3. Nov 11, 2020 at 10:05 AM
    #7783
    OVTune
    OVTune
    04B31 2019 AT
    04B33 2019 AT
    04B90 2020 MT
    04B91 2020 MT
    04C00 2021 AT
    04C20 2021 AT
    04C30 2021 MT
    names in bold are ones we are working on support / vF Tuner pack is being built.
  4. Nov 11, 2020 at 10:08 AM
    #7784
    ry18Tac
    ry18Tac Well-Known Member
    North Texas
    2018 Quicksand Tacoma TRD 4x4
    Ovtuned
    Which cells are you saying to raise to 90?
  5. Nov 11, 2020 at 10:14 AM
    #7785
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have the ECU Update thread 1st Post updated with these.
    Of course, the big question is when the 2021 TSBs will drop. Hahahaha!
  6. Nov 11, 2020 at 10:15 AM
    #7786
    OVTune
    OVTune
    lol please don't joke. I can't keep up with toyotas TSB and recall shenanigans.
  7. Nov 11, 2020 at 10:16 AM
    #7787
    StraightHardCore
    StraightHardCore Active Member
    Down in da southeast
    Thanks this is good to know. I didn't realize there were two 2020 MTs. Sorry if my post was a bit sassy.
  8. Nov 11, 2020 at 10:17 AM
    #7788
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I hear you there!
    If only there was a way to port 04C30 and 04C00 / 04C20 to all of the ECUs. One ID for each transmission to rule them all.
    CorbinDallas and ihatemytruck like this.
  9. Nov 11, 2020 at 10:19 AM
    #7789
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    All of the Taco MYs have at least two ECU IDs for each engine / transmission. 2016 / 2017 has four for each combo. See the ECU Update thread for details.
    At the moment, there is no TSB to get from 04B90 to 04B91.
    ihatemytruck likes this.
  10. Nov 11, 2020 at 10:20 AM
    #7790
    LstMinutePanic
    LstMinutePanic Well-Known Member
    Colorado
    2018 Black Tacoma OR DCLB AT
    You download it from the main site and install it again. So no "update" buttons. Just installing the program again.
  11. Nov 11, 2020 at 10:46 AM
    #7791
    DownhillDragon
    DownhillDragon Well-Known Member
    Brody
    Austin, TX
    2017 Tacoma TRD Pro AT Cement - POWERTHIRST v2.4 Tuned
    POWERTHIRST Tuned - My Custom OVTune SSO Slimline Bumper with Stage 2 Kit + BajaDesigns 20" Light bar with Amber Backlight + Smittybilt Winch x2o 10,000lb Synthetic CaliRaisedLED Step Edition Rock Sliders SUSPENSION FRONT A.D.S. - 2.5 Adjustable Dampening Remote Resi Fronts Dirt King Upper Control Arms SUSPENSION REAR A.D.S - 2.5 Smoothie Piggy Back "Rear" Shock With Compression Adjuster Deaver Leaf Pack Cab Mount Relocate by Triple-C Chop Shop, Lago Vista, TX Nitro Gear 5.29 BFG KM3 35x12.5x17 Fuel Rebel6 17" Wheels + Full-size Spare + Rhino-Rack Spare Wheel Strap 4x Rigid Cube Ditch Lights + Cali Raised Ditch Light Hood Mount Brackets + Cali Raised Ditch Light Extension Brackets + 3x Cali Raised Switches + Light Switch Mount Bracket Snugtop Camper Shell with Carpeted Ceiling and Mounting Tracks Prinsu Top Rack and Cab Rack Hi-lift Jack + Hi-lift Jack Mount on roof DEFEND INDUST Recovery Traction Tracks (knockoff Maxtrax) Trimax ST30 Trimaflex Spare Tire Cable Lock (Round Key) 36" x 12mm K&N Intake Canvas 270 RV Awning Rooftop Sun Shelter + Prinsu Awning Brackets Fire Extinguisher w/mount Campbell Hausfeld FP209499AV - 3 Gallon Air Compressor
    Hey 04C20 (2021 AT) guys, I finished the port of @Mooseditty17 's Mild+Wild 3.1 last night, reviewed everything, and it looks good! It's as close to a clone as I could get given some of the differences with the stock tune differences.... but I don't have a 2021 AT to test on until tomorrow or the next day.
    It's set up for a completely stock truck, with 265/70/r16 tires, running Reg gas.
    The biggest surprise looking at 04C20 stock maps was that some of the Torque Converter maps were already pushed further in good directions than MD pushed the 04B04 maps to get from stock to Mild+Wild.... so it seems like Toyota is figuring out better TC behavior as well!
    Edit: Here's the link to MD's original description of this tune
    (tune was originally uploaded, but taken off since it wasn't tested)
  12. Nov 11, 2020 at 11:21 AM
    #7792
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    10-4. Just didn't want to fall behind on the latest and greatest. Keep up the good work Matt!
    Is there a Rafael replacement yet? That way we don't always have to bother you...
    Dank Donkeh Luvver likes this.
  13. Nov 11, 2020 at 11:28 AM
    #7793
    ForceOfG
    ForceOfG Well-Known Member
    Portland, OR
    16' DCLB 4x4 Off-Road
    5.29 Yukons Stage 2 Icons 265/70/17 OVTuned
    Lots of factors dictate an answer to that.. How the throttle limit tables have been set up, how the airflow tables have been set up, at what pedal angle you expect it should unlock at a given speed. But to answer in a broad sense it should at least be all of the '100' columns.
    The best method I've found is to graph the tables in excel but I modify the speeds by .885 to get real world MPH speeds.
    Mooseditty17 likes this.
  14. Nov 11, 2020 at 11:30 AM
    #7794
    Mooseditty17
    AJ
    WI
    Mild+Wild is the closest I've been able to get to being truly satisfied so far. I'm currently working on a MD.87_Performance.Tow and a MD.87_Performance.GL. Both will have same shift points and acceleration characteristics as M+W when in drive. Sporty but practical. The Tow mode, activated by ECT button, will hold 1-3 gears longer (approximately 2500 rpm before shifting) and 4th until about 65 mph, or approximately, 2700 rpm. 6th gear is virtually eliminated. It will have only a slightly more aggressive tip in for the tow mode vs regular drive. Same thing can be said for the GL version except, it'll have gear lock of course instead of towing tuned shift points. Activated by ECT and shifting via S Mode.
    Both versions will be for 04B04 ECU ID.
  15. Nov 11, 2020 at 11:34 AM
    #7795
    Mooseditty17
    AJ
    WI
    Excel does wonders!
  16. Nov 11, 2020 at 11:36 AM
    #7796
    StraightHardCore
    Thanks. Truck is 04b91 so was excited about 2020 MT coming out until I found out 04b90 was dropping and not 91 =(
    and i fear im to dumb to tweak values in vf tuner myself without bricking my ecu :anonymous:
  17. Nov 11, 2020 at 11:48 AM
    #7797
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    04B90 is available. The problem is that 04B91 was just recently discovered. It takes a while for new ECUs to get supported. In the end, the later ECU ID is just better.
    Dood. There's no fear editing with vF. The worse case is the you flash back to an earlier version. I had to do that on my first go. Otherwise, the stuff we are messing with on the MT side is mainly small input stuff. Most all of the existing edits have been tried and tested by a good number of folks. There's no chance of bricking the ECU, just getting some odd driveability stuff. If you get wild with AFRs or ignition, which we are not, you can do some damage.
  18. Nov 11, 2020 at 12:20 PM
    #7798
    DownhillDragon
    Brody
    Austin, TX
    the worst outcome I've had so far was when testing my first tune on a Tundra, and it just put it into limp mode. i flashed back to stock, and went back to drawing board. no harm done. sent the tune to mat to see what I f'ed up, he easily found the smoking gun, and I reverted that map back to stock. next test is actually tmrw!
    ktbell444 and tonered like this.
  19. Nov 11, 2020 at 12:43 PM
    #7799
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Sent you a PM.
    mZiggy[QUOTED] likes this.
  20. Nov 11, 2020 at 12:55 PM
    #7800
    ry18Tac
    North Texas
    Ovtuned
    Anybody else notice an increase in throttle response after the fuel pump replacement? Or I just used to driving that 4 banger Tacoma? I still feel that it’s better than it previously was.
Thread Status:
