vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Nov 25, 2020 at 8:11 AM
    #8421
    ForceOfG
    ForceOfG Well-Known Member
    Portland, OR
    16' DCLB 4x4 Off-Road
    5.29 Yukons Stage 2 Icons 265/70/17 OVTuned
    I matched my ECT shifting to my primary shifting and TC tables to remove those unknowns from the testing. Now say my downshift to 2nd table is set so that if I'm going 30 MPH it downshifts at 30% input or more. 30% pedal in D could be 30% throttle. 15% pedal in ECT could be 30% throttle so it downshifts with less input.
    Try it for yourself make a one-off map matching the shifting and TC tables but go crazy with the throttle limit tables for one or the other, cruise at a certain speed and see how much less input it requires to downshift than the other.
    If Mat is saying its accelerator than they would shift at the same pedal input but thats not what I'm seeing
    Mooseditty17 likes this.
  2. Nov 25, 2020 at 9:25 AM
    #8422
    aaronPRO19
    aaronPRO19 Well-Known Member
    Aaron
    Santa Barbara, CA
    2019 TRD Pro
    OV Tuned w/ catted dump tubes, 4.88 Nitro Gears, RCI Skids, Shmellfab Sliders,
    Has anybody purchased the 4runner tune pack and tuned a 4runner? I just purchased and going to use my friend's as a Guinea pig.
  3. Nov 25, 2020 at 9:37 AM
    #8423
    OVTune
    OVTune Well-Known Member
    OVTune
    Accelerator angle is definitely, without a doubt, the axis for the shift tables.
    However, that axis is not the *only* thing that calls a shift. Requested torque will too. If you exceed torque request thresholds (calculated from throttle) it will downshift too.
    The shift maps, and axis is only the *limit* or speed vs *limit* of accelerator. It's 1 piece of a much bigger equation.
  4. Nov 25, 2020 at 10:08 AM
    #8424
    ForceOfG
    Portland, OR
    That makes sense, so we can consider the shift tables as condition A and the torque request thresholds as condition B. If B isn't met than A is used. If B is met it will trigger a downshift/unlock. Do we have access to these tables? Are these the torque shifting tables?
  5. Nov 25, 2020 at 10:10 AM
    #8425
    OVTune
    OVTune
    All Optimal Transmission Torque for shifting 3D tables
    Throttle position vs vehicle speed
  6. Nov 25, 2020 at 11:28 AM
    #8426
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    I want to ensure I'm not unnecessarily abusing the transmission with excessive heat, in the pursuit of "performance" After all, this is a daily driver. When you look at online charts it says x temp equals fluid change after xx miles. I can't imagine that means if the temp hits 205 for 5 seconds that you now have to change your fluid according to the chart for 205 degree operating temps, right? It would be based off an average temp during an operating cycle? So if the majority of the time I'm in the 185-190 range for trans temp, I would then base my fluid changes off that operating range and not the occasional 205-210 I'll hit when accelerating hard.
    Agree?
  7. Nov 25, 2020 at 11:32 AM
    #8427
    Shellshock
    Iowa
    Yes. You can easily get much higher temps towing or just at idle during the summer.
  8. Nov 25, 2020 at 11:41 AM
    #8428
    MLee
    MLee Well-Known Member
    Mark
    Knoxville TN
    2018 Limited Cement
    OTT 7.0
    Best I can do is direct you to @Mooseditty17 and he'll work with you to get what you need and for drinking money he'll even throw in some special touches just for you. I think our goal is to make sure he doesn't sober up until COVID is gone.
    AbnMP13, kibo, ktbell444 and 3 others like this.
  9. Nov 25, 2020 at 11:42 AM
    #8429
    Tharris242
    Tharris242 Technically
    Houston, TX
    2017 TRDOR DCSB 4X4 A/T FP TO BL
    Solid Fold 2.0, Air Dam
    Yeah, I thought you were one of the people that knew what they were doing... just had to make sure.
    Anyway, congratulations on your shift map escape.
  10. Nov 25, 2020 at 11:52 AM
    #8430
    Tharris242
    Houston, TX
    You can't just look a the pretty pictures! (I thought I explained well enough in the text... maybe not.)
    X is Accelerator
    Y is MAF
    Second gear was the worst (and it's the gear you spend the least amount of time in). I think the lines going out right are an indication that I ran out of power; but, it didn't downshift. I'm not worried about that just yet; since, changing throttle limits and airload messes up shifting... I'm saving shifting for last.
  11. Nov 25, 2020 at 11:56 AM
    #8431
    dave5623
    dave5623 Well-Known Member
    2020 TRD Pro
    If I purchase the Tune Pack with no intention of editing anything, do I need to purchase credits as well?
  12. Nov 25, 2020 at 11:58 AM
    #8432
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You'll get credits with the vF licence for one ECU Unlock. You don't need to do anything with them though. They will sit around.
    dave5623[QUOTED] likes this.
  13. Nov 25, 2020 at 11:59 AM
    #8433
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    i just loaded up the M+W 87 tune on my truck and will see what all the rage is about first before I try to load it up on someone else’s truck.
    MLee[QUOTED] likes this.
  14. Nov 25, 2020 at 12:05 PM
    #8434
    KnckleChldrn
    KnckleChldrn Well-Known Member
    Jamie
    Mass
    2017 Tacoma TRD Sport DCSB MT
    Suspension OME 886 Coils OME Nitro Charger Sport shocks OME Nitro Charger Sport struts Deaver Expedition leaf pack Mickey Thompson wheels 265/70/17 KO2 Total Chaos upper control arms Performance K&N air intake Exterior Southern Style Offroad slim line bumper Smittybilt x20 winch Interior Kicker tweeters, front and rear speakers Anytime front and rear camera Hondo Garage stereo knobs Hondo Garage un-Holley mount MESO black out door handles MESO steering wheel MGM overlay MESO puddle pods MESO ultimate red map lights MESO ultimate red dome MESO gasshole MESO ultimate turn signals MESO BD5 3rd brake light MESO stage 3 side markers Retrofit Morimoto 2.0 headlights RGB halo RGB demons RGB DRL Cali Raised raptor LED tail lights SpartanXCustoms scoop light Baja Designs Squadron Sports fogs (amber) Baja Designs Squadron Pro ditch (amber) Baja Designs S8 20" Matt Gecko bed lights Matt Gecko hood lights Switchpro 9100 OEM bed mat 300 Industries grill Bakflip Fibermax cover
    I purchased this, I still need the tune pack to get pre-set tunes for my ECU (04B14) correct? But since I will be getting the turbos and that comes with a tune for the turbos perhaps the tune pack is not needed? @OVTune does the tune pack need to be purchased to receive the turbo tunes?
    Thanks for the help
  15. Nov 25, 2020 at 12:08 PM
    #8435
    Flat wheel
    Flat wheel New Member
    2019 OR
    Has a set of ladder logic tables been compiled for the ECU?
    Sensing points
    Ranges
    Safe ranges
  16. Nov 25, 2020 at 12:18 PM
    #8436
    OVTune
    OVTune
    I would like to wish all who celebrate a happy and safe Thanksgiving.
    We will be closed tomorrow and Friday. But I will be working late tonight to ensure everyone is setup, and master key issues taken care of, etc.
  17. Nov 25, 2020 at 12:23 PM
    #8437
    KnckleChldrn
    Jamie
    Mass
    If you could let me know if the tune pack is needed in order to receive the turbo tunes before you call it quits for the week that'd be great. If needed I'd like to save $90 and buy while on sale. Will be even nicer if you say its not needed and I save $390! haha Hope you have a great Thanksgiving too. I'll be stuck at work until 3. Will get home just in time for some turkey though.
  18. Nov 25, 2020 at 12:23 PM
    #8438
    northwoods_
    northwoods_ Well-Known Member
    cole
    2020 DCSB
    Hopefully you can get to my registry file request I sent yesterday! Order #7676
    Thank you and happy Thanksgiving
  19. Nov 25, 2020 at 12:28 PM
    #8439
    Jbrentb
    Jbrentb Well-Known Member
    Jake
    Wilmington NC
    Black 2016 Trd OR Dcsb
    17x9 mayhem prodigy’s with -6 offset duratrac 265/65-17, fox2.5 coil overs, fox 2.0 rear shocks, OME uca, custom vf tune, Urd spec-u exhaust, high flow catted dump tubes, mbrp muffler, S&B cai, Green lane off road skid and stump bumper, ss3 fogs, pro grill and tail lights, tint, led interior reverse and plate lights, bhlm retrofit HID headlights, Meso turn signals, gashole, and coin holder. hardtop on bed and mat. Blacked out meso everything!!!
    Thanks man, you too! Just hope I make the cut tonight.
    Mines a vf tune registration issue. Enjoy the long weekend. Hope I can tune and test on these few days off.
  20. Nov 25, 2020 at 12:39 PM
    #8440
    16taco-trd
    16taco-trd Well-Known Member
    How many files are included in the tune packs? I am an original flash kit owner who recently purchased VF Tuner, and I just want to make sure that I have all the files that are supposed to be supplied with the tune pack before digging in much further. In the mean time I and am still really enjoying Mild and Wild Premium 3.1.
Thread Status:
