vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Nov 27, 2020 at 10:15 AM
    #8501
    disk_55FL
    disk_55FL Well-Known Member
    disk
    Buckeye
    '17 TRD Sport MT
    He said he " doesn't work " .... ? But it worked for me .... ?
    Finally got around to installing vf after sitting on it since it was first released. The instructions page in my reg email (https://ovtune.s3.us-east-2.amazonaws.com/vForest+Tuner+Instructions.pdf) doesn't work.
    Can someone tell me the process for unlocking my ECU?
  2. Nov 27, 2020 at 10:17 AM
    #8502
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :cheers:
    I wasn't sure if the site points to someplace different than was in the email? The link text is different.
  3. Nov 27, 2020 at 10:20 AM
    #8503
    Rocinante75
    Rocinante75 Well-Known Member
    2018 TRD Pro Cavalry Blue
    RokBlokz Mud Flaps, TufSkinz tailgate lettering, OV Tuned (1.05!!!)
    Right, the tune packs. I think I get that for "free" as I was one of the originals from back in the 1.03 days.
  4. Nov 27, 2020 at 10:21 AM
    #8504
    Rocinante75
    Yeah, I found this instructions in a different location on the site.
  5. Nov 27, 2020 at 10:22 AM
    #8505
    disk_55FL
    disk
    Buckeye
    '17 TRD Sport MT
    :thumbsup:
  6. Nov 27, 2020 at 10:23 AM
    #8506
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yep. You just need to send a message to OVT saying what ECU ID that you want in the Tune Pack.
    Rocinante75[QUOTED] likes this.
  7. Nov 27, 2020 at 11:15 AM
    #8507
    Shellshock
    Iowa
  8. Nov 27, 2020 at 2:10 PM
    #8508
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Does anyone off hand know if there is a difference between 35” tire tune and 33” tire tune?
    Other than tire size?
  9. Nov 27, 2020 at 7:38 PM
    #8509
    DownhillDragon
    DownhillDragon Well-Known Member
    Brody
    Austin, TX
    2017 Tacoma TRD Pro AT Cement - POWERTHIRST v2.4 Tuned
    POWERTHIRST Tuned - My Custom OVTune SSO Slimline Bumper with Stage 2 Kit + BajaDesigns 20" Light bar with Amber Backlight + Smittybilt Winch x2o 10,000lb Synthetic CaliRaisedLED Step Edition Rock Sliders SUSPENSION FRONT A.D.S. - 2.5 Adjustable Dampening Remote Resi Fronts Dirt King Upper Control Arms SUSPENSION REAR A.D.S - 2.5 Smoothie Piggy Back "Rear" Shock With Compression Adjuster Deaver Leaf Pack Cab Mount Relocate by Triple-C Chop Shop, Lago Vista, TX Nitro Gear 5.29 BFG KM3 35x12.5x17 Fuel Rebel6 17" Wheels + Full-size Spare + Rhino-Rack Spare Wheel Strap 4x Rigid Cube Ditch Lights + Cali Raised Ditch Light Hood Mount Brackets + Cali Raised Ditch Light Extension Brackets + 3x Cali Raised Switches + Light Switch Mount Bracket Snugtop Camper Shell with Carpeted Ceiling and Mounting Tracks Prinsu Top Rack and Cab Rack Hi-lift Jack + Hi-lift Jack Mount on roof DEFEND INDUST Recovery Traction Tracks (knockoff Maxtrax) Trimax ST30 Trimaflex Spare Tire Cable Lock (Round Key) 36" x 12mm K&N Intake Canvas 270 RV Awning Rooftop Sun Shelter + Prinsu Awning Brackets Fire Extinguisher w/mount Campbell Hausfeld FP209499AV - 3 Gallon Air Compressor
    Just changing the "Tire Size" field, literally that simple. Just be aware it's measured in Radii (not diameter) so if you're inputting values for your specific vehicle, don't forget to divide by 2!
    That all being said, in theory, you should just have to change two fields (Front Diff and Rear Diff) when you re-gear, but after running the same tune from before my re-gear on 5.29s just changing those two fields, I'm tempted to play with some of the shift points as well, since I don't think everything will translate perfectly with a change that big.
  10. Nov 28, 2020 at 4:41 AM
    #8510
    kdall82
    kdall82 Well-Known Member
    Jeremiah
    2017 Tacoma TRD OFF ROAD
    Installed the mild and wild from @Mooseditty17 last night. I’m happy as the truck now has smooth acceleration verse the 2.0 file where the power seem to be delayed.
    I changed the ratio to 4.88 gears and I’m running 33s with a cap/prinsu rack, sliders, dometic fridge and few other things adding weight. I’m going to run this for awhile but totally happy right now until I get the SC in the future.
    Mooseditty17, PapaRee and TacoNesian like this.
  11. Nov 28, 2020 at 5:59 AM
    #8511
    TacoNesian
    TacoNesian Well-Known Member
    Alex
    Fort Smith, AR
    20 WHT Taco TRD OR DCSB Tech/Prem 4x4 AT
    5.29 gears, front E-locker, CMR, OTT & ProCharged.
    Hey PapaRee, would I be able to use your tune (by Mooseditty17) with 04B81? I know its made specifically for 04A61. I’m new to VFTune and just got my truck tuned for the first time to 04B81_Reg_Stock.vft on my 2020 OR AT Tacoma (stock tires/gears) as a start and want to gradually learn to play around with this software. Any pointers/advice is greatly appreciated.
  12. Nov 28, 2020 at 8:39 AM
    #8512
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    You can’t load our tunes, since you’re on a different ECU. If I were you, I’d make the changes to your file in Vftuner (by comparing files). Or pay someone to do it.
    For me, it would take buying credits ($75) to open another ECU, then getting a .vft file to edit.
    Pm me if you need my help.
    TacoNesian[QUOTED] likes this.
  13. Nov 28, 2020 at 8:47 AM
    #8513
    wiki_taco
    wiki_taco vF Addiction
    PA
    2020 TRD Off Road DCSB
    04B81 Valley Runner BETA Tester
    Try out the 04B81 Reg Thx version... you will appreciate the extra pep..!
  14. Nov 28, 2020 at 8:52 AM
    #8514
    TacoNesian
    Alex
    Fort Smith, AR
    i did not knew what Thx stood for at the time tuning so played it safe and flashed it with the vft file for the time being and go from there. Once I found out reading 10 pgs ago that it meant enhanced throttle response, I’m definitely going to flash it to the 04B81_Reg_Stock_Thx file today! I wouldnt need to purchase additional credits to download this file right? Thanks for the heads up bud!
  15. Nov 28, 2020 at 8:55 AM
    #8515
    wiki_taco
    PA
    correct. Since you already unlocked 04B81, all the files you had to choose from before are still available.
    A few pages back I confirmed what to files abbreviations meant.
    like you, I’ll eventually get a “Mild n Wild” by Mooseditty, but currently for our ECU that’s not available.
  16. Nov 28, 2020 at 8:56 AM
    #8516
    TacoNesian
    Alex
    Fort Smith, AR
    Thanks for your input PapaRee. Im not at that level but will need to learn how to make changes to the file. I’ll flash it to the stock regular thx for the meantime. Btw, Arkansas should have beaten LSU! Lol good game.
    PapaRee[QUOTED] likes this.
  17. Nov 28, 2020 at 9:00 AM
    #8517
    TacoNesian
    Alex
    Fort Smith, AR
    Good deal, I appreciate your input!
  18. Nov 28, 2020 at 9:20 AM
    #8518
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    I havent been to this page in a long time I'm an original OVtune customer and upgraded to VFtune. Its probably been asked and answered a bunch but the search is failing me and I'm tired. So here are my 2 simple and probably overly asked questions
    1. Is the 04b04 VFTune tune pack released?
    2. What do I need to do to get it?
    I'm probably not even on the right version of software since I havent been in this thread for close to 6 months at this point.
  19. Nov 28, 2020 at 10:37 AM
    #8519
    Shellshock
    Iowa
    Yes
    Request tune pack via zendesk
    latest version of vf tuner is on the homepage of ovtuned.com just download and run the installer
    SuperBad[QUOTED] likes this.
  20. Nov 28, 2020 at 10:59 AM
    #8520
    SuperBad
    Dallas, TX
    Truck stuff
    Thanks! Your always a great help in here.:hattip:
Thread Status:
