vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. May 12, 2020 at 4:40 PM
    #861
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    That is no joke. I have paid in the past to use it online and the amount of work needed to pull that off is mind boggling to me.
  2. May 12, 2020 at 4:47 PM
    #862
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    So true. I would have made it about 300 pages in and said fuck it.
    Inferno__Taco likes this.
  3. May 12, 2020 at 5:10 PM
    #863
    OVTune
    OVTune Well-Known Member
    OVTune
    While I can access it, I won't. Simply put messing with it can be dangerous since it is part of the cruise control system
  4. May 12, 2020 at 5:17 PM
    #864
    Quadabaum
    Quadabaum Well-Known Member
    2017 Tacoma TRD OR 4x4 DCSB
    265/75R16 Falkens, ADS 2.5" Stage 3 Suspension, Go Fast Camper
    Just purchased the software. I had the ovtuned kit so hit the link for the license only.
    I am excited to learn this skill and dive into some of the current and potential possibilities of this software. Thanks Matt.
    Is it possible to use vf tuner to adjust tire size? I know you made a few tunes specific to tire size so was hoping this would be possible. I tried searching but couldnt find if this had been answered already.
  5. May 12, 2020 at 8:06 PM
    #865
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    If VF Tuner can't come through with it, there's a viable 2Lo mod available.
    pinochle, Karminski and Shellshock like this.
  6. May 12, 2020 at 8:14 PM
    #866
    Shellshock
    Iowa
    2lo mod is great. I use it quite a bit
  7. May 13, 2020 at 8:03 AM
    #867
    naked farmer
    naked farmer Well-Known Member
    Nor Cal
    ‘17 B.Red Off Road
    Is it bad to be in 4wd low with a loaded trailer? Not sure I see the usefulness of 2wd low.
    PNWTacoma likes this.
  8. May 13, 2020 at 8:11 AM
    #868
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    On high friction surfaces, you cannot turn while in 4wd. For the MTs with a Reverse gear that is taller than the 1st, backing in 2Hi can be a clutch slipping PITA. The 2LM solves that.
    That said, @lapoltba has sent his 2LM harness to a lot of AT folks also.
    One issue with implementing the 2LM with vF is that you need a control switch to tell the 4wd ECU that you want 2Lo, not 4Lo.
  9. May 13, 2020 at 2:16 PM
    #869
    RushT
    North Texas
    I wonder if the way Mat is managing multiple tunes via ECT/S-Mode could be mimicked.
  10. May 13, 2020 at 2:38 PM
    #870
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That might work for ATs if the 4wd ECU can see those inputs. The biggest tune switching issues for MTs is similar since the only available engine ECU input is the cruise control switch.
  11. May 13, 2020 at 2:53 PM
    #871
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    I want to try and modify the torque converter lockup/unlock. Want to tune my truck to not unlock TC over 55mph in 5th. in the tune i'm running now it does this but over 60mph, I havn't tested it stock but most likely will soon. trying to figure out what all these numbers in vftuner mean in relation to shifting in the upshift and downshift schedule. Then I see the gear size for differential is .8 but not sure what I'd enter here for 5.29 gears. I can't wait to see an actual ovtune in vftuner format i could probably figure a lot of this out on my own just by going back and forth looking at the differences between the stock and tuned tunes.
    i'm working in vftuner on 04b31 stock tune.
  12. May 13, 2020 at 4:22 PM
    #872
    Taco16LB
    Taco16LB Well-Known Member
    @OVTune , I am not wanting to be a pest and I know you are most likely swamped but I added a question to my Zendesk # 15138 from 4-28 . I did not get an automated response from the new question . I did get an automated response from the original request for my VF registration but nothing since I sent the email with the system ID .( I have the master key from 4-23 ) Do I need to start over because it has been 2 weeks and it has automatically been deleted ?
    Thanks , and hope you are feeling better .
  13. May 14, 2020 at 6:48 AM
    #873
    OVTune
    OVTune
    I will check today.
    Rafael should have MT ECUs ready to go this weekend.
    I am also preparing tune packs for new vF customers to release this weekend
  14. May 14, 2020 at 6:59 AM
    #874
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    one of those tunes should be an alternator boost only ;) - 14.7 please and thanks haha
    on a serious note, just got my cable in the mail. Waiting for the MT's to post and you'll get my money
    moondog1 likes this.
  15. May 14, 2020 at 7:30 AM
    #875
    Watkinseli91
    Watkinseli91 Well-Known Member
    Eli
    Greenville, SC
    2021 LR PRO
    WAIT A MINUTE....
    manual 3.5 VF releasing maybe this weekend?? I was literally about to post and ask about us manual guys. Any more info on this for new customers who have no tuning experience? MT please :D
    Thanks again Matt! I’m ready to finally try this!
    Auzea likes this.
  16. May 14, 2020 at 11:36 AM
    #876
    crunchytaco13
    crunchytaco13 Well-Known Member
    ‘17 PRO MT Cement
    TRD CAT
    So for new customers with .reg files already installed and Tactrix cable in-hand, that means we’ll be able to tune if both of the above are completed this weekend, correct @OVTune?
    Djdeadpixel likes this.
  17. May 14, 2020 at 2:33 PM
    #877
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Anybody mess with the alternator settings in vFtuner yet? I left the settings on the alternator test file (04B04), but changes the numbers on the graph so that the matched the increments on the stock file, instead of 93 all the way across. Tested the file, and the voltage wasn't increased. It looks like there is a lot to learn about how all this works.
  18. May 14, 2020 at 2:57 PM
    #878
    Stormpeacock
    Stormpeacock IG: @storm.peacock
    Rich
    Atlanta, GA
    19 Cement Offroad
    MCB Elite Performance Tuned 5.29 Differential Gearing 35" Kenda M/T on Steelies SOS Bumpers, Skids, and Sliders Ranch Camper Shell
    Wooooo. Got my tactrix today. Ready for that tune pack baby.
    pinochle and GPatriot like this.
  19. May 14, 2020 at 3:36 PM
    #879
    Double Phister
    Double Phister Punch it Chewie
    Sacramento, CA
    2017 DCSB TRD OR [SOLD]
    the calibration procedure isn't that difficult according to the service manual. You just setup the corner reflector at a certain spot then tell TS to start the calibration. Is there a thread for guys talking about this? I want in.
  20. May 14, 2020 at 5:56 PM
    #880
    OVTune
    OVTune
    Good evening
    we have discovered a bug on 4D tables (for editing).
    This bug will be fixed ASAP! (likely by tomorrow) and a new version build will be available.
    Everyone will need to update to this new version.
    To update:
    simply download the new version and install it.
    it will over-write the old stuff.
Thread Status:
