vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Jan 9, 2021 at 7:18 PM
    #9341
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    I "tipped" my waitstaff. :D well worth it! Ski
    G8R_Taco, PapaRee and uploadadventure like this.
  2. Jan 10, 2021 at 12:13 PM
    #9342
    ry18Tac
    ry18Tac Well-Known Member
    North Texas
    2018 Quicksand Tacoma TRD 4x4
    Ovtuned
    Just downloaded again and mine still says 1.2.7.7
  3. Jan 10, 2021 at 12:14 PM
    #9343
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    If you're using Chrome, try an incognito window.
  4. Jan 10, 2021 at 12:56 PM
    #9344
    mlua805
    mlua805 Member
    2017 Tacoma Off-Road 6MT
    URD SPEC-U Exhaust< Black Widow Muffler , VFTuned
    I tried incognito but no luck still getting version 1.2.7.7. I believe the version 1.2.7.8 was taking down because off errors. That's why we see 1.2.7.7
  5. Jan 10, 2021 at 7:00 PM
    #9345
    Dbronco20
    Dbronco20 Dbronco20
    RJ
    Gilbert, AZ
    2017 Toyota Tacoma TRD Sport 4X4
    Bilstein Suspension, OME Leaf Springs, Full Skid Plates (steel), Ditch and Fog Lights, OVtuned , Thinking about 4.88 Gears
    So - hope someone can get me a little guidance so I can update the ECU with my new gears.
    Its been a little bit since I have done this, so forgive my vaguer'y on the description below.
    I was originally a Flash Tuner, then upgraded to the Vf when that came out. I am not comfortable enough with Vf to do anything just yet, but I would like to update my tune to reflect my newly installed gears. I recall getting a download, or file, something a while back that allowed me to input Yr, Make, Gas, Tire Size.. and then flash and it was at that time I noticed in that file or option menu different options for gears (4.88/5.29).
    Any insights on how to re-flash the truck, keeping my current tune set up because I like it so far, add the new gear ratio?
    Any advice/suggestions/guidance helps, thanks
  6. Jan 10, 2021 at 7:48 PM
    #9346
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    You have two options. Request the tune pack that matches the ecu id if your truck and flash a preset tune that comes in the pack. It’ll have several files just select the tune that matches the gear set you’ve upgraded to and see if you like it.
    Other option would be flash a p5f file that you have stored away. If you no longer have it, it’s not available for download any longer and you’d have to private message someone who may still have it on their personal computer and then flash it through flash manager.
  7. Jan 10, 2021 at 8:40 PM
    #9347
    Dbronco20
    Dbronco20 Dbronco20
    RJ
    Gilbert, AZ
    Thanks! Can I use credits for tune packs? I have 1 credit now because I downloaded the stock file earlier tonight thinking I needed to because those were the files on my computer.
  8. Jan 10, 2021 at 11:04 PM
    #9348
    Stormpeacock
    Stormpeacock IG: @storm.peacock
    Rich
    Atlanta, GA
    19 Cement Offroad
    MCB Elite Performance Tuned 5.29 Differential Gearing 35" Kenda M/T on Steelies SOS Bumpers, Skids, and Sliders Ranch Camper Shell
    you unlock specific ids.. so if you opened 04b04, then you can open any fill me with that Is, including tunepacks
  9. Jan 11, 2021 at 8:29 AM
    #9349
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Email ovtune at zendesk, and request the tunepack for your specific ecu id.
  10. Jan 11, 2021 at 8:56 AM
    #9350
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    I just came back after being away for six months. Is there an updated list of available Tune Packs posted somewhere? (I'm 04B30)
  11. Jan 11, 2021 at 8:57 AM
    #9351
    Shellshock
    Iowa
    You should apply the TSB to your truck to update to 04b33 and get that tune pack.
  12. Jan 11, 2021 at 9:54 AM
    #9352
    Mshort03
    Mshort03 Well-Known Member
    Martin
    Holly springs nc
    2020 TRD off road tacoma
    Hey I figure since this thread is active and seems to be filled with knowledgeable people i was hoping to clear a few things up. I want to buy vf tuner and do my truck but I'm confused as to how to get maps? I see where ov tune isn't making maps anymore but third party people are? Is this correct? I see on their site I can buy the vf tuner software and cable and then I found tune pack I believe was 350...so I just buy these 2 things for ~760 and then I have access to tune files which I can upload on truck? I'm ready to pull the trigger but don't want to spend 800 bucks without knowing exactly what I'm buying. I don't have interest im making my own maps I just wanna take an existing map that is good and upload it to truck.
  13. Jan 11, 2021 at 9:57 AM
    #9353
    paleh0rse
    Raleigh, NC
    Right on. I'll look into that now. Thank you!
  14. Jan 11, 2021 at 9:58 AM
    #9354
    OVTune
    OVTune Well-Known Member
    OVTune
    Software + cable + tacoma tune pack = everything you need for tuning + pre made maps and you don't have to make your own.
    Mshort03[QUOTED] likes this.
  15. Jan 11, 2021 at 10:05 AM
    #9355
    Mshort03
    Martin
    Holly springs nc
    Thank you!! And if I want to tune multiple vehicles then id just have to buy 4 credits per vehicle to be able to tune other trucks?
  16. Jan 11, 2021 at 10:06 AM
    #9356
    OVTune
    OVTune
    for now, yes.
    But if you want to tune other trucks with pre made tunes from us, you must *also* purchase tune packs for those ECUs.
  17. Jan 11, 2021 at 10:22 AM
    #9357
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    Other ECU's, if they are the same as yours, you are good.
  18. Jan 11, 2021 at 12:42 PM
    #9358
    paleh0rse
    Raleigh, NC
    Update: alright, so I've got 04B33 up and running on the truck. What is the latest and greatest process for securing the B33 tune pack so that I can get back to my usual tunage? Is there a feature in vfTuner to download them directly, or do I have to do a few email exchanges with @OVTune to get up and running again?
    appreciate the heads-up on the TSB btw!
    :cheers:
  19. Jan 11, 2021 at 12:47 PM
    #9359
    Shellshock
    Iowa
    Message zendesk and request the tune pack for 04b33
    paleh0rse[QUOTED] likes this.
  20. Jan 11, 2021 at 12:57 PM
    #9360
    skidooboy
    central lower mich
    if you used your credits to open, use, tune, 04b31 in vf, you may have to use more credits to open, use, tune, 04b33. Ski
Thread Status:
