vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Feb 4, 2021 at 7:33 AM
    #9541
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You have a 2019, so I would guess that you're pretty familiar with the hot garbage that Toyota gave us for the Stock tune? There was a lot left on the table.
    Shellshock likes this.
  2. Feb 4, 2021 at 7:49 AM
    #9542
    Alcatraz1015
    Alcatraz1015 Well-Known Member
    Matthew
    2018 MT Super White TRD OR DCSB
    Lol Apparently. I’m waiting on my OV tune kit to ship. I’m more than a little anxious to get the premium tune flashed. I’m using a Pedal Commander atm - which has been fun - but obviously doesn’t add power, efficiency, or fix the weird shifting from the transmission.
    I do have Injen’s new Evo CAI installed as well as Flowmaster’s FlowFx catback. So maybe I’ll be seeing an even greater performance increase.
  3. Feb 4, 2021 at 7:53 AM
    #9543
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Just an FYI, it's not recommended to use pedal commander with the tunes.
  4. Feb 4, 2021 at 7:55 AM
    #9544
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Folks that I know with PCs have ditched them either when they flashed or not long after. Lots of benefits with this tune.
    For the intake and exhaust, they will not help you.
    Folks dynoed with no filter and saw no bump. Some intakes can be detrimental as @OVTune posted recently.
    There are specific areas to get more out of an exhaust with our setup, and it isn't from the muffler / tail. Although, the tune does change the exhaust note for the better.
    Just level setting expectations there.
    inksin and ihatemytruck like this.
  5. Feb 4, 2021 at 8:03 AM
    #9545
    Alcatraz1015
    Matthew
    That’s great to know. Hopefully, I’m not screwed. I guess I’ll find out soon-ish. Do you know what post it was that OVtune advised where some intakes could hurt the tune? For the record, this Evo CAI is a closed box with a cone filter.
  6. Feb 4, 2021 at 8:05 AM
    #9546
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It should be back in this thread or the Dev thread and was posted in the past few days.
    It was about intakes that move the MAF sensor closer to the throttle body. The flow disturbance of the TB messes up the airflow through the sensor.
  7. Feb 4, 2021 at 8:05 AM
    #9547
    Alcatraz1015
    Matthew
    I was curious about that. I wouldn’t have been using it with the tune regardless. Thank you for letting me know if I later decided differently.
    ihatemytruck[QUOTED] likes this.
  8. Feb 4, 2021 at 8:07 AM
    #9548
    Alcatraz1015
    Matthew
    Ooh okay. If that’s the case then I should be fine. The MAF sensor is basically in the exact same location as stock.
  9. Feb 4, 2021 at 8:07 AM
    #9549
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That should be good.
  10. Feb 4, 2021 at 8:31 AM
    #9550
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    Same experience here. Other trucks that used PC have decided to stop using it and sell it....there is just no need after a proper ECU update is flashed.
    tonered[QUOTED] likes this.
  11. Feb 4, 2021 at 9:01 AM
    #9551
    Badname
    Badname Well-Known Member
    Socal
    2018 Tacoma Sport AT
    OVTune 2.0 premium Taco rail universal holder Falken wild peak A/T 265/65R17 Center console tray
    @skyking3
    Very interesting data.
    I'm running 2.0 now and love it but I wouldn't mind trying this one.
    Hope 2.0 performance comes soon.
  12. Feb 4, 2021 at 10:27 AM
    #9552
    Ron1965
    Ron1965 Go Bruins.......
    Ron
    Socal
    2018 Cement TRD ORSB PREMIUM/TECH
    OVtune Mooseditty Custom;DD Exhaust;Nitro 5.29’s;SCS Brushed Copper;AFe Custom CAI
    Don’t get your hopes up. My cai was the same type as yours. I even had the big air scoop attached. I thought the truck ran better until I pulled it off and just used an Hps silicon tube with a dry filter. Truck runs so much better now.
    Phich and tonered like this.
  13. Feb 4, 2021 at 1:14 PM
    #9553
    Alcatraz1015
    Matthew
    Even if that ends up being the case for me, since I’ll have access to the tuning software, I could just tweak it to benefit from my CAI I’m assuming. From what I recall in the past, vehicles can be tuned to take more advantage of the increased airflow of a CAI instead of it being a hinderance.
    If all else fails, I still have my stock air box. I can simply reinstall it and sell my CAI.
    tonered likes this.
  14. Feb 4, 2021 at 2:55 PM
    #9554
    Alcatraz1015
    Matthew
    Can you also describe what "better" means going from your fancy CAI to a silicon tube with a dry filter? Which OVtune were you using? Which CAI were you using specifically before? You said yours was the same type as mine - which I'm assuming meant in general a closed box with a ram intake? Thanks!
  15. Feb 4, 2021 at 8:09 PM
    #9555
    Ron1965
    Ron
    Socal
    More power. Much smoother. Just runs better.
    The Hps is a silicon tube with the MAF sensor connection,etc. It’s not really just a silicon tube. I use an aFe pro filter.
    Am running one of MD’s custom tunes that he has adapted for me quite a few times.
    Was running the aFe Momentum GT cai with the dynamic air scoop.I just remembered how well the truck ran before and wanted to see if I was right. It does run better than with the aFe.It was like there was just too much going on with the aFe.But remember this is just what I “feel.” No dyno proof or anything.
  16. Feb 5, 2021 at 5:05 AM
    #9556
    Alcatraz1015
    Matthew
    Cool deal. Thanks for the replay. I think the biggest difference between my CAI and yours is that the aFe Momentum GT moved the MAF sensor super close to the throttle body as to where my InJen Evo kept it in the same location. I was told by another user that the CAI issue for the OVtune was related to moving the MAF. So I’m thinking my CAI will probably work fine with the tune. I could be wrong but I’ll definitely find out!
  17. Feb 5, 2021 at 5:15 AM
    #9557
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    My experience exactly but now with an AFE drop in filter. These engines do so much better without CAI's. I'm sure via VF a tune could be tweaked to accommodate a CAI and benefit from, but until then it'll sit in my attic. Frankly my truck is running so good now I could care less.
    EDIT - I was running the AFE Momentum with the air scoop.
  18. Feb 6, 2021 at 5:49 PM
    #9558
    OVTune
    OVTune Well-Known Member
    OVTune
    vF Tuner will be going through a major update this month.
    During this time, there may be some days when
    - information on our website may not be available / may be unable to load
    - products on our website may be unavailable
    - our credit server may be unable to be accessed (however we will try to keep it operational 99% of the time through this)
    - zendesk / email ticket answers may be delayed (they are already because I'm STILL trying to catch up from December / January massive wave of new customers)
  19. Feb 8, 2021 at 7:07 AM
    #9559
    OVTune
    OVTune
    vF Tuner 1.2.8.1 will be released in 15 mins.
    This is an interim update before a much larger update.
    included in this update is more tables
    - expansion on some shifting access
    - multiple tables for controlling fuel
    and other things
    the large upcoming update will have multiple tables renamed / refined and updated for more info.
    Mr. Nobody, wahoobie, MOC221_ and 3 others like this.
  20. Feb 8, 2021 at 7:08 AM
    #9560
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Is the new Credit server / Credit values in place in this version?
    Thanks!
Thread Status:
