vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Feb 21, 2021 at 5:20 PM
    #9881
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    yeah im automatic
  2. Feb 21, 2021 at 5:21 PM
    #9882
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Then you will want to be on ecu id 04B04.
    SpeySquatch likes this.
  3. Feb 21, 2021 at 5:22 PM
    #9883
    shotgunbilly420
    i tried figuring this out the other day i do have techstream installed and i have the version 14 of it and i felt lost lol
  4. Feb 21, 2021 at 5:26 PM
    #9884
    ihatemytruck
    Dave
    Southern California
    It's been awhile since I've used techstream, maybe someone else can chime in on how to check your ecu id on it
  5. Feb 21, 2021 at 5:26 PM
    #9885
    shotgunbilly420
    ok yeah i know it cant be to hard to do just need the right info and steps
  6. Feb 21, 2021 at 6:01 PM
    #9886
    DownhillDragon
    DownhillDragon Well-Known Member
    Brody
    Austin, TX
    2017 Tacoma TRD Pro AT Cement - POWERTHIRST v2.4 Tuned
    POWERTHIRST Tuned - My Custom OVTune SSO Slimline Bumper with Stage 2 Kit + BajaDesigns 20" Light bar with Amber Backlight + Smittybilt Winch x2o 10,000lb Synthetic CaliRaisedLED Step Edition Rock Sliders SUSPENSION FRONT A.D.S. - 2.5 Adjustable Dampening Remote Resi Fronts Dirt King Upper Control Arms SUSPENSION REAR A.D.S - 2.5 Smoothie Piggy Back "Rear" Shock With Compression Adjuster Deaver Leaf Pack Cab Mount Relocate by Triple-C Chop Shop, Lago Vista, TX Nitro Gear 5.29 BFG KM3 35x12.5x17 Fuel Rebel6 17" Wheels + Full-size Spare + Rhino-Rack Spare Wheel Strap 4x Rigid Cube Ditch Lights + Cali Raised Ditch Light Hood Mount Brackets + Cali Raised Ditch Light Extension Brackets + 3x Cali Raised Switches + Light Switch Mount Bracket Snugtop Camper Shell with Carpeted Ceiling and Mounting Tracks Prinsu Top Rack and Cab Rack Hi-lift Jack + Hi-lift Jack Mount on roof DEFEND INDUST Recovery Traction Tracks (knockoff Maxtrax) Trimax ST30 Trimaflex Spare Tire Cable Lock (Round Key) 36" x 12mm K&N Intake Canvas 270 RV Awning Rooftop Sun Shelter + Prinsu Awning Brackets Fire Extinguisher w/mount Campbell Hausfeld FP209499AV - 3 Gallon Air Compressor
    If you're on a 2016/2017 AT, just double-click this file, and it will open Techstream's ECU updating tool, you don't even need Techstream open first. It'll tell you to turn your ignition to ON but the engine OFF, and hit Next. At that point, it'll take 10 seconds and pop up a window saying what your Current version is and what the New version will be if you update. If both are 04B04, do nothing. If you're currently on 04B03 or earlier, then continue through the rest of the steps. This updates you to 04B04.
    Edit, this info and much more can be found on this link: https://www.tacomaworld.com/threads/ecu-tsb-update.562550/#post-18431380
  7. Feb 21, 2021 at 6:02 PM
    #9887
    EatableTaco
    EatableTaco NoDak
    Ben
    Williston, ND
    2017 Black Tacoma TRD Sport DCSB
    If you've already flashed tunes to your truck, you are on the latest TSB already. That's something that should have been done before hand, anyway. Unless I misread your previous post. (In that case just disregard my comment) But, I thought you said you tried a tune.
  8. Feb 21, 2021 at 6:21 PM
    #9888
    shotgunbilly420
    thank you
  9. Feb 21, 2021 at 6:25 PM
    #9889
    shotgunbilly420
    ill run the program and see if i need updated
    ihatemytruck likes this.
  10. Feb 21, 2021 at 7:00 PM
    #9890
    N5J_Taco
    N5J_Taco Well-Known Member
    Did you flash a tune already?
    Edit: If you flashed a tune already you are stuck with that ECU ID, you can flash a TSB but that will give you a different ECU ID making any tunes you bought NO GOOD.
  11. Feb 21, 2021 at 7:19 PM
    #9891
    shotgunbilly420
    ok well i have the most recent ov tune on my truck right now . so should i just leave the truck alone then . Again i dont even know if im up to the current tsb for my truck i did have a tsb update from dealer in 2019
  12. Feb 21, 2021 at 7:22 PM
    #9892
    N5J_Taco
    Do you know what your ECU ID is? What version of the tune did you install?
  13. Feb 21, 2021 at 7:27 PM
    #9893
    shotgunbilly420
    would that be the number in the calibration file
  14. Feb 21, 2021 at 7:29 PM
    #9894
    N5J_Taco
    Yes should be like 89663-04B04.
  15. Feb 21, 2021 at 7:30 PM
    #9895
    shotgunbilly420
    89663-04B04 yes
  16. Feb 21, 2021 at 7:30 PM
    #9896
    shotgunbilly420
    i think im getting some where lol not sure
  17. Feb 21, 2021 at 7:31 PM
    #9897
    N5J_Taco
    You are on the most current TSB. You are GOLDEN enjoy your tunes!!
  18. Feb 21, 2021 at 8:12 PM
    #9898
    shotgunbilly420
    thank you for your help im glad i got this all cleared up
  19. Feb 22, 2021 at 5:45 AM
    #9899
    SubaruTheTacoma
    SubaruTheTacoma SubaruTheTacoma
    Rhys
    USA
    2017 STI Off Road
    HELLA Horns BP-51 ARB Summit SCS Ray 10 And many many others
    hey fellas I was reading the ECU TSB thread and noticed this thought I would share since you are both talking about 04B04
    posted yesterday around noon
  20. Feb 22, 2021 at 5:50 AM
    #9900
    N5J_Taco
    Looks like those are for Manual Transmissions we are Automatic!
    wahoobie likes this.
Thread Status:
