vF Tuner for the 3.5L Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rafael@OVTune, Apr 23, 2020.
Thread Status:
Not open for further replies.
  1. Feb 23, 2021 at 5:35 PM
    #9961
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    I believe you could make that work.
    Taco16LB[QUOTED] likes this.
  2. Feb 23, 2021 at 5:53 PM
    #9962
    Taco16LB
    Taco16LB Well-Known Member
    I am going to have to give this a try as my first try at changing anything . If it goes well I may become hooked , but it is intimidating to me . From a google search I found I need to change the ETC up shift and down shift tables , and just adjust the gear I want to the lowest number in the table for that gear . like 30.xxxx .
    PapaRee likes this.
  3. Feb 23, 2021 at 6:02 PM
    #9963
    OVTune
    OVTune Well-Known Member
    OVTune
    If you are using 1.2.9.5 please update to 1.2.9.6. This update is required if using 1.2.9.5
    Thanks!
    Uscgamecock7 likes this.
  4. Feb 23, 2021 at 6:46 PM
    #9964
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    Is there anything wrong with holding out on 1.2.8.1 or whatever until 1.3.0 release? Just not wanting to guinea pig anything and have everything working ok right now.
  5. Feb 23, 2021 at 6:47 PM
    #9965
    OVTune
    OVTune
    1.3.0 is coming soon enough so no need to update if 1.2.8.1 works for you right now.
    BUT if you are on 1.2.9.5 then this update is required
  6. Feb 23, 2021 at 7:08 PM
    #9966
    Pruby18
    Pruby18 Well-Known Member
    2019 DCSB OR 4X4
    Question for anyone willing to deal with a noob. I’ve had the flash kit and 2.0 tune for quite a while and just upgraded to the VFtuner and have a few questions. Will I get the same tunes to input that were released for the 2.0? Are credits only used when tuning another ECU? And finally I’ve read a while back about updating 04B30 to 33 through techstream. Anyone have the link how?
  7. Feb 23, 2021 at 7:11 PM
    #9967
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. The 2.0 Tunes are identical between the Flash Kit and vF. vF just uses editable VFT / VFC file formats.
    As of now, credits are needed to Unlock ECU IDs and individual VINs. Credit costs are cut in half.
    Yep. TechStream is the way. The 1st Post of the ECU Update thread is all that you need. See the link below.
    Pruby18[QUOTED] likes this.
  8. Feb 23, 2021 at 8:39 PM
    #9968
    AZC Edge
    AZC Edge AZ OTT Tuner
    Eddie
    Arizona
    2020 TRD OR 4x4 DCSB MGM
    Tacoma build stuff Kings all around with adjustable reservoirs SKU: KIN25001-119A-EXT KIN25001-121A-EXT Pakrax sliders https://pakrax.com/products/pakrax-16-current-tacoma-sliders Pakrax tailgate panel https://pakrax.com/collections/toyota-tacoma/products/pakrax-05-current-tacoma-tailgate-panel?variant=30310492569705 Body armor pro series front bumper https://www.bodyarmor4x4.com/product/toyota-tacoma-pro-series-front-bumper/ Westcott roof rack https://westcottdesigns.net/product/toyota-tacoma-3rd-gen-modular-roof-rack/ SPC UCAs https://www.4wheelparts.com/p/specialty-products-upper-control-arm-set-25470/_/R-FCMW-25470 Ironman 4x4 full skids https://ironman4x4america.com/heavy-duty-skid-plate-kit-suited-for-2005-toyota-tacoma/ Rough country 30” light bar w/DRLs https://www.roughcountry.com/30-inch-led-light-bar-70930blkdrl.html Rigid fogs https://www.rigidindustries.com/d-series-pro-spot-surface-mount-black-2-lights-202213.html Voswitch 8-button switch panel https://m.voswitch.com/UV100-Universal-8-Gang-Programmable-Switch-Panel-for-Truck-UTV-Side-by-Side-Boat-p1291994.html Gatorfx tri-fold tonneau https://gatorcovers.com/p/gator-fx-tonneau-cover/v/toyota/tacoma/2020/ Anytime backup and front cam https://www.anytimebackupcamera.com/products/2020-kit 3TPAM powered dash mount https://expeditionessentials.com/collections/frontpage/products/toyota-tacoma-3rd-gen-usb-powered-accessory-mount Fieryred 13k synthetic winch https://fieryred.com/collections/winch/products/12v-13000lbs-synthetic-rope-winch-kit Meso Customs stealth pro 2-button shift knob https://mesocustoms.com/collections/toyota-tacoma-3rd-gen/products/stealth-pro-shift-knob?variant=21433407438961 Meso/Morimoto collab Ultimate Tail Lights https://mesocustoms.com/collections/toyota-tacoma-3rd-gen/products/ultimate-tacoma-tail-lights-full-led AJT key fob https://www.ajtdesign-llc.com/online-store/V1-Fob-Case-c69661004 Victory 4x4 center console molle panels https://www.victory4x4.com/product/VTCC.html Desert Does It Seat Jackers https://desertdoesit.com/collections/toyota/products/2005-2019-toyota-tacoma-1-1-4-front-seat-spacer-lifts-front-of-seat + multi mount panel on passenger seat https://desertdoesit.com/collections/toyota/products/front-multi-mount-panel RXT leaf pack https://iconvehicledynamics.com/accessory/15947/icon-accessories-05-up-tacoma-multi-rate-rxt-leaf-pack-w--add-in-leaf/ Redline hood quicklift elite https://www.redlinetuning.com/2016-Toyota-Tacoma-Hood-QuickLIFT-ELITE-p/21-27015-03.htm Hypertech speedometer calibrator https://hypertech-inc.myshopify.com/pages/product-result?rq=yr_2020~mk_toyota~md_tacoma~wa_3-5l-v6-gas Kicker speakers all around https://www.crutchfield.com/p_20646CC674/Kicker-46CSC674.html https://www.crutchfield.com/p_20646CC693/Kicker-46CSC6934.html Kicker Key 500.1 https://www.crutchfield.com/p_20647KEY50/Kicker-47KEY500-1.html Wireless CarPlay adapter https://cplay2air.com/ Duro bumps front and rear https://durobumps.com/product/3rd-gen-toyota-tacoma-front-bump-stops/ https://durobumps.com/product/3rd-gen-tacoma-rear-bump-stops-3-5-2016/ K&N CAI https://www.knfilters.com/63-9039-performance-air-intake-system 285/75/17 Falken wildpeaks a/t3w https://www.discounttire.com/buy-tires/falken-wildpeak-a-t3w/p/26812 KMC Grenade 17x9 -12mm offset wheels https://www.kmcwheels.com/kmc-grenade-off-road AVS bugflector 2 hood shield https://www.autoventshade.com/bugflector-ii/2020/toyota/tacoma AVS low-profile window visors https://www.autoventshade.com/low-profile-color-match-ventvisor/2020/toyota/tacoma Cheap+effective Amazon front&rear dash cam https://www.amazon.com/dp/B08M9JD55C/ref=cm_sw_r_cp_api_i_5K49S7WFCC5XMAPDDY3E Tailgate lock https://www.amazon.com/dp/B07ZL2WCLD/ref=cm_sw_r_cp_api_i_KYY3FYH3ZS06DYZVDAHT Fumoto valve(easier oil changes) https://www.amazon.com/dp/B085RBL4KW/ref=cm_sw_r_cp_api_i_GPBZJTJ0NTAA85R3G2DY?_encoding=UTF8&psc=1 K&N Premium Oil Filter https://www.amazon.com/dp/B0067ED49C/ref=cm_sw_r_cp_api_i_D5DHE5F27G5CW8HHCC31?_encoding=UTF8&psc=1 Raptor-lined fender flares and rocker panels https://www.amazon.com/dp/B07DGVMWS9/ref=cm_sw_r_cp_api_i_KQXFHYDEVNH49SKTA9P4?_encoding=UTF8&psc=1 Supreme Suspensions D-Ring Shackles https://www.amazon.com/dp/B082PDV9KR/ref=cm_sw_r_cp_api_i_EGX04F00SXJ6MBMCR3NW Heritage grill with lights CMC Arizona Toy Pros Needle bearing -> bushing swap Arizona Toy Pros OTT tune with Mild>Medium throttle by Eddie Erosa/AZC Edge/me!
    Hey @OVTune or anyone that may know. Would the changes to the system ID verification process (now that it’s not a step) in these newer updates mean that I would be able to use multiple computers with my master key and login? I reg’d my crap laptop at first, but I’d really prefer to move operations to my newer surface pro
    skidooboy and Mooseditty17 like this.
  9. Feb 24, 2021 at 7:47 AM
    #9969
    Rodchester
    Rodchester Well-Known Member
    Baton Rouge
    2017 Quicksand SR5 DCSB V6
    Weather tech mats, LED interior lights and reverse lights, tube steps, bed extender, bed mat, folding bed cover, TRD Pro grill, blacked out badges and wheel center caps. Kicker speakers(all 6). Front bed rail header. Under hood LEDs. Tufskinz door and interior foam inserts. Chrome interior door handles. Fumoto drain valve. Aluminum oil filter canister. Rear view mirror with Homelink. Quick charge USB charging ports. TRD badge on grill. MESO fuse box cover. Redline Tuning hood struts. Ceramic coating. Pop & Lock auto tailgate lock. LED bed lights. Lower bumper LED light that bar. MESO coin holder. TRD cat back exhaust. Hikari Ultra LEDs high and low beams. 2020 TRD Sport wheels and TRD center caps. RSC Nano dashcam. DSM from the Taco Garage. Blue Sea dual USB outlet on back of center console. KDMax7.0
    Maybe I’m missing something but, to me, it seems like you are wanting S mode to do what S mode already does.
  10. Feb 24, 2021 at 7:55 AM
    #9970
    OVTune
    OVTune
    You can install it up to 3 times / 3 computers,
  11. Feb 24, 2021 at 7:58 AM
    #9971
    N5J_Taco
    N5J_Taco Well-Known Member
  12. Feb 24, 2021 at 8:43 AM
    #9972
    EastVanTaco
    EastVanTaco Well-Known Member
    2017 super white Trd Sport DCLB
    Can someone please give me a knowledgable answer?
    I am having OVtune done this week. I have lil dinky pizza cutter dedicated winters on 16s
    I will be getting the tune for 33" tires.
    I may be driving a week or 2 with the dinky winters before i switch back to 17" rims with my 33" ko2s
    Will this cause any probs or issues or will it drive funny?
    Cheers
  13. Feb 24, 2021 at 8:45 AM
    #9973
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    It will be fine. The shift points may be slightly off, but you probably won't even notice.
    PapaRee and EastVanTaco[QUOTED] like this.
  14. Feb 24, 2021 at 8:45 AM
    #9974
    Taco16LB
    Yes , I want normal S mode below 4th gear . In 4th and above I want it to be able to be locked in gears 4, 5 and 6 ,and needing a manual shift from one to another .
    The normal S mode when set to limit the truck in 4th gear , allows the truck to down shift to 3rd when it wants to . This down shifting to 3rd is what I want to eliminate.
    This setup would also eliminate Mat's original gear lock necessary shifting of gears 1 , 2 and 3 every time I have to come to a stop and start up again , enjoying the reason to have an auto transmission in the first place .
    It is hard to fathom unless you have used gear lock when it was available so I hope this makes sense.
    Rodchester[QUOTED] likes this.
  15. Feb 24, 2021 at 8:48 AM
    #9975
    dave5623
    dave5623 Well-Known Member
    2020 TRD Pro
    When I think about it, plenty of people go from stock to 33 or 35" tires all the time without touching their ECUs. It's probably not ideal but it'll be fine
  16. Feb 24, 2021 at 8:51 AM
    #9976
    Astr0Aar0n
    Astr0Aar0n Well-Known Member
    Portland, OR
    19' Tacoma TRD OR V6 4x4 DCSB cavalry blue
    Quite a few things at this point..
    Is the THX recommended if you're running 33s? And does it eat up the possible MPG gains some get with a tune?
  17. Feb 24, 2021 at 8:51 AM
    #9977
    EastVanTaco
    Well considering how bad they have been for 4 years from factory lol it may be slightly better lol
    Shellshock likes this.
  18. Feb 24, 2021 at 8:52 AM
    #9978
    lapoltba
    CT - 06076
    Thats why I said you won't even notice. The difference from stock to tuned is so massive, the other improvements will overshadow any minimal shifting difference with tire size.
    PapaRee and tonered like this.
  19. Feb 24, 2021 at 9:49 AM
    #9979
    Mooseditty17
    AJ
    WI
    Esmode stops the truck from upshifting he wants to stop the truck from downshifting unless he tells it to
  20. Feb 24, 2021 at 10:45 AM
    #9980
    SubaruTheTacoma
    SubaruTheTacoma SubaruTheTacoma
    Rhys
    USA
    2017 STI Off Road
    HELLA Horns BP-51 ARB Summit SCS Ray 10 And many many others
    C41n likes this.
Thread Status:
